Originally Posted by HD_Dude
Hi again...
Hey, sorry to jump in the conversation midway, but I have read and read and can't seem to find the answer:
Last time I checked, eSata was not 'turned on' for the S3. Has that changed?
Can I buy an eSata hard drive from any local store, take it home and hook it up to the S3 and immediately have more recording space?
Or do I need a special one, like from Weaknees?
Or do I need do do some procedure to have the S3 recognize it?
And will my two cablecards in the S3 complicate any of this?
Hi again...
Some folks have discovered a very simple method about how to connect an eSATA drive to their S3 and make it work. There has been no positive/negative acknowledgement of this from TiVo, which sorta fits their past behavior concerning such "underground" user activity. So, while it's not "officially" turned on, a good number of people have successfully connected eSATA drives to their S3.
Yes, you can hook up any number of eSATA drives to your S3 and increase your storage space. It does not need to be a "special" one. The S3 will format the drive when it recognizes that a new drive has been connected to it.
Basically, all you have to do is reboot the S3 and hold the pause button on the remote. At a particular point in time during the boot sequence, a light on the front of the S3 will change colors. At that time, you enter '6' and '2' on the remote. This instructs the S3 to look for the external drive. After that, the S3 takes over, formats the drive, and adds its space to your overall storage capacity. Very simple.
It makes no difference if you have CableCARDs or not.
