Originally Posted by
Ben Music
Hey guys, I keep reading that TWC is going to a switched digital system by the end of the year. It's going to give TWC increased room for hundreds of HD channels. Will our S3's with cable cards be able to handle this change?
Ben Music
Hi Ben.
First TWC in our area isn't going to SDV anytime soon. To many other things they have to straighten out.
Now if and when they do go to SDV it will more likely mean you will either get less HD channels or the same amount you are getting now. That is because SDV uses the two way cable card and the S3's hardware is not capable of using the two way card. It just isn't in the design.
The last I read is that the cable companies are trying to work something out with TiVo so that they can still use the S3 and the SDV, but how or if that will actually happen is anyones guess. It is possible the FCC may step in and stop SDV but no one knows. SDV is already fully developed in Northwest New York and in Austin Texas. People with S3's have said that there are certain channels they can't get and some they can.
SDV doesn't only mean addition of HD channels but digitally encrypted as well. For example you might take a channel that doesn't get that much viewing and put that on SDV so you can have more bandwith for another HD channel. Lot's of directions this can take. Personally, I don't like it but it's probably something we will all have to deal with.
In anycase it's not likely your S3 will become useless as a result of SDV. It just probably won't be beneficial like you seem to think.
