AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer Elite VSX-82TSX Owner's Thread
The "Official" Pioneer Elite VSX-82TSX Owner's Thread - Page 55
post #1621 of 1626
Originally Posted by tjlmbklr View Post
What about passthrough? I have been seeing a bit of info that says as long as you have passthrough on the receiver it will work.
Sorry, I wasn't aware that some have had success running 3D thru their non-3D receivers - I just know our 82's aren't 3D ready. I've never tried it so I'll have to defer to someone who has.
post #1622 of 1626
I don't know about that. I have a VSX-94, not 3D ready, and it passes 3D just fine.
post #1623 of 1626
Well I am running it as passthrough and I don't even have the best HDMI and it seems to be working fine. However, this is LG's 2D to 3D conversion which may be less to handle.
post #1624 of 1626
Can someone chime in on how to optimize the setup for LFE and R/L stereo full range when using large towers and R/L out to sub? Also, what setting to use analog in from analog out from BDP?
post #1625 of 1626
I was searching the threads for the Pioneer Elite VSX-90TXV and couldn't find very much info but have a basic question if anyone can help here...???
I just received 2 MartinLogan Dynamo 300 budget subs for xmas to replace my 10yr old 12" Energy (EPS-12) Sub that I loved and paid about $600 for but now that has some unknown issues with static while adjusting controls .......
My question is with my older 7.1 Pioneer Elite VSX 90TXV... would I be able to run both these 8" subs in mono from the 1 sub output on the receiver? Is it plausible or should I just ebay the pioneer Elite which I really have enjoyed... and look for a cheap 7.2 AVR?
Any input or helpful knowledge is appreciated.
Happy Holidays
And just out of curiosity... would anyone return a pair of the 8" martinlogan dynamo 300 and pay the extra $60 for the pair of Velodyne VX-11, 10 Inch Subwoofer (Special 2 for $229) if I did upgrade to a new 7.2 avr... I know it's a thing of personal preference, just looking for logical opinions . My system is used primarily for home theater applications or use....... Thank You
Edited by zennn - 12/24/12 at 6:47pm
post #1626 of 1626
Zennn:
I've taken a cheap RCA splitter (two female and one male), plugged it into the Sub out and then ran cables to each of the subs I was using. Not only did it work great, it was less filling, too.
Since the subs are active or powered subs, splitting the sub output is completely invisible to the receiver.
Now, if you fancy yourself a golden ear, you may notice a tiny amount of sonic degradation, but this is extremely unlikely given that you're talking about frequencies in most cases below 80 Hz (or, in my case, since I cross over at 50 Hz, below 50 Hz)..
Should work just fine.
