Originally Posted by
gtgray
The contrast setting is only available in the AV Parameter menu if the you are working with 480i over component. I will admit the scaler seems to work well with 480i component sources.
The image adjustments are available for any analog 480i source, over any input--composite, s-video, component. I don't know why it's limited, I agree it's kind of silly.
gtgray
Pioneer may call those aspect ratio selections choices.. but too me they are just plain brain dead..... why would I want to scale to 1080i and then set it to 4:3...
To preserve the aspect ratio of the source? The real problem is that the scaler's stretches 4:3 by default and it doesn't appear that you can defeat this and leave 16:9 content alone. The 4:3 setting makes sense, if you think about the purpose of the scaler--to upscale SD sources, which are usually 4:3.
gtgray
I bought an external ATSC tuner. HD 3150 Pro from Circuit City.. It does not do 480i .. it has 3 fixed choices only 480P, 720P, and 1080i.. The tuner over HDMI scales to 10801 internally much better than sending a 480P signal to the 82's scaler to make 1080i. I dug out my older Sony progressive DVD player set it 480i over component and agree the Pioneer did a fine job of upscaling that.
This makes perfect sense, actually. To get to 1080i, the tuner simply scales the 480i signal up, leaving the interlacing alone, in one step. Getting to 1080i through the 82, on the other hand, involves many more steps--first, the tuner deinterlaces the 480i signal, then sends the resulting 480p image to the 82, which scales it up and reinterlaces it to 1080i. Those extra steps involve significant signal degradation, which is what you're seeing.
Upscaling the DVD player, on the other hand, all takes place in the 82's Faroudja chip in one step, which is why that looks pretty good.
gtgray
I did have to make signifcant changes to contrast and brightness to get decent picture quality. So it seems to me so far that the Faroujdia or the Pioneer implementation are pretty poor overall. It is not like you want to go setting everything up to go through the scaler.....
Changing the brightness and contrast doesn't mean the scaler is "pretty poor overall." It just means you had to change the brightness and contrast to get good PQ out of your TV. Although I do agree that you don't want to use the scaler for everything. It works well with 480i SD sources, which is what it's there for. But as with anything, it's garbage in, garbage out. If you're expecting a miracle, you're going to be disappointed.
