Originally Posted by BenJF3
Yes, the customer pointed out to me that he used to use the channel banner to scroll through the current channel and hit select when he saw his show. That was on an 8300HDC with SARA. Both of the other features you mentioned are nt in our version of Navigator yet. I upgraded him to an 8640HDC yesterday.
On a side note, I've found two little Easter Eggs in the software for our division. If you directly enter channel 1990 you will get a Diagnostic screen with your version of Navigator. It's only two pages of data, but it's a quick check that doesn't require you to go into the full diagnostic menu. Also, direct entry of channel 1997 will give you a Navigator Install screen which looks like it a way to force a download to the box or dump the info to the headend. The channels are hidden from the guide so you won't see them there. I believe most divisions have them, but they are different channels depending on the division.
That's helpful! Thanks Ben!
Jack
A truck roll will be required because both new boxes and a special splitter have to be installed.
