Originally Posted by derek01
Hi BenJF3,
Thanks very much for the quick response. It was actually your signature in previous posts that made me think it was possible to add a larger drive, I had assumed it was an expansion drive as opposed to surgery.
Do you have a previous post where you describe the process? How easy/hard it was.
Derek
Hi BenJF3,
Derek
I simply swapped the OEM drive with a 1TB WD Black Edition and let it boot. I posted more detailed results earlier. The short version is you will need tamper resistant screw drivers and likely have to remove a security seal. Anyone doing so does it at their own risk.
As far as D*, I was just spitballing ideas. Going with them brings it's own set of issues, but they are a viable option if I get totally fed up with TWC.
