Dave,
I've been doing a little research tonight on the cable requirements, and if I'm interpreting it right, it looks like they can be minimized with the use of DB Plus Separators (Diplexers), based on Dish's data.
Basically, there will be one cable per lnb to the 4x4 switch, two short cables from the switch to the diplexer, and from the diplexer, a single cable per receiver into the house, and into the area of the receiver, then the second diplexer and two short cables from the inside diplexer to the dual channel receiver. The output cable from the receiver to TV2 doesn't go outside, just to wherever TV2 resides. There are drawings for distribution of the TV2 signal cables to support multiple TV's, but I have no need for that anyway. I don't think that's excessive.
I plan to run a full complement of cables, without the diplexers, for the reasons I described in my last post.
