The "fly in the ointment" with that statement is that there are not many devices (TV sets, etc.) that use CableCards. At the moment, most of the 2-99 channels are still analog. For those digital encrypted channels that are in that range either a CableCard or, more commonly, a Digital Terminal Adaptor (DTA) will be required. This will be changing somewhat as TW eliminates these analog channels. What this means for most folks is a DTA or a regular digital Cable Box will be needed to be neededQuote:
A Tuning Adapter has NOTING to do with "Clear Transmission". ("Clear Transmission" means not encrypted.) What is needed is a device on the consumer end to send a signal upstream to tell the node to send out a specific channel. TWC provided cable boxes do that, so do Tuning Adapters. CableCards do not. Tuning adapters were developed as a "band aid" to enable the use of TiVos on cable systems. The software to provide VOD, Start-Over, etc needed to reside in the device (TiVo) that the Tuning Adapter is connected to wasn't there - so no VOD services with Tuning Adapters.HOWEVER, A TUNING ADAPTER IS REQUIRED FOR ANY CHANNELS THAT ARE NOT A PART OF THE IN THE CLEAR TRANSMISSION.
Correct*A cable card plus tuning adapter along with a box such as a Tivo will be able to tune in all TWC Analog plus Digital Channels. This includes the music stations. The only thing you cannot get is Start Over, Look Back, or VOD, nor Caller ID on TV even if you have Digital Phone without additional software.
I suspect so. I believe that those packages are strictly a matter of encryption (function of the CableCard), and, perhaps, SDV (Tuning Adapter).My big question. Digital Variety Package includes 50+ channels included with Triple Play Packages. If a sub does NOT take TWC's POS box, but still has a tuning adapter and say a Tivo or Windows Media Center, and calls up TWC, can they get Digital Variety and Sports Pass without a TWC Navigator box? Or are those "Packages" like Digital Variety, Sports Pass, Movie Pass, tied into to TWC and Navigator as a way to force their DVR's on victims? (unsuspecting customers?)
BTW: In most cases above you keep referring to "TWC DVRs": Navigator is not exclusive to DVRs, it also applies to non-DVR cable boxes as well! I assume that you mean that the POS aspects of Crapigator apply to the DVR functions.
