Originally Posted by
kwilkins
In my ongoing quest to improve dialog with my 3005se setup I've decided to replace the center with either an iQ2c, or iQ6c, and perhaps even an XQ50. On the XQ50 I'm waiting for another poster who just received one to provide his impressions.
I do not know what the relative prices are, but I think that leap-frogging the iQs for the XQ center is a bit excessive. Sure, you want your center channel to be capable, but I do not think that that necessitates such a drastic disparity between it and your other speakers. A perfectly matched front soundstage is also very important and we all know that identical speakers across the front, although not always possible, is the ideal situation. Depending upon how much the XQ center is, consider the following setups, instead, for your front array:
1.) iQ1s with iQ2c
2.) iQ1s with iQ6c
3.) iQ5s with iQ6c
4.) iQ1s with another iQ1
Even though the iQ2c and iQ6c are not identical speakers to the iQ1s or iQ5s, the UniQ driver's coincidental array design makes them MUCH more so than many other manufacturers' center channel offerings.
For similar reasons, and because the tweeter is essentially identical, the 3005 satellites will work well as surrounds with the iQ speakers. And even allow you to consider 7.1. Or selling a pair of the satellites to someone who either needs a couple of small surrounds or is considering expanding their setup to 7.1. You may also be able to sell the center, too, btw, to someone who has, for example, the 2005s and desires a different center.
kwilkins
I'm wondering since I'm replacing the 3005 center if it would make sense to use that in the rear of the room for a 6.1 setup. At issue is that my couch goes right up against the wall it would be mounted on. Would having the 3005 center mounted on the wall facing downward (as much as possible) work well? Due to the couch being against the same wall the position of the speaker will actually be pointing well above my head towards the center of the room.
If it is not too much trouble to experiment, you can, of course, try it. I realize that you do not want to have a speaker sitting idly, but a proper 5.1 setup will sound better than an improper 6.1 setup. More is not always better. Don't use the center in that spot just for the sake of using it.
