sivadselim,
Thanks for your reply.
I initially wanted 3 iQ9s to go behind an acoustically transparent screen in a 2.35:1 widescreen format. However the costs for a good fixed AT screen is at least $3500 more than a good fixed screen. Moiree is a problem often.
The only other options is under the screen. We have 2 other Blu ray 5.1 setups with LCDs that expose all speakers but this will be a theater where all speakers will be concealed (according to my wife, I guess I agree).
The salesman who mentioned the Klipsch RB 81 said that 3 center channel speakers will generally not provide enough high bass even if a sub is used.
What are your thoughts on 3 iQ3s standing vertically in a 7.1 setup. I would have just enough room for the 3 iQ3 speakers and I would aim them towards the first row of seats ear level. Many members have spoken positively about the iQ3 and I see that the freq resp is 45 Hz to 40 khz so it goes lower than the iQ6 at 65 hz.
The iQ3 is 14.4 in tall. Any other good speakers at this heighth? The KL 525 THX Klipsch is nice but is well over a grand. The Klipsch RB 81 is 19 inch hi and that will not work vertically dimension wise.
Thank you
Thank you
