AVS › AVS Forum › Audio › Speakers › KEF Owners Thread
KEF Owners Thread - Page 161
post #4801 of 6059
Looking for any thoughts reviews on Q700s - I am looking to use them as my front 3.
Thanks for any feedback.
Tom
post #4802 of 6059
Originally Posted by galvs View Post
Amazing speakers...blow away the oldies XQ20, rich and tight bass, sounds like towers!
Congrats Kef!
You know, Ive owned and sold Kef speakers now going on 20 plus years, and I have to say the new Q/R series Kef's are actually a big dissapointment, especially over the XQ series(The XQ10's and 20's specifically) which I consider one of Kef's greatest bang for the buck speaker line ever made period, especially with a few tweaks/mods. I would not put the new R series monitors in the same class as the XQ20's......I even have a hard time putting them in the same class as the iQ bookshelves which themselves can be made to sound fantastic with xover and internal cabinet damping mods for dirt cheap money. The new cabinets and drivers are just made cheaper, the minute they went to a box enclosure it became obvious what Kef is doing to cut costs and to improve profit margins on their mass produced, main product lines during what is now a poor A/V economy. And the new R/Q series in room frequency response has shown to be poor in comparison to the older XQ and needs alot more EQing to get a respectably flat response curve in the midrange and treble regions.
post #4803 of 6059
Tom
they are a nice sounding speaker but when i was auditioning i found the q900 to be quite a significant upgrade especially in the low freq. go with the 900s if you can swing the extra money, if not the 700s are a good sounding speaker
post #4804 of 6059
Better off saving the money, bypass the towers and go with a pair of pointsource Q300's or something similiar that can comfortably get you to 80-120hz and then with the money saved get yourself a dedicated sub(or preferably pair subs).
post #4805 of 6059
Can you be more specific about the mods for the iqs? I have a pair of iq90s.
post #4806 of 6059
The size of room will be 12x25, |I didnt think the q300s would be able to play as well as the 700s. The 900 i thought would be overkill.
Already have 2 subs.
I was looking for a better front soundstage behind a Seymour screen.
Tom
post #4807 of 6059
I'd do the towers. I prefer towers for ht. they just sound bigger.
post #4808 of 6059
The iQ's really benefit from 2 mods. Cabinet reinforcement and damping(do first), and xover board component replacement(do 2nd if your comfortable with a soldering iron and have a few bucks to spend). The cabinet mod requires fiberglass resin, hardener and a large carton or 2 of carbon pellets(like what you would use for a fish tank filter or air purifier), and a can or 2 of spray on V-blok. Mix the pellets with the resin and hardener and allpy to the entire inside of the cabinet walls, once dry and hardened, spray on V-blok. This will make the cabinet alot more inert, and add some weight to the speaker. The carbon pellets, resin and v-blok help to reduce outside cabinet vibrations and absorb and diffuse the backwaves of the speaker on top of the generic poly fill used stock by the factory.
The xover conpoents used by Kef in pretty much ALL of their lines have poor tolerances overall. For those without the ability to EQ out each independent channel at multiple frequency points, replacing the xover components can significantly improve the natural imaging ability of the speaker. I've modded a pair of iQ10's and 30's to the point where they produced better imaging and sound detail(And a flatter fs response) over a pair of stock Reference 201/2's, and for a small fraction of the price.
post #4809 of 6059
Tom
Easily, if your subs are actually up to the task, the Q300's will have no problems filling up a room that size. Tower speakers have a habit of coloring and muddying up the midrange from cabinet resonations and uneven blocky bass, and tend to be picky in location needs. The ability to place your monitors in a location suited for optimal imaging, and your subs seperately for optimal bass is always going to be the best setup.
post #4810 of 6059
Tom
If you heard my tiny XQ10's and dual D15SE sub combo, you would think your listening to a pair of monster towers......actually you would probably think your at the concert hall. Its all in the room and speaker setup and calibration. The last pair of towers I owned was a pair of Revel Salon's, and those speakers cannot touch my XQ10/D15SE setup which cost 5 figures less in money spent.
post #4811 of 6059
while i am personally a fan of 'hot rodding' speakers to get more performance out of them, i dont think its a fair comparison to compare a set of modded speakers to a set of unmodded speakers, since not everyone is comfortable (or skilled enough) to modify a set of speakers.. and for those that are skilled enough, not everyone is brave enough to crack open a new set of 500-2000 dollar speakers and start fiddling.. you can make a pinto faster than a ferrari for less money, but at the end of the day its not a ferrari.
post #4812 of 6059
Well, in all reality, there really is no such thing as a "Ferrari" speaker IMO, unless you DIY and spare no expense in materials and design on your own. Even speakers costing 5 figures PLUS dont have more than but a few hundred bucks worth of materials into them at most. Take my Old Revel Salon's, or B&W 8 series tower speakers. The majority of the material is mdf, even the crossovers were STILL using generic run of the mill components. The drivers themselves, though proprietary in many cases, were still in reality "average" in terms of whats available to the DIY market. A pair of Revel Salon's that retailed for about $15k a decade ago had in reality about 3-400 dollars worth of materials and components in them, and even that might be stretching it a tad. Speaker markup is only rival'd by jewelry markup. In other words, its overly obnoxious and rediculous.
With this being said, you can pick up a pair of iQ10's for a few hundred bucks or less, tear it down, reinforce and refinish the cabinet(for the DIYer its actually a fun relaxing project), upgrade the xover components, and have a speaker that can sound better than a pair ofKef reference 201/2's that cost how much stock? And your out of pocket expense will only be a few hundred bucks and that including the cost of purchasing the speakers themselves. For someone who wants "reference" sound quality, but without the cost, this is a very viable alternative, and an easy one to accomplish too.
Kef's UniQ drivers range from average to above average in sound reproduction quality potential compared to whats available on the market. But the point source design gives them above average potential like a true full range driver when it comes to imaging if they are driven actively or the passive xovers are upgraded. Kef's drivers aren't in the same league as say a Fostex, Audience or Mark Audio driver, but for a fraction of the cost they are actually darn close, especially for the relatively inexpenisve price. The older XQ/iQ drivers have alot of untapped potential. And if you want the "Ferrari" quality cabinet, then just bypass the iQ series and look for a pair of XQ's while they are still available.
post #4813 of 6059
yea i totally agree, and id love to hotrod my q series, but am waiting for someone to do the leg work and say do this to them.. much like you did above haha..
my argument is more that, to your average reader here, that might be outside the realm of what they are comfortable doing (aside from the DIY area obviously)
post #4814 of 6059
Got my new KEF Q900 and Q600 and all hook-up today. So far the SQ is very good and I'm happy with what I got them for. Will be breaking them in slowly.
post #4815 of 6059
Originally Posted by jaxwired View Post
Hi guys. New KEF owner here. Just picked up some Model 3s. New in 1998. Bought them from the original owner. Still had the boxes in perfect shape. Had them playing for about a month now. Pretty amazing sound. Spectacular really. Using a Bryston 4bsst2 amp with a placette preamp to feed them.
BTW, I tried replacing the stock jumpers with some Kimber and found the stock jumpers sound better, go figure.
Anyway, loving these KEFs. Really underated. I prefer these older KEFs with the woofers inside the box. Great warm sound. : )
Yes I remember these well. Actually have a set of Model 2's in their original boxes in the basement, near brand new still.......I take em out every once in awhile to play them. Great sounding speaker IF you have a good punchy amp that is low ohm stable. Bryston definetly qualifies! If you like those 3's, then do yourself a favor and try and find some 2's. The 2's don't have quite as much bass, but the bass is a bit more defined and the imaging due to lack of multi front drivers is as well. And Model 2's can be had for cheap money.
post #4816 of 6059
I don't agree.
I have both XQ20s and R300s, and side by side R300s have more puch, much better bass and presence.
IMHO, for my taste, R300 is a step over XQ20.
Just my opinion, of course.
post #4817 of 6059
I don't agree.
Your post here kind of furthers my point a bit. I agree with part of the assesement you made. More "punch", and "presense" I agree with in a sense, but better bass?, or specifically more acurate and more detailed? No way, its not even close. Those XQ20's are ruler flat down to near 60-70hz before they slope off in a nice linear fashion.
BUT........
If your going with a pair of monitors and have no sub,and are trying to attain "full range sound" out of a small monitor then I can see going with the R300's..........they are basically a direct step down design of the 201/2's in terms of driver array and cabinet type/volume tuning........but if you have a good solid sub or 2, then without question the XQ20 is a much better TRUE monitor. Its a true point source driver, the tolerances from driver to driver are tighter as measured with RTA data in room, and its frequency response is much smoother. The XQ20's have alot of natural advantages over the R300's. A. Single Point source driver which allows for better imaging, vs. 2 front drivers. B. Less xover components in line on a 2 way passive system, vs. the 3 way on the R300, allowing for less signal alteration C. A much easier to tune front port system that thankfully doesnt hurt sound quality whether near a back wall, on a shelf, or out in the open. Rear ports like on the R300, give the dreaded 2 peak/ 1 valley bass response(More punch and prsense as you state)but at the expense of detail and accuracy, and the 2nd lower peak under 80hz just muffles the upper midrange excessively unless you keep them far enough away from a rear wall or corner. Without question fill the rear port with the included port plug to reduce this......but then you might lose the "punch and presense" you desire. Its a design tradeoff they made. But again, if your not running a sub and want as close to full range sound as possible, I can understand in a sense going with R300's, and of course if they sound better to you and its what your after, then thats all that matters. But if you have a good sub or pair of subs, Id without question stick with those XQ20's, or would have gone with the R100's in place of em. Just MO of course.
I'm actually surprised you didnt think of doing something like a pair of R100's and with the money saved over the R300's, pick up a matching sub or 2. Would have been a system that you would have liked alot better to your taste, especially since you want bass punch and presense.......you would have had that, and then some with alot more clarity and detail on the lower octaves as well as those R300's still have zero bass in the lowest octave, and from 40-80hz its muddy and uneven still.
post #4818 of 6059
Is there any measurements available yet on the R series ?
BUT........
post #4819 of 6059
I stared with the Ref 2s, bought the Ref 3s (using the Ref 2s as side speakers) and upgraded from the Ref 3s to the Ref 4s (using a Parasound A51 amp). I liked them all, but appreciated the lows in the 3s and 4s. Never noticed that the 2s was more defined and I would personally not 'downgrade'. The 4s are monsters in size though!
post #4820 of 6059
Thise could all be just personal preference to your ears, but I felt the bass the Model 2's gives is smoother, more linear and allowed more detail to come through. The Model 2's like any of these older Kef speakers really shined with a top tier amp. I actually ran/run my Model 2's with a pair of Aragon Palladiums, and an older modded Parasound HC3500. The older model Kef's were REDONCULOUSLY power hungry to sound their best.
THe Model 3's and 4's I feel to sound their best need to be really far away from walls and need a bit of EQing in the lowest octaves. Because of the larger bass drivers and cabinet volume I found they tended to bloat certain frequencies and in the process covered up some detail. But this is true of pretty much all tower speakers, and one reason why I won't even own another tower speaker again. (I kept the Model 2's because of the single point source main driver and the fact that the bass from the interal passive bass drivers isn't overdone or tuned super low like most of the speakers from the 90's era). The Model 2's don't do that, but they also don't hit that last octave either well, and this I feel is actually a benefit. I actually classify the Model 2's as a hybrid "monitor" as they sing the best with a steep slope high pass xover point at right around 40-50hz just above the port tuning point and when used with a good dedicated sub still to this day sound fantastic. Also, the Reference model series greatly benefit from Xover component upgrades. And considering how old they are now, freshening up the xover boards with new caps,coils and blocks would do wonders for em. Get new life out of older speakers. I really love the old Model series Reference uniQ driver, have 3-4 brand new spares also for my Model 2's. You can score em dirt cheap from time to time on Ebay.
post #4821 of 6059
Originally Posted by toolskizm View Post
So I recently got my Q600C in and admittedly, I've never really own a true center channel. More so, I've never really owned a real home theater setup, so this is my first. Upon connecting this speaker and hearing it for the first time, I have to say that I'm very unhappy with it. I'm really thinking there is something wrong with it though. I've tried hooking it up as a center channel and using multi ch audio to play music, and I also watched a move with it. I even tried unhooking the left q300 and putting it in stereo with the other q300 to hear the difference.
This q600c is very very tinny and seems to have no midbass whatsoever..especially compared to the q300s. Is that what you guys get from this speaker? I'm not 100% sure, but I really see no excursion coming from the drivers. It really sounds like just the tweeter is playing. I'm wondering if I got a defective speaker, but I'd like some input especially since I have nowhere I can hear how this thing should sound.
My expectations were for it to sound close to the q300, but that's definitely not the case. And I don't know if that's because it isn't ported, but for 500$ I'm not satisfied at this point...
I got it from accessories4less, so it very well could be defective..
Originally Posted by arshishb View Post
Accessories 4 less is an authorized Kef dealer & all my Kef units arrived new instead of "open box" as said on their website. They do that so that they can post whatever price they want.
As for the Q600c, make sure you are connecting to the bottom speaker terminals & have the 2 knobs all the way in; meaning keep turning them clockwise till they can no longer go in. Also make sure you have connected the correct terminal from the Denon receiver as well.
I truly disagree with you on this one, A4L does has a reputation on it's own for selling stuff that is on really bad shape and should not be sold at all, check my own and other's posts from several users on this same thread. It's not a guarantee that they will send you a new or just open box item. With them it is always a possibility that the unit they send is defective.
What the....? I neither got foam plugs nor rubber foot, no wonder I couldn't figure out how to mount the damn things on the wall.
You still maintain that you've got a new item?? With no foam plugs or rubber foot on them??
If I were toolskizm, I'd go to another store that has the Q600c on demo and see for myself if it's the speaker itself I do not like, or it's indeed a defective unit.
Again, as you can see for yourself with A4L there's always that chance.
Just my 2 cents
post #4822 of 6059
post #4823 of 6059
Just my 2 cents
I'll add my .02 to this as well.
A. Does the person with the Q600c have the xover on his AVR set correctly(ie xover not set too high, with the 600c it should be set to 80hz high pass since it can handle frequencies to 80hz without any issue).
B. As stated.........was it hooked up correctly?
C. A4L I feel is a reputable place. Mark(the owner) is actually a pretty honest stand up guy. Ive dealt with them on and off for over a decade when good deals are kickin around and everything I bought(refurb, open box etc)came in brand new condition. If an item was or is missing an item, I know Mark will take care of you properly. If in fact if you did get a defective unit(happens all the time regardless of where purchased), you wll have the option of doing a swapout, or sending in the unit to Kef America directly for driver/xover replacement. Or if you ask and request, they will send you out a new driver to save time and shipping money since all Kef speakers are field serviceable. I did have a driver fail on one of my XQ's a few years back, one call to Kef, and they shipped me out a brand spankin new driver the same day(Had it in hands within 24 hours)no questions asked, and no need to send the old defective driver back to them. Kef and A4L are very good about taking care of their customers overall.
D. If you are thinking about buying something from A4L, normally they do put in the description if the unit is open box, a refurb, or has some blemishes on it, but all you gotta do is call up A4L ask for Mark, and he WILL double check the actual condition of an item if you politely ask. He will go the mile for you. A few times I bought specific items with "blemishes/scratches or chips" as stated on the description(since I am capable of repairing and refinishing cabinetry myself)and had the item come in , in 100% perfect "brand new" flawless condition. Again though, if your on the fence and question an item description, your just a phone call away from finding out. Mark will be up front and honest to you about the item in question.
post #4824 of 6059
My wife just ordered me a pair of Kef IQ90's. Pretty excited. No more IQ60C's at Vanns. Is there another matched center for those speaker? I am not able to run a tower as a center.
post #4825 of 6059
To answer ntrain & romeo:
I called AC4L for the missing the plugs & wall mounts & I received a package from Kef in 2 days with the parts. I think I spoke to Mark & when I conveyed my problem, all he said was "No problem, I will send kef an email & it will taken care of". Took 2 mins of my time.
As for the products being new, before ordering I called to ask that they mean by "open box" & the lady put me on hold to check stock. She came back stating that the they are all new & they state open box so that they can advertise a cheaper price than MSRP. When the boxes arrived they were factory sealed, you know those huge staples that are on some of these boxes? I think they were there, dont have any box with my anymore to double check.
I am not sure what to think of the Q600, perhaps I approached it the wrong way or I truly do have a defective speaker. I have set Xover to 60 as of now & while watching movies I think its doing its job. Perhaps it is what it is. My complain hasn't just been of lack of bass but overall lack of clarity when running it in Pure Direct mode. I will spend more time with it & see how it goes.
post #4826 of 6059
I just my new Q900 and Q600 on Saturday and calibrated them last night with ARC. The Q900 and Q600 were set at 60hz for both.
post #4827 of 6059
..............but overall lack of clarity when running it in Pure Direct mode.
Your center channel speaker isn't used in Pure Direct mode.
post #4828 of 6059
Yep, I was about to say the same thing. Pure direct mode is 2 channel only. At least it is with Onkyo products and some other select mfg's.........
post #4829 of 6059
Not a fan of ARC or any auto calibration tool.........regardless 60hz is too low for the Q600 unless you your volume is set really low. 80hz-120hz is normally the best cutoff point for speakers that feature 5 or 6" drivers. At 60hz your going to start introducing intermodulation, especially at higher volumes.
post #4830 of 6059
I think I can do it in my Yamaha RX-A1000. I will double check tonight unless I have been in some audio illusion all this while.
@sivadselim & ntrain96 can you provide guys provide some feedback on the center placement based on the pic I provided the previous page? Would like to get the most out of my center.
  Back to Forum: Speakers
