Originally Posted by
ntrain96
A. The problem is the dominant signal is equally shared between both drivers around 4-500hz..........and in the case of the 201/2 that means at 1khz its still only 12db down, enough to potentially pull and smear the dispersion pattern.
Lots of use of hedge words like "potentially" that show you don't actually have a point, and you know it.
ntrain96
***You can believe whatever you want, but Kef has lost alot of major retailers/resellers in the past decade. And if Kef closes shop within the next 4-5 years, you can look back on this thread.
There are no more chains like HiFi Buys or Tweeter or Brynmar carrying Kef products, and thats just here in the US alone.
I can't speak to the others, HiFi Buys (pre Tweeter) never carried KEF anyway. Their main lines around here were API (Mirage/Energy), Martin-Logan, Monitor Audio, and Klipsch.
And post-Tweeter buyout, at least their stores in the SE US never carried KEF, except for the eggs.
ntrain96
D. So no 3, 4,5, or 6" driver can play down to 120hz without thermal compression?
No, they can't. Not on their own, at least. (If used in a line array or something, that's different.)
They can't at the SPL required to accurately reproduce large-scale live unamplified music such as a Mahler or Shostakovich symphony, at least. At background levels, they're fine.
ntrain96
Just curious..........having owned a Q100......what did you have that crossed over at?
First, as I clearly indicated in my preceding post,
own not
owned. (The plain meaning of the phase "currently in use" is sufficiently clear to an observant reader.)
I use my Q100's in the bedroom for background music. They have ports plugged and no high-pass. The sub's filter is I think around 100Hz indicated. The integrated that powers them right now, a Meridian 551, doesn't have bass management or preout/main-in loops. And the system is for background listening, and only includes one sub, so I get overall better low-volume response by letting the mains roll off naturally. Yes, they completely fall apart if I ask them to reproduce Shostakovich 10 at 7th-row-center-in-the-Berliner-Philharmonie levels. I've tried it so I know. But, again, they're in a background music system so that doesn't happen
They're fine, spectacular even, in that role. But would I use them in my reference system? No. I think its 5" Uni-Q is very, very good, though, and maybe that Uni-Q with that driver and 10" woofer that can play up to 500Hz cleanly, with a well-engineered crossover, would be a very good loudspeaker.
ntrain96
Also, just curious....the 201/2.....what size bass dirver does it use? 6" right? LOL! .........Dude you have no clue what your talking about now.....
Actually, if you actually read and understand what you were reading, you would see no inconsistency. In my
blog post on the 201/2 I wrote the following pair of sentences:
"One does notice their inefficiency, when one compares them directly to similarly excellent but more efficient speakers, in the form of lower-midrange compression on fff massed strings and other such loud sustained passages. But for their size they strike a pretty reasonable balance of efficiency and extension."
That is exactly what I'm saying here.
An assertion unsupported by measurements, and thus pointless. One can usually tell the good speakers Soundstage reviews from the clunkers with massively overblown claims because the good speakers are submitted the NRC for testing, and the dross is not. (Furthermore, having heard a Feastrex driver, let's just say I understand why it wasn't submitted for real testing...)
ntrain96
E. An R100 uses basically the same UniQ driver as the blade........and you think a tiny monitor like the R100 is going to have diffraction issues....vs the large Blade?
Yes.
The reason the R100 is inferior in diffraction to the Blade is that the R100 has sharp discontinuities, whereas the Blade (except on the top) is all smooth, gradual curves.
ntrain96
Got any proof to back that up? LOL! And you think an R100 pair with a quality pair of subs is going to have compression issues before the blade?
Yes.
Unless one crosses the the subs very high up, like in the 500Hz range. And then one probably won't want to use down-firing subs, because the cavity resonance (from the cavity between the bottom of the cabinet and the floor) will fall within the passband.
