Originally Posted by
ntrain96
A. My terms are generalized obviously and not just geared towards the 201/2, but regardless a "bass driver" that plays flat to around 500hz and is only 12db down is going to play a much bigger factor on defining a true point source.
Please stop talking about things you don't understand.
IF you want to show that something like a Ref 201/2 doesn't act as a quote true point source, unquote.
Prove it. Show
horizontal and vertical polar maps demonstrating its behavior. Anything less is just someone with just enough knowledge to get things consistently wrong relieving himself against the wind.
ntrain96
B. Sure they can, a smaller driver is more than capable of playing low frequencies CLEANLY at at loud levels.....it all depends on the cabinet type and tuning.
Nope.
Besides, to properly integrate with subwoofers mains should really be
sealed. It's easier to blend 2d order rolloffs than higher-order rolloffs. So performance in a closed box is all one should really consider.
ntrain96
C. Do you know where your Q100's roll off at and at what slope being "semi sealed"?
Yes. Unlike you, I have modern measurement tools, not just some cutting-edge-ca.-1985 RTA.
ntrain96
DO you realize you make such a big deal about "diffraction" yet I bet you have no idea how minor if an issue it really is. There are lots flat faced speakers that dont have any issues with diffraction. BUt yet you seem obsessed with this particular point.
Yes, because I can hear.
I've also had the chance to
directly compare the
same drive-unit in a fairly diffractive cabinet. Here's the factory Tannoy System 12 DMT II.
Note the ridges on the baffle, the minimal roundovers, the ports, and the protruding logo.
And those drive units in cabinets I personally designed using best practices to reduce diffraction, with the same baffle dimensions as the factory speaker so they could be compared using the same crossover.
Note the very large roundovers (for size reference, the Dual Concentric driver is 12"), continuous curves, and complete lack of disruptive surfaces on the baffle.
The difference is indeed measurable, but not very stark. The difference in listening fatigue over long listening sessions is marked. And consistent with the literature on diffraction perception.
You probably don't have the experience, or skill set, to make that comparison.
ntrain96
There are alot of high end full range drivers out on the market now. Lowther, Mark Audio,FOstex Feastrex etc:
Those are all very low-fidelity drivers. Seriously, mentioning KEF and Lowther or Feastrex in the same breath just marks one as fundamentally unserious.
(And yes, those Feastrex drivers are just about the opposite of high-fidelity. I have heard them. Awful, awful, awful. Though your expression of fondness for them explains an awful lot about your posts. In the no-crossover, backloaded horn designs favored by "full range" fetishists, they have shouty midrange, uneven treble on axis that disappears completely off axis, little upper bass, midbass like a cheap car system, and no deep bass. A tiny little KEF HTS1005 egg is a higher-fidelity reproducer than any of those horror shows.)
ntrain96
But it takes a very high quality driver and careful design of the enclosure to accomplish true full range sound. Kef's UniQ pointsource monitors get somewhat close in the sound for cheap money using their inexpensive UniQ drivers.
A well-engineered loudspeaker as KEF typically sells sounds
nothing like one of those "full range" monstrosities!
