Originally Posted by sdg4vfx
I just noticed something about the R series ... none of them use the 6.25" Uni-Q, they all use a 5" Uni-Q. The one exception is the R100 which uses a 5.25" Uni-Q, same as the LS-50. Wonder if this is related?
Originally Posted by DS-21
Having recently heard the Q300 (and compared them to the Q100), the 5.25" Uni-Q is a higher fidelity device than the 6.5" Uni-Q through the midrange. I suspect they have the same tweeter and the same crossover frequency, because the 5.25" sounds much more together to me ...
I'm not sure there's much difference between 5" and 5.25". I wonder if the baskets are different.
However, note that a 6.5" concentric with a bigger/stouter tweeter wouldn't have the same problem. That's why the Q900 doesn't have the same midrange mushroom cloud pattern. (See Stereophile's measurements.) It has a much stouter tweeter, and crosses it lower. KEF can and has in the past done the same with a 6.5" concentric. See, e.g., polar measurements of the Ref 201/2, or the old Andrew Jones-era Ref Four. Stereophile has measured both. Likewise, my old 12" Tannoy Dual Concentrics didn't have the problem. The reason was that the tweeter was a compression-loaded unit that played down to ~1.4kHz. (Also, the pattern was narrower than on a modern Uni-Q, which means the woofer could play up higher before the tweeter needed to come in to match the woofer's pattern.)
This particular 6.5" concentric (the Q300/Q700 driver) uses what might be the same tweet as the smaller one, and a crossover point too high to allow a directivity match. So the tweeter has a broader pattern at the base of its passband than the woofer, what I call a "midrange mushroom cloud" pattern.
Note that I've not measured the Q300's polar reponse, but in listening to them I clearly heard the, "hi-fi" tells of speakers with midrange pattern discontinuities. The Q100 and Q900 do not. Perhaps smart marketing by KEF, because the Q300's do sound more like standard 7" 2-ways from lesser makers than they sound like KEF's best stuff.)
Edited by DS-21 - 11/19/12 at 6:17am
