Originally Posted by JAMMAN
So after calibrating and watching DVDs, SD and HD, I've decided to return the pearl. The picture was very good but my main concern was how dim it was in my room. I had to really try to block external light (reiminded me of my w400 days) and realized that this projector is for a competely dark room. So I'm going to get a new lamp for the HS10 and sit it out for a while for a brighter projector. I guess I've grown used to the brightness of the HS10 and can over look some of its imperfections until something comes along that really suits my application.
Judging from the pics of your HS10, it is about as far away from properly calibrated as one can possibly get.
If you are willing to live with a bit of "Torch Mode" on the Pearl, and willing to crank open the IRIS, I would bet you could get it substantially brighter.
There are at least a couple of hundred more lumens at your disposal.
However, if you're watching in a room with ambient light, I think you'll want a light canon. And clearly, this projector does not fit that bill.
