I just bought a 2nd hand IN72.
The lamp hours is 70 and total lamp hour is 70 also. But the lamp reset counter is 3.
Does it mean that the seller might use it for more than the total lamp hour indicated and then reset it again and again so it will reach lower hour ?
Will resetting the lamp hour make all lamp hour count reach to zero again ?
Is there a limit on how many time we can reset the lamp ?
Thanks for any help.
I use 4805 for 4 years and never try to hit this reset for lower lamp hour.
what do you mean by work your way up from 848x480 ? I thought you would set it and forget it just as with the D1.
