Originally Posted by
Martin Butler
Different strokes for different folks there Mupi
No sarcasm intended . That "D65, grey scale dealership crap" might prove interesting and informative to many beginners, so why suggest limiting the input here? I'm no pro when it comes to projectors and I for one really appreciate it when the pros drop by our humble little threads and drop some science on us. I know of no other forum where the actual designer of a product (Bob Williams/InFocus) participates. So let's all just enjoy ourselves and help each other get the most from our hobby, eh?
No answer yet on the sync question from standard def to high def? What's the most current firmware? Thanks.
Hi Martin, visited your website and enjoyed your music.
2.8 is the latest firmware, here's the history:
Play Big IN72 Firmware Revision History
Version Date Notes/Enhancements
v2.8 26-Oct-2006 · System lockup on boot-up when only first item in Source Enable menu (HDMI) is enabled (all others disabled). · Offset the menu from the top and left edges by a few pixels (5% of native horizontal resolution).
v2.7 18-Jul-2006 · For manufacturing reasons only
v2.6 23-June-2006 · Improved fan control and audible noise · Keystoning improved in ceiling mode · Resolved image shift with 480i/576i signals · Resolved compatiblity issues with Panasonic DVD-297 DVD player with HDMI. · Splash screen expanded to fill 16:9 space. · Fixed issue where the projector would stop sub-source searching on the M1-DA connector if all sources except M1-DA are disabled. · Fixed a hue shift issue with some 1080p component sources. · Computer does not go into Power Save mode while upgrading software.
v2.5 14-April-2006 · Improvements to video syncing table · HDMI video codes corrected (1-34) · Fixed interlaced computer sources image shift. · Fixed no image issue after 4 hour sleep mode was initialized. · Added M1 and HDMI in HDMI DDC option. · Fixed lockup issues when disabling all "source enables" except for one, then power cycling unit. · Corrected hue shift in the black levels for component video inputs. · Removed fan speed increase during power down. · Fixed vertical position jump, when aspect ratio is set to crop top and bottom of the image.
v2.2 N/A · Initial release
sgibson
