Originally Posted by jrh203
I just got my SR804 yesterday. I decided to return the SR674 to see if I would notice a difference. In my limited knowledge, it definately seems to be worth the extra $100 or so that I could find them each for.
Unfortunately that brings me to the humming issue at higher volumes. Just as 1953 has stated in his post. While pausing a source, the hum becomes evident at around -20db on my HD-A2 and around -30db on my Motorola 6412. Both connected via HDMI. Unfortunately, those are the only numbers I have to reference the sound level.
I just wanted to thank you 1953 for taking this issue head on with Onkyo. I may simply return it, and opt for separates. I will continue to monitor this situation though as I look forward to hearing a resolution.
Thanks for the kind words. I'm sorry to say that as it stands there will not be a solution.
LP
