So I've been an avid Replayer for the past four years. I've had four replays working off directv sat receivers and haven't been happier.
That is, until I got a new HDTV and went for the directv HD. First off, HD from directv isn't bad at all. I get my locals in HD and am trying out the HD pack, which has around ten HD channels. TNT broadcasts a lot of good sci-fi reruns in HD (X-Files, Alias) and HDNet shows a variety of movies in HD. The HD looks BEAUTIFUL and I'm glad I got it.
I was lucky enough to get the new HR20 directv hd recorder. It's a dual tuner direct bitstream recorder that does the new MPEG-4 content. It's no replay, in any aspect, but it does work. Setting up recordings is a bit, uh, sketchy. You can hit record once in the guide to record one show or hit record twice to do a "series link". The series link works of a cron job that runs in the background and updates throughout the day -- this means that you can set up a series link and it won't schedule those recordings right away, which is kinda weird. There have been mixed results posted in the directv community on how the series link actually works. I've tried it with a couple of X-Files episodes, but haven't had a chance to do a "weekly" show yet.
It takes a LOT of button presses to get stuff done (e.g. you always have to hit the guide button twice to bring up the live tv guide). The recorded guide also takes two button presses to bring up (unless you get a new remote and program in the "list" command). The recorded guide is called "My VOD" and is horribly organized. Again, it's no replay. The shows are jumbled together into one large block and then multiple shows of the same name are in "folders" in that list.
Show navigation is done using FF and REV (1x, 2x, and 3x), skip back (a few seconds backwards -- not always the same amount of time) and "30 second slip" which fast forwards 30 seconds. There is no "slip back" like you find on TiVo (where you fast forward and if you hit play it goes back a couple of seconds).
There is no networking with the HR20, and we've been told not to expect multi-room viewing any time soon. There is, however, an ethernet port built into the unit.
Overall I'm happy with it, but it's no replay. I've decided to keep two of my replays to record all the SD content (one of the replays is connected to my H20 HD receiver set to 4:3 mode thanks to DOSman's USB to serial link). My roommate keeps commenting on how it doesn't skip commercials. I literally haven't seen more than a glimpse of a commercial in the past four years, so it's taking some getting used to.
I'd definitely recommend the HR20 and directv's HD service is great. Supposedly they are going to launch a large number of HD channels in the beginning of 07. De-commisioning my replays is a sad thing, but brining up a dual tuner HD recorder makes me forget my sadness.
