AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Recommendation for Chrysler 300C
post #1 of 4
I am leaving for Iraq next month and upon my return I will be getting the new Chrysler 300C. I have a current sound system with my Mitsubishi Eclipse GT. The difference with the cars is I currently have a hatchback vs a trunk on the new 07.
I only have experience iwth the hatchback with it the Eclispe being my first car with a aftermarket sound system.
Anyone with any experience with the 300C as far as speaker size and Amps. I have always used Rockford Fosgate for both amps and speakers for the Eclipse. I am trying to see what others are using in the 300C.
PJ2
post #2 of 4
The car generally doesn't really matter, if you like RF, you should be able to stick with them... Your best bet to see what fits your car is to use Crutchfield's car configurator thing...
post #3 of 4
I will check that out thanks. The experience I have had has only been in a hatchback compared to a trunk.
post #4 of 4
I've rented the 300s many times and I think you'll be surprised by what is hidden beneath the speaker covers. I think the front door panels might be able to hold a component system with 8" woofers and a midrange. The car has some definite possibilities but might require a bit of custom work.
  Back to Forum: Car Audio, Video, and Nav
This thread is locked
