AVS › AVS Forum › Display Devices › CRT Projectors › Ok Folks! Show me your dots!
Ok Folks! Show me your dots! - Page 3
post #61 of 283
I think your problem still lies in the optics. It really looks like light scatter, not just focus.
Since you replaced the green c-element and it's clearly the color that has the least problems I put my money on that layer of white microscopic crud I spoke of before. On the tube face you will only see it when looking at an angle with it all dried off after the c-element is out. You will notice the tiniest layer of white like phosphor grain but smaller except it'll be on the wrong side of the glass to be phosphor. Remove the blue c-element and carefully inspect the backside for the same microscopic white stuff. Wash ut with soap and water and be sure not to scratch it at all. Then when it's dry inspect it out in sunlight. If it's anything other than crystal clear and perfectly scratch free it'll cause your symptoms.
If it's not that, and your Lc fluid is good quality clean stuff, then maybe swap the blue and green lenses and see if the light scatter is in the lens. Did you clean and inspect them as well?
Troy
post #62 of 283
Yep, that's my tube face imploded. I fell asleep watching a baseball game. When I woke up, the PJ was off. When I tried to re-start it, I got a "HIGH BEAM CURRENT" error message. Right now I have my3600HD set up below it on a table. That 3600 smokes but I miss my contrast ratio that you can only get with a LC.
Chip
post #63 of 283
What do you think caused that chip? LC fluid pressure/no air bubble? I can only imagine the pain and disgust you must have felt when you saw it was the tube.
Troy
post #64 of 283
Rajiv-
I'd be happy to post some screenshots for you, but I need to redo my set-up first. I've just gotten my Moome card working with my HD-A1 and I just received my 15' HDMI to DVI cable today. So perhaps this weekend I'll redo the set-up YET AGAIN and see how nice I can (or can't) make it. By the way, this is on my G70. A few weeks ago I redid my setup using Brian Hampton's modified Guy Kuo focus document. After that the G70 looked better than I had ever seen it. But now with the DVI input I had to redo the convergence. I did that rather quickly and it begs for a full set-up... again :)
Also worth noting, I definitely noticed increased sharpness when I switched to the Moome DVI input. The difference was not subtle.
Also worth noting, I haven't given up on my Ampro 4600. It's got near mint tubes in it now and I'm waiting for HD-10L lenses from Curt. At that point I will have to make time to give that projector a serious try. Then maybe I'll finally decide to sell one or the other. Oh, and I have the Moome external DVI box to use with the Ampro. I'm all set up now... twice :)
Good luck with your set-up tonight.
-Mark
post #65 of 283
Really sorry to hear about that Chip.
I always thought the rubber bladder under the fill plate would provide some protection. When I first got my 4200 about 5 years ago. I loosened the plates on all three tubes and there was zero fluid pressure at that time. About a year ago I decided to change the discolored fluid.
I was shocked about how much fluid squirted out from under the plates when I loosened the screws a second time 4 years later. There was definitely a lot of pressure there. Maybe I was lucky I did it when I did.
Ray
post #66 of 283
I really wish I had an answer. The fluid was changed in all three tubes just after I bought it as I wanted to install the colored c-elements that I had. That was about two and a half years ago. The projector has been set up with no changes since then. Rasters were set to 1/4 inch to the closest point of the tube edge. For the time being I will use my 3600 while I look for a decent used green. I want to make sure something didn't go haywire and shift the image onto the tube edge or something before I spring for a new replacement tube. I will fix this as I love my 4600HD. No one but jtnfoley believes me but I prefere my projector over a modded 9500LC. He has seen mine and came with me to look at a modded 9500LC. We both came to the conclusion that to buy one would not be a up-grade over what I have.
Chip
post #67 of 283
Some pics from my 2000. 7" ES focus/air coupled projector. Thing is, it has the same CRT cards and RGB board as the model 4200. The tubes don't have the resolution of the 9" mag focus set but it does 1024 x 768 @ 70 Hz pretty well. That is a pixel clock of about 100MHz. 1080i has a pixel clock about 80MHz and the pixel clock at 720p is about 72MHz. 1080p is about 160MHz.
The 4200 should give good performance at 720p and 1080i.
Screen shot of off air HDTV at 1080i. The actual image looks better than the camera pic. My wall isn't a perfect white screen, either. I ought to fix that.
Scott
post #68 of 283
Scott,
A lot of interest has been generated with Wilsonart Designer White. You can get a 5x10 piece for less than $100.
Ericglo
post #69 of 283
Turn down your contrast way low and see if the image sharpens up. Electronic focus becomes a moot point at miniscule contrasts. If you still cannot resolve alternating lines with very low contrast at 1080P, then you must have an optical problem.
You aren't getting scan lines at 720P, you are resolving alternate lines, and fairly poorly at that. I don't know how the 4200 performs, but my marquee 9000 resolves alternating lines fairly well at 1920x1440@60.
post #70 of 283
post #71 of 283
Hi,
I pulled a PG extra in front of the screen to do a screenshot of the rez pattern with my HTPC, so this was not exactly a dedicated setup, but I use no HTPC anymore with my main pj so this is the most I was wiling to do.
Here is what I came up with, the Ampro on the right.
The camera always gave me a warning saying the picture was not properly focused, but it still looks better than the 4200, both pics taken at 1080p 60.
Oliver
post #72 of 283
OK,
here is another one comparing letters on the desktop when doing a right mouse click.
post #73 of 283
If your PC monitor is set anything like mine you will need to turn the brightness up to ~50% to see Kai's dots ;)
post #74 of 283
Ok guys, I spent a long time yesterday night (actually from 11 PM to 4 AM!! :eek: ) tweaking the PJ. I did the astig and focus magnet alignment again. I also did the convergence all over again.
I used a new method for astig. I used a camera and monitor setup. This gave me extreme accuracy. I cant even start to describe how much easier and accurate this method was over the "do it by eye" method. Here is a picture of my setup:
http://funkyhuman.com/hosted_images/IMG_5099.JPG
I nulled everything and concentrated on getting the focus exactly right with the electronic focus controls at 50. I succeeded to do so for green and to some extent for red. The blue still has to be pushed to 75 or so to get best focus.
Now the focus is so sharp, it is not funny!
But here is the problem: The focus is extremely sharp when seen on the tube face. On the screen.... it is still a little soft. There is surely a huge improvement but it is still not what I feel it should be.
I also run out of convergence range.
It is slowly dawning onto me that these HD10 lenses are not for this small a screen. This surely is pointed out by the lack of convergence range. Especially on dynamic Horizontal Width and Linearity.
When I had the PJ on the floor I was able to keep it much farther back from the screen. I remember I did not have this problem and the image was sharper.
Anyway, here is the result of that night out with the PJ :o :
(all images are at 1280 x 720P @60 Hz from a HTPC)
http://funkyhuman.com/hosted_images/IMG_5095.JPG
I also found out that YES, earlier it was blooming. Hence those really bad desktop screenshots.
It still blooms and the desktop picture goes haywire. The above pic was taken with the brightness/contrast at 40/63
Strangely, the DVDs are extremely dark and I have to run something line 80/85 and still not bloom!
Here is the green now:
http://funkyhuman.com/hosted_images/IMG_5104.JPG
Here is the blue now:
http://funkyhuman.com/hosted_images/IMG_5102.JPG
Here is the red now:
http://funkyhuman.com/hosted_images/IMG_5103.JPG
I also tried to show the dot size but it is rather difficult. Here is a try.
http://funkyhuman.com/hosted_images/IMG_5106.JPG
Notice how round the dot is and the size is pretty small too. Notice the white ballpoint pen I help to the screen. It is seen in the vertical green line to the right of the dot. (very difficult to make out)
post #75 of 283
Originally Posted by Oliver Klohs
Rajiv,
your green 720p picture shows scanlines, the 1080p screenshot does not.
So I do not understand why you ask about scanlines at 1080p ?
It seems that your 4200 is quite a bit bandwidth limited, even at 720p not all the vertical lines in the upper left box are visible.
You desktop looking so bad might get better with lower contrast, maybe detail is blurred due to blooming - you should try that.
Still I think you should be able to do better with that projector, how far from that 76" screen did you hang that projector ?
Oliver
Hey Oliver,
check out the new desktop pic! MUCH better and surely it is blooming. That pic is taken with much lower contrast.
As promised, I measured the distance. It is around 117 inches from the screen. Still the screen is not filled out. The raster has around 5 to 10 mm on each side (unused). With that here is what the screen looks like with 1280 x 720p:
http://funkyhuman.com/hosted_images/IMG_5107.JPG
I want to pull the PJ back a little but I am running out of space on the brackets on the ceiling:
http://funkyhuman.com/hosted_images/IMG_5108.JPG
post #76 of 283
OK guys,
Here are some more screenshots. Tell me if they are any good.
Please concentrate on the center of the picture:
( I know the convergence in the corners is still off, I simply can’t achieve any better it with this mechanical setup since I run out of range.)
Here is one which may be compared with the one posted by Scott.
Just that this shot is 720p from my cable box. (via Moome of course)
http://funkyhuman.com/hosted_images/IMG_5116.JPG
here is the Link to the original non-resized image
Detailed headshot:
http://funkyhuman.com/hosted_images/IMG_5117.JPG
More images (taken from the DVR, “Jeremy Pivins’ Journey to Indiaâ€)
http://funkyhuman.com/hosted_images/IMG_5111.JPG
http://funkyhuman.com/hosted_images/IMG_5112.JPG
Here is a graphic from something on Discovery HD. This is 1080i:
http://funkyhuman.com/hosted_images/IMG_5109.JPG
Now here is something a little more familiar. Here is one shot from House from my DVR. Don’t we all love Dr. Cameron ;) (She does not look good with the new hairdo :( )
http://funkyhuman.com/hosted_images/IMG_5114.JPG
Same shot just the camera was kept closer and zoomed in.
http://funkyhuman.com/hosted_images/IMG_5115.JPG
I tried to show the details but the camera was not able to capture everything :mad: (it wont auto-focus) I manually focused it, but you know how good is manual on a point-and-shoot digicam.
I REALLY need a digi-SLR!
Oh By the way, I LOVE the saturated colors of this PJ. Sure it is a little red ( I changed the clear red C-element to the red one from VDC) but still the blues and whites do not have any red tinge.
Of course, all these pics look better in person.
post #77 of 283
Originally Posted by stefuel
I'd like to show you how tight the dots are on my 4600HD but.....I think I'm having a problem with my green tube ;)
WOW Chip. That looks nasty!
Were you woken up by the dripping glycol?
Do you have HD10L on it?
post #78 of 283
Rajiv, that looks HEAPS better.
And you should have no trouble finding someone to swap HD-10L's for HD-10's, most people want the opposite.
Mark
post #79 of 283
Originally Posted by Person99
By your pics, 720p is pushing it and at the edge. I'd be curious to see if it can't handle the 1920 or 1920x1080i. Did you try this pattern on 1080i?
Dave
Dave,
Although it is 3 AM in the morning, :eek: :eek: :eek: .... I just had the take a screenshot of 1080i before I went to bed.
So here is it:
http://funkyhuman.com/hosted_images/IMG_5118.JPG
Not too bad, eh? Pretty soft!
Good night!
post #80 of 283
Mark
Actually Mark, I really dont want to swap. I still want to keep the 10s so in case I move to a bigger room I can use the 10s.
Now just where can I get the 10Ls :rolleyes:
post #81 of 283
Rajiv,
117" form the screen is not a problem with the HD10 lenses I have used. I would not expect the HD10L to look much better at that distance, if at all.
For your sake I hope I am wrong, but don't expect miracles.
720p is definitely improved, good work ! And a very impressive and professional looking setup I might add. 1080p is where it is at though in the 9" class, you should work on that resolution and optimize your setup for it. In case this proves too difficult I would optimize for 1080i, you will get better results with HD movies when using that.
You have a cool looking RGBHV cable - are those Belden 1694 ?
Oliver
post #82 of 283
Yes I have 10L's on mine and have (had) no problems with those test patterns. This is what I want you to do. Put that test pattern back up that is soft on the screen and look through the lens and see if it's sharper on the tube face. Look through the lens at those two top boxes and see if you can see the lines.
I have a thread from about three years ago about a 4000G with focus problems. Everone insisted that I had soft tubes. I was trying to project onto a small screen (72" diag) with straight HD 10's and could not see scan lines on screen at 600X800. I could look through the lens and clearly see scan lines on the tube face. Being quite sure that I was correct and everyone else was not, I packed up the PJ and took it somewhere big enough that I could experiment with much larger screen size. I set the lens adjustments to exact mid point. With the PJ on a cart, I moved it till I had the best center focus (green only) without touching the lenses. Yo know what I ended up with? Big honkin, ultra sharp scan lines on a 140 inch screen. At that location I was able to pump up the rez to 960P and on a 4:3 screen was able to project scan lines (from a 4000G ES focus). You can chose to or not to take my word on it but I saw it with my own two eyes and that's good enough for me.
Later there was a thread about the ability of doing 1080P on a 8" EM focus set. This thread cought my interest and sent me out to the shop where I have a 3600HD. I set it up on a 100" 4:3 screen @1080P and spent about 3 hours messaging the green astig, electronc focus and mechanical focus. so that at 4:3 the scan lines were clearly visible. I then began to squeeze the image to the point where scan lines vanished which was exactly at the 16:9 ratio. Fully knowing that no one would believe it, I asked jtnfoley to come over and see it. I gave him the tape measure and asked him to make the call as I squeezed the image. We went back and forth at least six times till he was satisfied that we were at the point where the lines touched. He measured the screen to a 16:9 ratio. If he reads this, I'm sure he'll varify.
Get some 10L's and try again.
Chip
post #83 of 283
Rajiv,
I thought again about the lens issue and I remembered a Sony 1292 I had with all crappy HD10 lenses that got much better when I installed some HD10f for it.
So maybe you should really try and sort out the lens issue, maybe you even need the 10L, even at that quite long throw distance. Of course it still would be good to know if the current lenses are really better at longer throw distances - would you be able to check that ?
If they are you know what to shoot for in your current setup, if they aren't the lenses just might be no good at any distance but from what you say you got a better pic at a longer throw - right ?
Regarding looking on the tubes you could try that also but it seems that your Ampro is very sensitive to higher contrasts so you'd have to compare your screen with a very low contrast setting and look into the tube at the same setting, that would be a useful comparison.
And: Maybe a stupid question , but are you sure you got the Scheimpflug all dialed in ?
@Chip: 72" diagonal has to be about the smallest I ever heard from a 9" CRT setup, Rajiv has 76" across, which would come to about 92" diagonal I think. I agree that you have been had when nobody recommended the HD10L to you, this is the lens for the job.
post #84 of 283
Rajiv,
This camera setup looks pretty useful. I'll be doing the astig on my PJ sometime soon. How have u done this? USB camera connected to a laptop and adjusted the astig while viewing the image on the laptop?
post #85 of 283
Nice dots!
Thanks for posting.
With the tweaking even my dots are similar now.
Originally Posted by kschmit2
My dots:
6PG plus at 1920x1080i95.904
My camera sucks in low light conditions, but the dots were captured nicely.
post #86 of 283
Rajiv,
Yes, I too wonder about that, the focus knobs are NOT on a corner. There are pretty near the center. But I am going to give it a try anyway.
“professional looking setup†What do you mean? :confused: Are you referring to the room?
If so, thanks, :D we just painted it and it is still not complete. The Rope light is still visible because I still need to install the “lip†molding. I still need to make a stand for that front center speaker. Right now it is just sitting on the sub.
Oliver
I am suspecting maybe the switcher is the culprit. I think I have tested taking it out of the chain but it did not make a difference. But was that test at 1080p…I don’t remember. Gotta do it again.
Also, maybe the VGA card may be the problem too. It is a nVidia MX440 with 64 MB RAM. I think it is not very good.
Oliver
Yes it is !
I got it from bluejeanscable.com. Nice people there!
post #87 of 283
Your projector looks like it's set-up alot better! You are right to suspect your video equipment for bandwidth, noise, and other undesirable stuff. Sometimes that is part of the problem.
Scott
post #88 of 283
Sure Chip, I will do that tonight.
No no…. I believe you. :)
I am looking for HD10L lenses now. You won’t be selling yours would you?
BTW, do you have a link to that thread ?
post #89 of 283
It is probably not of any help to you, but even my 8" non-LC Barco Graphics 1208s/2 (with PT18-205 tubes) is much, much sharper at 1080i. You really should look for other lenses because I simply cannot believe (from the screenshots) that you have a 9" LC projector...
post #90 of 283
Rajiv,
Oliver,
I used to think that HD10 lenses are good. :confused:
I know that the HD10GT17/26 versions have more resolution. 12 lp/mm instead of 10 lp/mm of the plain vanilla version (HD10)
What does the HD10F version do?
I am pretty sure I got a better picture when I had the PJ on the floor and much farther back in the room. :)
Yes, I want to do that tonight. :)
Yes, I did the Scheimpflug , but not 100% . I :( was close, maybe only 80% of what could be achieved. I was just concentrating on getting the screen center dialed in first. Only when that was perfect, I was planning to do the corners.
Actually, in the past, some people have recommended me the HD10L. I just wasn’t sure. But I am sure about one thing here.
Due to the lack of convergence range (especially in the width and the corners) I am pretty sure that this image is way too small for these lenses.
I DID NOT have the “lack of range†issue when I had the PJ on the floor and had it much further back in the room.
So this points out that I surely need HD10L lenses, if not for the clarity but surely for the convergence.
Looking looking !
  Back to Forum: CRT Projectors
This thread is locked
