Once upon a time.....
I was very interested in HT since the first Dolby ProLogic amplifiers came on the market and enabled private people to have the surround experience in their homes! My amplifier was one of the first ProLogic Yamaha devices available in Europe and I watched movies on my small TV set fed from a VHS player with a crappy and cheap 3/2 speaker setup, but I was impressed!
At the time when the first DVD's came available in Europe (around 1999) I upgraded my sound system and bought the best gear I could get for my budget these days - Sony DVP-S7700 DVD player, Yamaha DSP-A1 amplifier and Magnat Vintage 7 Series speakers for a decent 5.1 DD/DTS setup...WOW what a difference!
About the same time I always wanted to add a video projector to my system, but I could never afford to pay these crazy prices the charged back then - so I decided to build my own LCD projector. After more than 2 years of design and development I finally had this unit working with a quality I could enjoy watching movies with it.
So in 2001 my first complete HT was installed in my living room with a DIY 250cm (98) diagonal screen, self developed VGA 3 panel LCD projector, HT-PC running dTV (now called DScaler) and my Yamaha / Magnat audio setup.
In 2002 we planned and built our own house and of course a dedicated HT in the basement was part of it. In September 2002 we moved in, but there was of course no time or money left for the cinema - so it ended up as a storage room. Although I installed my audio system in our new living room, the projector and screen was kept stored in the basement.
In December 2002 the second part of LOTR came to the cinemas and I planned to invite some friends at my house to watch the first part before going to see the second in cinema. Well, the sound was good enough in my living room, but watching LOTR on a 70cm (27) TV set sitting 4m (157) away from it? NO WAY!
So I grabbed my screen and installed it temporary above my TV in the living room, but there was another problem - my self-made projector was fine, but without a hush box way to loud, only VGA and just for this evening a did not want to install it together with my hush box to the ceiling of my living room..but my wife had the solution.she bought me a used Sony VPL-PX 20 projector for Christmas and it arrived just in time 2 days before my planned LOTR session with my friends - saved!
Now guess what.the temporary solution in my living room is still in place, and we have enjoyed it during the past 4 years.
In the meanwhile I have colour corrected and contrast optimized the Sony projector (and it rocks now!), upgraded the HT-PC with new hardware and software, collected and watched over 500 DVD's and had many good ideas for my dedicated HT.
Enough from old stories and let's jump to the Zinema!
As I already mentioned the cinema is located in the basement of our house. The room is 4,5m (177) wide, 4,88m (192) long and 2,32m (91) high - with an extra equipment room in the back. The walls are 30cm (12) thick and made of solid concrete. Also the ceiling and floor is solid concrete. There is no window in there and 2 doors to enter the cinema (plans will follow later). Some might say the dimensions of the room are not ideal, but this was the maximum size I could do and I believe it will be just fine!
As you can image my problem is not to keep the sound inside the room, but to reduce the reflections and reverb time.
For the screen I decided to go for a 2.37:1 constant height setup where the screen is 332 cm (130) wide and 140 cm (55) high with vertical masking for smaller AR.
And YES - I like it LARGE!
There will be 2 rows of seats, the last row on a 30 cm (12) riser providing enough space for 6 people to sit comfortable. The 7.1 speaker setup will be placed behind framed walls - so not a single speaker will be visible. Carpet floor, soffit around the ceiling corners with lights installed. Acoustic treatment on the walls and everything covered with fabric.
Almost everything in this project will be DIY - here is a short list of planned things I will build:
In the first phase I will use the Yamaha DSP-A1 and only a 5.1 setup together with my Sony VPL-PX 20. Later I will upgrade to a Pre-Amplifier + four 2-channel amps and a native 16:9 projector but this would blow my budget right now.
The planning of the room is done, the speakers are designed and computer simulated for optimal performance. The room acoustics are also simulated including the planned sound treatment but since computer simulations are never 100% accurate I will have to test it during the construction to check if I am going in the right direction - but it will be a good starting point.
Tomorrow I will post some of the acoustic simulation results and some very primitive 3D renders (coming from the sound simulation) of the room - so you will get a better impression how it will look like.
I hope to get some feedback of the community here since I am following this forum now for some years and I have to say this site is the best source of information I have found so far!
Let the construction begin
- 332cm x 140cm (maybe curved) screen with electric vertical masking
- 2 main, 1 centre, 2 side surround and 2 back surround speakers, all 7 full range speakers using the same VISATON chassis for optimal sound match
- 1 sub built as transmission line to produce subsonic bass down to 17 Hz for LFE
- Bass traps to handle the low bass problems in this room
- Anamorphic lens for a VC of 33% - prism based
- HT-PC with display and input control built in a small table in front of the first row of seats - for the DVD playback and room control
