Just to give a heads up, I just finished watching CB and while it is a good release, it certainly is not a "reference" disc as many seem to be touting. First off, there is minimal posterization, from time to time, on the disc. A good example is the very first Wb logo as the movie starts (not the first WB intro that starts every disc). As it fades in and out, you can see the posterization in the grey cloud patterns.
More disheartening is the occurance of noise in the backgrounds at certain times during the presentation. Look at around 8:45 - 9:00 in and it is easily noticable as I would consider that instance moderate to severe, and very, very distracting. I was hoping for a homerun here, but alas, this is not it.
The transfer is certainly not all bad as the blacks can't get any richer or darker, color fidelity is outstanding, even with the intentionally subdued pallette, and depth and sharpness are always outstanding, so there are clearly som excellent attributes to be found, but the above issues keep it from being perfect.
Certain reviewers are really getting lazy with their analysis, seeming to only write the same ******** video review for every disc only changing the paragraph structure to look fresh. I'm sure the ever reliable Josh Z, and Home Theater Spot group will come to this conclusion once they are able to obtain their review copies, but until then, buyers looking for a perfect disc may be left wanting more.
P.S. I almost forgot to mention the fine texture detail, and it is amazing. Clothes takes on a whole new dimension as does the velvet-like wallpaper of the household. Even subtle nuances of the sculted puppets reveal lines and minor details hidden before by the DVD. Just wanted to point this out as another plus as I am FORMAT NUETRAL and only want outstanding presentaions. And most likely this problem will manifest itself on the HD-DVD anyway as the encoding is the same with the only difference being in the audio department.
