After inadvertently calibrating the AV input on my Samsung LN32B640 today, I was able to get back to "AV Calibration Success" again by doing the following:
I compared my ADC Result values after the failue to akakitsu's values in the picture he posted above (he had not messed with the AV Input calibration). Mine were all similar (all within 1 of his) except the first two. My 1st_Y_GH was 255 and 1st_Y_GL was 163 whereas his were 1st_Y_GH = 249, and 1st_Y_GH = 245. I changed those to match his.
Next, I download a 8x8 checkerboard grid that was linked from the link in JQ3's post above. I inverted it so a black checker box was in the top left corner and made the image 1920x1080. I then copied the picture to my PS3 and connected the PS3 up to the TV using the AV1 input.
I then used the PS3 to display the checkerboard and went into the TV's service menu. One issue was that the PS3 was not displaying the image full screen. The 1920 x 1080 image was being displayed with black bars across the top and bottom. Tried to calibrate and got 'failure'. So, I zoomed in using the analog hat until the top of the image met the top of the TV. This cut off both the left and right edges of the left and rightmost columns of boxes (about 3/4'ths cut off). However, I tried calibrating again and got 'success' even with the edges cut off.
I checked the ADC Results again and the only thing that changed was the 1st_Y_GH changed from 255 to 253. 1st_Y_GL remained unchanged at 245. And, by playing around with that value I can see that the original failed calibration setting of 163 is the culprit as to why everything gets so dark after a failed AV input calibration.
TV is looking good once again.
Hope this helps others than blunder into this same issue.
: messing up) their tv.
or just pure luck, lol.
