AVS › AVS Forum › Display Devices › Rear Projection Units › Official Sony XBR2 (60" & 70") Owner's Thread
Official Sony XBR2 (60" & 70") Owner's Thread - Page 62
post #1831 of 11971
Originally Posted by evcook View Post
I have learned some things about using the 70 inch XBR2 as a 1920x1080 display for PC and Blue Ray playback. Hope this helps someone...
* first - the good news: movie playback quality using a PC on the Sony totally rocks! whether you used your MY-HD card to PVR it off the air, need to play plain old DVDs, or pay the $ to buy a BD/HD disk drive - the PC can handle it all and deliver a top end quality result on your XBR2. the bad news is that your current video card/motherboard may not be able to handle it.
* the 3 HDMI inputs only support stereo sound, not 5.1. the optical output is only good for listening to 5.1 that has come into the set through the antennae.
* the 35 foot DVI-to-HDMI cable by works beautifully ($25 on sale)
* all 3 HDMI inputs will work with a 1080p compatible PC video card, although you should have a video card that allows hacking that down to lower resolution to prevent overscan (yes I hate that too, but I would rather see the whole screen than overscan or look through a smaller "window").
* any 1080p video card will give you better DVD playback quality than any HD-DVD player I have seen. if you have a spare PC - use it instead of buying a HD-DVD player. the DVD quality is so good - it is stunningly close to Blue Ray playback.
* only a few AGP video cards support 1080p. even though they may list resolutions as high as 2048x1536, they will not be able to do 1080p on the Sony (typically only 1080i). one that does work is the Nvidea GeForce 7600 GSOC. others with release dates similar to this card will probably work as well.
* it is easy to find PCI-X cards that support 1080p, but they have a problem as well - most do not support "HDCP" - High Definition Copyright Protection - which means that you can't play back Blue Ray or HD disks on your computer. the Nvidea web site has a program you can download so that you can test your system and determine if it supports HDCP.
Currently, I am on a mission to find an AGP card that will support HDCP. I have this query into Nvidea level 2 support. There is a ton of mis-information on the web, and on video card boxes about this (I have returned 3 cards to my local store this week). The key is this - even though the newer graphics CHIPs from Nvidea, Ati, etc support HDCP, the various vendors that use those chips don't put the extra logic on the video card circuit board to allow the chip to work. Hopefully the good folks at Nvidea can tell me what (if any) AGP card does.
evcook:
Thank you for the response. But this still does not answer the question of sound. You've mentioned that DVI-HDMI cable works great. Well, there are many cables that work great.
The question still remains: For those of us / and you that do not use an AV receiver to pass the sound through the external speakers, and only use the TV, is there cable that pass DVI + Sound (via stereo input cable) into an HDMI cable which will plug into the TV.
Unless I am mistaken, this is the only way you will get PC 1080P + full sound.
Thanks for the effort. I guess we're all SOL
post #1832 of 11971
Originally Posted by asong26 View Post
evcook:
use mini- to-stereo audio and audio couplers if you need to extend the cables. one of the HDMI inputs accept audio and your computer should have a mini output for the audio
post #1833 of 11971
I have a quick question on the danger of putting non-home speakers near the TV. My XBR2 will be delivered tomorrow and I wanted to know how close I can put my modified Bose 301 speakers.
Are these TVs sensitive to the magnets from car speakers like older ones did? My woofers in my Bose gave out and I replaced them with car subs. They work great, but I don't want to risk getting them close to the TV.
Thanks in advance for the feedback.
post #1834 of 11971
evcook:
I too hunted for a cable that would take sound from my computer/player (either stereo or 5.1) and DVI into the HDMI at the other end. I did not find one, but abandoned that idea when I found that the Sony would not accept 5.1 in. No way am I going to use stereo when I have 5.1 available for almost all content. Your needs sound different from mine, though.
post #1835 of 11971
Originally Posted by CriPPleR_HD View Post
Thanks for the compliments on my set up, Plasmabuyer.
At first I was using a Arcam AVR350 but it was not doing my speakers justice. The Arcam clipped badly. I am in the market for a good amp ATM. I had a McIntosh MT6900 on lone and that thing made my speakers come to life. I currently have the McIntosh MHT200 on lone from my dealer but after hearing the 200WPC beast(6900) it is hard to go less then that. I am also getting receiver noise out of the MHT200 something that I did not experience with any other amp/receiver before.
I am going to audition Class'e Bryston and Ayre this weekend and then decide on something next week. Here is a of pick of the amp. I am happy that my center speaker fit in the stand.
http://i89.photobucket.com/albums/k2...D/P1010209.jpg
Back to the XBR2:
It is unfortunate that SSE is an issue with Micro Displays. It really is not that bad and it beats watching TV on a 34" screen but it would of been nice if they could of worked it out.
I just down loaded the update from Xbox live. The setting for 1080p is there but when I select it I get a black screen.
Nice setup! Although the 6900 has the current for the Focals, I think you will find that it's not the most refined of amps and isn't the best match for your speakers. I bet you will find the same with Bryston. I'm going to guess that Jm Labs tweeters are going to pierce your eardrums with Bryston. I'll take a shot in the dark and bet you will like the Ayre the best. I've got a CD player from them and they make brilliant equipment. I actually like all the other stuff you are looking at, just not with your speakers. If you have a chance try to go hear the YBA stuff with your speakers--there's something to be said for the all French synergy, they work really well together. I'm not shilling for anything here, I've got all Joule Electra Tube gear--I've just done a lot of what you are about to. Good luck!
post #1836 of 11971
Originally Posted by the_bull View Post
DVD Freaky,
The 70 (in the box) was to large to get into my viewing area (basement) as well. But the delivery guys took it out of the box and were (amazingly to me) able to get it in without incident. If needed to, I would have taken the speakers off to get it in (only takes 2 minutes).
You should consider letting them take it out of the box and removing the speakers if needed (if the 60 fit in the 70 will this way).
I thought about returning the 70 for the 60 because the 70 seemed too big (but now love it - 3 weeks in), but knew I probably would always regret it. I think you are already regretting going to the 60.
You shouldn't buy this TV with regrets, go for the 70!
good luck!
Totally agree...
BTW, finally the XBR2 will be here tomorrow to replace my XBR1...
post #1837 of 11971
DVD Freaky,
good luck!
Good idea, but again...the delivery guy said I would have to sign a waiver removing them from all liability if they took the tv out of the box outside my apartment, to move it in. I think that's ridiculous, which is why I declined. Even though I am 95% sure your idea would work, the fact that I would have to sign a waiver with this particular company is what killed that. They said Crutchfield's instructions were to move the box inside my place and then remove from box. Any deviation, they would not adhere to. Strange, cause Circuit City removed the 60 outside my apt. without a care in the world.
I am definitely investigating getting the 70, but it all comes down to financing, ease of exchange with CC, etc.
KT....thanks for posting info about the Palette....will definitely experiment more later.
MMMMM...'LOST' in HD later tonight for the first time....YES!
post #1838 of 11971
Oh yeah, would someone mind posting a link to the XBR2 settings/tweaks thread....can't seem to find it.
post #1839 of 11971
Originally Posted by heartsurgeon View Post
have you sent dvd material to your hdtv from your computer using dvi-hdmi cable, and if so, how did it work.look
Heartsurgeon - See my initial experiences with PC - to- Sony in the above post. Throw your DVD player in the trash, and get a PC video card that can output 1080p. Be aware that you may want to play BD/HD later, and most video cards that can do 1080p can not play BD/HD.
Quality is also dependent on the player, but the (free) VLC player in full screen mode does a decent job. I use WinDvd 6.6 (a not yet available version for BD/HD disk drives) for most things, however, because it can handle 5.1 audio and has all kinds of tweeks for getting the perfect image.
If you have a MY-HD card for HD capture and PVR use, do not use it for playback (poor quality). Instead, record the content to disk and play it back using a good (software) player. If you want to use MY-HD for live viewing, then you should have the DVI daughter card because the MY-HD player gives a very poor image when run on the desktop.
post #1840 of 11971
only CRT / tube TVs are susceptible to a magnetic field...lcos dlp plasma and LCD don't care...you can put that guy right on top of the xbr2 and nothing will happen...unless you drop it
post #1841 of 11971
best buy with a magnolia has teh 70 instock and shouldnt let you sign a wavier..something to think about
post #1842 of 11971
To be more specific, plug your DVI to HDMI cable into the lower HDMI socket labeled #8 for video. Then your mini-plug to stereo RCA adapter goes into the audio jacks to the right of the HDMI sockets labeled HDMI IN AUDIO/8. The front panel HDMI (#3) unfortunately does not have a separate audio in.
post #1843 of 11971
Hi
Here you go.
There are several good sets of suggestions on this page. My thoughts are on post 4.
http://www.avsforum.com/avs-vb/showt...40#post8742640
KT
post #1844 of 11971
I just finished working on a 70" XBR2. This is one awesome display. The processing is exceptional and the colors were wonderful. This display has the lowest video noise level of any RPTV I have seen.
Here are the results.
Summary Calibration Report.pdf 29.6484375k . file
Final Tristimulus.pdf 5.9072265625k . file
Initial Tristimulus.pdf 5.9072265625k . file
post #1845 of 11971
Thanks for the update.
post #1846 of 11971
thanks for the news UMR. Would it be reasonable to assume that the 60 would be of similiar quality
post #1847 of 11971
1) One-to-One pixel mapping via HDMI (no overscan for optimal use of video processor)?
2) Inverse telecine?
3) 24/48/72 Hz input?
I've read these threads quite a bit, and to be frank, I'm getting lost in some of the details
Thanks for the help
Greg
post #1848 of 11971
UMR would you be willing to share the settings you used to achieve this?
post #1849 of 11971
I am having problems getting to see the 70" XBR2 in Northern San Diego County. The Tweeter stores say they have the 60" on display but will not have the 70". Can anyone suggest an alternative?
BTW- Please PM me if you were able to get a better price than the $5,999 retail price on the 70" XBR2. Thanks.
post #1850 of 11971
not sure it would be valid - or fair to ask. UMR should be adjusting the individual unit using the service menu options and the openly available options, so this would not be for the faint of heart, or valid to another set without measuring then adjusting to move those measurements to ideal. besides this is a service he charges for
post #1851 of 11971
My next purchase is the XBOX360. I thought I read somewhere that the XBR2 supported 1080p over VGA....but I guess that's wrong. Guess I'll be going via component when I get the 360.
Time to do some thread searching here...but wondering if anyone knew for sure.
post #1852 of 11971
Yay umr! Thanks so much for the feedback and deets! Hope you can stick around a while.
post #1853 of 11971
Did you use either of the DRC 2.5 modes? If so, are there optimal settings that we owners should be using?
post #1854 of 11971
I don't see why it would not be.
post #1855 of 11971
All of my adjustments in this area are not in the user mode so it would not be of much help. I also do not share settings.
post #1856 of 11971
i get an error opening the documents. says the files cant be found.
however, i am so happy to hear your opinion. "awesome, exceptional, wonderful."
sounds like this is the one for me
post #1857 of 11971
Try.
Right click on the file link.
Select "Open In New Window" from menu selection list.
post #1858 of 11971
Try.
yep. thats the trick....thanks
post #1859 of 11971
Try.
1st, I would like to say thanx for letting everyone in this forum know how the tv performs in your own experience!!! 2nd, I don't blame you for not sharing as this is what pays the bills for you!!! I would like to know how this tv compares to the new samsung DLP's, I know you say those are the best tv's you've worked on!!!
post #1860 of 11971
wow UMR. you were able to get it pretty much dead nuts with the targets.
and it wasn't as scary precalibration as i thought it would be. was that right out of the box or had someone used a calibration disc or played with the settings before you got ahold of it.
  Back to Forum: Rear Projection Units
