AVS › AVS Forum › Display Devices › Rear Projection Units › Official Sony XBR2 (60" & 70") Owner's Thread
Official Sony XBR2 (60" & 70") Owner's Thread - Page 181
post #5401 of 11979
Originally Posted by Bob Fosse View Post
Although I own a A2000 I wanted to share my impressions of Jeff Meier's (UMR) recent ISF calibration last Saturday with all you lucky XBR-2 owners:
We recently had Jeff Meier (UMR) ISF calibrate our A2000 to a stunning new level neither I or my wife thought possible. The improvement in picture quality was dramatic and has to be seen to be believed. The overall clarity, detail, focus, and color balance were greatly improved giving the picture a more 3 dimensional appearance. Black level and shading is also better. Facial tones post calibration were also significantly improved giving them or more natural look and texture. With good source material Jeff was able also able to eliminate the green tinge to face issue that has plagued my A2000 which neither I, the 2 Sony techs that looked at my set, or 2 other ISF calibrators were successful at doing. The other calibrators concluded that my A2000 had a decoding error which was the cause of the green artifact. Jeff did find that my A2000 had a green push before his calibration but with his custom software and talent he was able to fix that without upsetting the color balance. The green tint still does manifest itself sometimes on TV broadcasts but is probably the fault of the source in most instances. I have not seen any green artifacts on any of my DVDs that I have viewed so far. If fact Standard Definition DVDs are improved giving the best ones an almost HD quality look that I describe above. The picture on DVD is so much cleaner looking too. One of Jeff's tricks is to eliminate noise without sacrificing detail. In fact, shading and detail are better now post calibration.
Jeff was also going to do a full calibration of my audio but found that my old M&K sub woofer is defective so he only did a partial audio calibration which did improve the balance and tonal quality of the sound from my THX Atlantic Technology surround speaker system. He made some excellent suggestions for a replacement sub woofer and a new receiver too. I will have him come back for a full audio calibration on his next tour to our area. Can't wait!
After having work done by several other ISF calibrators it is most apparent that Jeff has a special talent for ISF calibration and also knows the SXRD technology like the back of his hand. He is a really nice guy too and explained everything that he did in detail to me. If you considering ISF calibration, or even thinking about it, Jeff Meier is the one to do it. The improvement post calibration was worth every penny and then some. Even my wife is impressed with what Jeff did to our A2000 and she normally she doesn't care about these types of things so this is the highest compliment possible.
Great to hear Bob, but what exactly does Jeff do. Is it all via the Service Menu or does he actually do physical convergence adjustments as well? Could you elaborate some?
Thanks, JP
post #5402 of 11979
Originally Posted by Desert Heat View Post
Thanks Max! Which XBR2 did you put on the new stand? 60" or 70"? If you have the time, do you think you could maybe snap some photots of your stand and post or send to me? I am really interested in closeups of the stand as I cannot make out from web pictures what the inside is made up of?? for instance are those glass doors on the two end compartments? How about wire mngmnt? Looks like it might be tuff running all of my componets as the back is not open like the XBR1 stand.
Once again, thank you for all your valuable feedback!!!
I have a 60". Since the stand is for 70" too there are about 4" longer than the TV on each side.
I won't have my Camera with me until this weekend but the stand looks like a "C" channel with 2 vertical dividers, no center shelf.
The shelf have cable holes at the back with invertable plastic cover.
post #5403 of 11979
Bob,
Any chance you can post your settings to the A2000 board? Thanks, Kevin
post #5404 of 11979
Originally Posted by iumbastu View Post
Bob,
It would not help you very much. Each set is unique and requires different settings. Many of the important changes are also in the service mode.
post #5405 of 11979
Jeff,
Where are you located? What area of the country do you do calibrations? Thanks.
post #5406 of 11979
Originally Posted by zxvfrr41 View Post
Jeff,
You can get to UMR's web page by clicking on his user name.
post #5407 of 11979
Question:
I can purchase either a 70"XBR2 or a 60"A2020. If I go with the XBR2 it will be down in the basement in a home theatre setup (non dedicated room) to be shared with the kids in a second family room. I don't have room for this in our primary family room. Viewing would be on an ad hoc basis during sporting events or family movie nights.
The A2020 would go upstairs for daily viewing and would be used probably 2x, if not more, as much as the XBR2.
I can't afford to get both, but can choose between either one. I'd like to get the XBR but feel like it will be underutilized as it's down in the basement while the 60A2020 would be replacing a Hitachi 50" Director series (which would then head to the basement...) and might have more value to the family. Of course with the A2020 there's always a chance of the green tint issue...(from what I hear.)
Any thoughts or suggestions. Thanks in advance.
P.S. 60" XBR2 is a no go due to the dumbo ears
post #5408 of 11979
Thanks, JP
He works in the service menu using his custom software on his laptop, test pattern generator, Eye One Pro calorimeter, and other equipment. He also calibrated my DVD player. His final adjustments are by eye to each input for the optimal picture quality for each one. He does all the video calibrations as outlined on his website www.accucal.org . You can also read about the equipment that he uses there too including the Eye One Pro. He worked on my set for over four hours. He did adjust my convergence but I am not sure what you mean by "physical convergence adjustments?"
post #5409 of 11979
Originally Posted by pwiss View Post
Congratulations Bob!
I had a feeling that Jeff would be able to fix your issue.
Thanks! And to think that I almost backed out at the last moment. Lucky that I didn't
post #5410 of 11979
Question:
It seems to me that the HT impact of the 70" SXRD may have you using it far more often than you think for movies and sports especially if you have HD DVD or BD. 70" WoW factor is hard to resist and it appears the QC and green issues have been resolved. If I had to choose I'd choose those factors first based upon the reviews. Not being critical of the A2020 but the top of the HT Food Chain is the 70" SXRD IMO.
post #5411 of 11979
finally got some free time and can report on jeff's calibration of my 60 xbr2 and my sony str da2 es a/v receiver. my sony is connected to dish 622 dvr via hdmi and toslink to receiver, and my a2 hd dvd player connected to set via hdmi and toslink to receiver.
initially, just want to say what a great guy jeff is. he's a gentleman, friendly, knowledgable, patient, and someone who is a lot of fun to talk with. i even left him alone in the house for a few minutes when i had to pick up my son from school and found only a few valuables missing (lol).
jeff also shared some of his insights about the xbr2 that i feel are worth sharing. he indicated, as most of us know or believe, these are as good or better than any sets currently available with large screen sizes like this. he has encountered very few problems that he cannot correct with calibration. he's impressed with the sets. he also stated that he thought the 70xbr2s were overall superior to the 60xbr2s because sony uses their best lcos chips on their flagship set. interesting since most of us believe size was the only difference between the two. luckily, he found my set to be one of the better 60" he has encountered, with no tinges or hazes, and virtually perfect convergence. he did not need to make any adjustments to my convergence - not bad for an october build.
jeff calibrated 4 inputs on the set, video 2 for wii at 480i (since we do not have component connection), video 3 for future htpc connection via hdmi (my son wants to build one this summer as a project), video 7 hdmi via 622 dvr, and video 8 hd dvd via hdmi. the results -- SPECTACULAR!!!
most noticeable changes were the blacks. went from deep navy blue to squid, inky blacks. outstanding. watching ncaa tourney game saturday from arena where outside border of the court was black really exemplified the difference. also the shades of gray across the scale are now clearly visible. watch departed or batman begins and you are blown away by the richness and distinctiveness of the blacks and grays. now i see what the videophiles are talking about with these colors.
another major change is the sharpness of the picture and the displaying of accent colors. think of the banners of the armies in kingdom of heaven. i've seen that movie 15x, but only after the calibration did i notice the subtlety of the colors incorporated into the scenes of the armies in the field. the whole picture now has such depth, crispness, and dimensionality it is almost like a 3d effect. watch the dinosaur stampede scene in kong, and all the images stay sharp and distinct, there is not blending together of the colors and tones as there was pre-calib.
lastly, the accuracy of the flesh tones and facial colors is remarkable. in fact that the only thing my wife has noticed post-calib. absolute, right on, precise human colors and tones. completely lifelike. i didn't think it would be possible to obtain this level of accuracy.
as startling as the video has improved, i believe my audio has improved even more. all 5 channels are precisely balanced and tuned. my surround is now working the way it was supposed to. my sub rumbles while subtle audio projects from the rear. it is the complete ht experience. i swear, i have better pq and as good of sound as i can get at my local cineplex. why spend $10 a head from now on, i'll just wait for the dvd or hbo. the setup is so cool i'm excited as a little kid at christmas. this is probably the best toy i've had since childhood!
in summary, these set are off the charts. no matter how much tinkering you do with the settings, you will not be able to dial these puppies in the way jeff can. do yourself a favor and spring for a calibration, and definitely use jeff if you can. i have absolutely no regrets.
pre and post calib results attached. contact me if you have questions or need more info.
thanks again jeff.
Initial Tristimulus-1.pdf 5.916015625k . file
Final Tristimulus.pdf 5.91015625k . file
Summary Report.pdf 29.392578125k . file
post #5412 of 11979
How much does Jeff charge you for calibration for these sets?
Can you just buy the calibration DVD and do almost the same thing?
post #5413 of 11979
I've included your report in the owner's list that is linked at the bottom of my post.
Thanks for the report.
post #5414 of 11979
How come the 70XBR2 is superior lcos chip than 60XBR2. Both are exact same set otherthan the size and removeable speaker option. Has anyone else ever heard about this?
post #5415 of 11979
Sony can hand pick (test) the chips used in the 70" XBR2 sets. That's what they did when the Qualia 70" set was being offered.
post #5416 of 11979
You can get price information at UMR's web site. His URL is in his profile.
Maybe almost ~10% of the same thing.
post #5417 of 11979
I saw the photo of Qualia 70". http://www.ultimateavmag.com/rearpro...ony/index.html It looks exactly same as XBR2 sets.
post #5418 of 11979
jeff calibrated 4 inputs on the set, video 2 for wii at 480i (since we do not have component connection, video 3 for future htpc connection via hdmi (my son wants to build one this summer as a project), video 7 hdmi via 622 dvr, and video 8 hd dvd via hdmi. the results -- SPECTACULAR!!!
thanks again jeff.
So you are the guilty party for introducing him to the Wii! I left him along for a little bit, and found him bowling. Just Kidding, but I think he might be buying a Wii in the future.
post #5419 of 11979
I had Jeff over today to calibrate the TV, and he discovered that my 70" XBR2 is out of focus. I was wondering if anyone else had has this problem.
Sony is coming out on Wednesday to take a look.
Michael
post #5420 of 11979
that's what jeff said. they want the best chips for their top of the line set. doesn't mean you can't get good quality chips in 60, just a better bet in the more expensive 70. i suppose it makes sense.
post #5421 of 11979
Michael
Be sure to write a report so it can included in the owner's list.
post #5422 of 11979
no way can you get the same results via any commercially available calibration system. jeff uses his own software to make the adjustments in the service menu. he then tweaks everything again making subtle adjustments based on his own intimate knowledge of the sxrd sets and his significant sensory experience. every set is different and needs its own specific adjustments in the service menu to obtain it maximum performance. other isf calibrators may be able to accomplish the same results, but with jeff it is a sure thing. you don't have to take a chance on getting less than optimum results (ask bob fosse or alan buck about other isf calibration results)
jeff charged me $500.00 which included a $100.00 travel surcharge. he spent nearly 5 hours at the house. once again, money well spent as as far as i am concerned, i have an entirely new hd home theatre.
post #5423 of 11979
Be sure to right a report so it can included in the owner's list.
He didn't end up doing it, as he was afraid that they might replace my TV and it would have waisted my money.
post #5424 of 11979
Anyone knows when Sony drops price online? Is it 1st of every month?
post #5425 of 11979
Did you reschedule?
post #5426 of 11979
thanks again jeff.
Great report and from what you describe above you see the same sort of things that both my wife and I see after Jeff's calibration to our A2000. As I mentioned before, my set had a serious green problem that no one else but Jeff could fix. It was so bad that I was on the verge of donating it to charity--no kidding. Jeff did adjust the convergence of my set which neither of the previous calibrators had a clue how to do. He also told me that my A2000 was not fully resolving a 1080 signal so he fixed that too (not the same problem that the early A2000s had that was described on the C-Nets review.) He shifted the problem areas away from green and towards blue to correct my green tinge problem. The A2000s get the lowest grade LCos chips according to Jeff. Even though my A2000 had been calibrated before, the improvements that Jeff made to our set was beyond all our expectations and now both my wife and I are really happy with our A2000. Its like a whole new set!
post #5427 of 11979
Great! Thanks for the feedback. Sounds like you are quite happy with the stand even with the extra 4" of unused space on each side. If you have the time when you get your camera some pictures would be very helpful too.
Thanks again!
post #5428 of 11979
Welcome to the UMR club!
Your results look very good. The only thing that caught my eye was that your contrast ratio went from 1882 to 1858. When he did my 60xbr2 it went from 926 to 5218. He did mine in warm2. It looks like yours started in cool or neutral temp based on your initial readings.
post #5429 of 11979
Michael
I know someone who bought an A2000. It was their first big screen HDTV so they were impressed with it at first. However after a few weeks they started to notice that there was something not quite right as the picture seemed a little out of focus. They decided to have it ISF Calibrated. When the ISF calibrator came to work on their set he found that it had such a bad convergence that he could not even calibrate it. Even though their set was beyond the 30 CC exchange/return policy, the ISF Calibrator was able to convince CC to exchange their defective set for another A2000.
Hopefully you will be able to get your issue resolved with Sony before Jeff returns.
post #5430 of 11979
Michael
Michael,
I had my 70" XBR2 calibrated 2 weeks ago by Randy Tomlinson. He wrote the review of the 60" XBR2 on Ultimate AV Magazine.com. He put up some sort of test pattern that covered he entire screen that looked like a bunch of interlocking letters. It was as sharp as a tack on the left side and gradually fell off focus left to right with a huge difference at the exteme right side of the screen. He said that the test pattern was an extreme test pattern for focus, and although it was obvious that the focus was off, I would not notice it normally, and I don't. But, it still bothers me in my mind. Was your set uniformly out of focus? What sort of test pattern was used to make the call? Let us know what the tech says. Who is cominng out to make look at the set?
Ken
  Back to Forum: Rear Projection Units
