Originally Posted by kelpie
No, I didn't go to CEDIA. Did you read the links that I gave you? I have. All of them. And more.
I'm sure that you saw quite a few displays at the CEDIA show. In fact, I wouldn't be surprised if you saw a bewildering array of displays at a show like that. It must have been hard to keep them all straight.
Although, as you say, I wasn't a CEDIA like you, I have followed the XBR5's closely. Unfortunately it would appear that your presence at the show ~1½ months ago didn't prevent your memory from failing you. Virtually all of the information that you presented in this thread concernding the XBR5 was inaccurate, misleading, or incomplete- as I have shown with the verifiable evidence that I provided in my post (as opposed to your memories of what you saw and heard 1½ months ago). The XBR5 SXRD's are not available "now" or apparently even "soon", there is a standard "base" under the screen and there are no "legs" that the owner needs to install, there are not "2 supports" on the optional pedestal stand, and the display does not always interpolate frames as you described. Sorry.
Still feel your memory of the XBR5 at the show is correct? Below see photos of two of the XBR5's at the show. Care to tell us again about the "2 supports that hold the screen above the surface of the stand"?
Despite what you thought you saw or heard at CEDIA, looking at those photos from the Sony booth at that show it would appear that the information that I posted about the SU-RS52U stand is correct- even for the pre-production stands that you saw at CEDIA.
Instead of being "cracked up" by "internet smartboys", perhaps you should be appreciative of better informed people who help you improve your knowledge base.
OH, I'm SOOOOOOOOOOOO SOOOOORRRRRYYYYYYY, there's only ONE support that holds the TV above the stand and there's nothing but space below the screen. Just like I said. No visible "base" to the display... also as I said... nothing at all extending below the screen except the support. That's quite different than the XBR2 which DOES have a base that DOES contain much of the GUTS of the TV which was my point in the first place. So the XBR5 design has to have moved all the guts UP into the space behind the screen to get that appearance, which was also the point of the original post.
. he also told me that one of my surrounds wasn't quite right and after he pointed it out to me i noticed it too. almost like the timbre was different than the other speakers. not really noticeable when watching movies but definitely different with pink noise. (gotta check into getting that fixed). he also pointed out that i had neglected to run a digital audio cable from my cable box to the receiver and that i was only getting analogue pro logic when watching 5.1 TV. he offered to fix it but i knew i didn't have a cable and my receiver back is pretty hard to get to so i told him I'd do it myself. i haven't had a chance to listen to any of my own music or movies through my newly calibrated system but the samples he played were fantastic.
