Originally Posted by
DPlettner
Why not plug everything into the 1G router? Are you out of LAN ports, or to you want to combine the HDHR LAN ports for a long LAN cable run?
Which router do you use to bring the Internet into your network?
Typically, you only want one router on your network, and then you want to use switches for the other network distribution devices. However, most routers can be used as a switch. Just disable the DHCP server of the router you want to use as a switch, and then use the LAN ports on the router, but don't plug anything unto the WAN port.
-Dave
Hi,
Adding a second HDHR would fill up all the ports on the 1G router so if another port is needed there would be none available. But that would be the initial configuration and yes the 1G router would bring the Internet into my network and would be the only one with the 2G and 5G radios on. I see no usefulness of having a second router's radio on. A long LAN cable run might be in the future to where I wish to put a second HTPC but currently no antenna connection is possible there.
The speed of the 5G radio would in effect allow another fast port but not a good idea to me.
Main Wireless router:
1. DHCP server ON
2. Internet connection
3. 2G Radio on (Network Printer Server and other laptops)
4. 5G Radio on (Main Laptop only currently)
Port1 = Network Attached Storage (NAS)
Port2 = (Spare for long LAN run to additional HTPC Computer)
Port3 = HTPC (Computer has no wireless)
port4 = Connection to second router
Secondary router
1. DHCP server OFF
2. NO Internet Connection
3. 2G Radio OFF
Port1 = Connection to main router
Port2 = HDHR #1
Port3 = HDHR #2
Port 4 = Spare
Note: Old wireless router may be replaced with a 1G router with no radio if more speed is needed. The speed needs of the four HDHR tuners might force this but I do not see this happening, not too many HD programs need to be recorded at the same time.
Questions:
Can the Internet connection (WAN Port) on the secondary router be used for any purpose?
I assume that no manual configuration of network settings need be done.
I just discovered a second 1G port on my HTPC, how would DHCP be done if I plugged the secondary router into that port? Would the result still be one network with access to all devices still possible? (HDHR on secondary router to HTPC to main router to wireless 5G radio on main laptop work?
SHF
