AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp Aquos 42D62U/46D62U/52D62U Owner's Thread (NO PRICE TALK!)
Official Sharp Aquos 42D62U/46D62U/52D62U Owner's Thread (NO PRICE TALK!) - Page 409
post #12241 of 12255
Originally Posted by rickster470 View Post
does the liquid crystal only seep out when the TV is on? Or can it come out when the TV is off?
It can seep out when the TV is off or on, doesnt matter
post #12242 of 12255
Update on my situation: After a day at work and a couple of hours of having the TV off, most of the black stuff is gone, leaving a few stuck pixels behind. Is it possibly the same problem that some people were having earlier, or did the liquid crystal just seep back in?
Originally Posted by akaplay View Post
I have a Sharp Aquos 52" LC5264u and upto now the TV has worked Great. Recently i noticed a "bubble" on the left hand side of the screen... then after a few days the Bubble grew larger to almost 4 inches. There are also a few more smaller bubbles below the larger one.
After an hour or so, the bubble is barely noticeable, unless a white background is on the screen.
This is a very Odd occurrence and i cant find anything about it. TV is less than 3 years old. Unfortunately i dont have an extended warrenty and the TV was Purchased from Circuit City.
its the diffusion panel that is going bad. Currently i am in the same boat, got a sharp 46 from thrift store at an auction pretty cheap price $130. Now i know whats wrong with it when i turned it on. Same thing as you but across the screen. I am looking online for one to order. Easy to replace, just need the panel. Its a white board with a laminate film between lcd panel and backlight.
post #12243 of 12255
My ~3 year old LC-42D62U has developed a grunge band horizontally across the top of the screen that is slowly getting worse. It cannot be cleaned because it is behind the front plastic screen. My guess is that dust/dirt has been getting in there and the heat takes it to the top of the screen. Seems to me that the front protective plastic screen should have been sealed to the LCD panel behind it.
Has anyone taken the screen apart for cleaning or is that a big no-no?
post #12244 of 12255
Have anyone encountered ants or strange foreign objects entering the screen? Currently I do not have a picture of this but it's pretty strange right???
post #12245 of 12255
Yes
post #12246 of 12255
I'm guessing that the LCD isn't sealed that's why dust and other particles are getting in to the screens.
post #12247 of 12255
Hi everybody,
I own the 52" model and need some help with the audio output settings.
Basically, I will like to connect my PS3 and HDTV sat box to the TV via the HDMI inputs and then send the audio of both devices through the TV optical audio out to my receiver.
After a quick search, I found some people in this forum claim that you cannot pass through an optical audio signal when using the HDMI ports, however, I have managed to pass a dolby 5.1 signal to my receiver using the TV in between the devices (source is a PS3).
The problem is that I can only hear sound when playing a BD or DVD. Once I use the PS3 for anything else I get no sound (not even the sound click when scrolling through the PS3 menu) .
PS3 audio settings: PCM 44.1, 48hz, Dolby Digital.
*Note: I can get sound when playing a movie in both HDMI 4 and 5 inputs- the audio is only output to my receiver and not the through the TV internal speakers (which is exactly what I want).
I do get a message: An incompatible audio signal has been received. Check the output device settings. In spite of the message, I can hear dolby 5.1 movies using my receiver (the AC3 5.1 lights up).
My experience with the Sat receiver is even worse. I can only manage to get sound on the TV internal speakers, but I need to find a way to send it directly to the receiver.
Does anybody have this HDMI--> TV optical--> Audio Receiver working correctly?
My only only assumption is that a firmware upgrade might enable this capability to work properly.
Any help will be greatly appreciated.
PS. I'm out of optical toslink inputs in my receiver, I will like to get this working via the TV in order to avoid a switch. Thank you.
post #12248 of 12255
Hi,
I have a 46D64u to which I am trying to connect a CinemaGo brite view via HDMI cable.
I get picture (up to 1080P) but no audio over HDMI. I can get audio over composite cables, and the brite view box works fine on my colleagues Plasma via HDMI.
I tried all the ports, different cable, no luck.
I updated the firmware, but no change.
Anyone successfully connected a brite view via HDMI?
Thanks....
post #12249 of 12255
ro2207, did you ever solve your optical audio out issues? I'd be interested in what you did if you did.
Bill
post #12250 of 12255
Bill
Unfortunately I was unable to find a work around, I'm currently using an optical audio switch. When I bought the TV a few years ago, I always had the intention to connect two HDMI devices and output dolby 5.1 sound to my yamaha receiver (not dts capable) via the optical out. I thought of it as a nice addition for those of us who don't want to buy an HDMI audio receiver just yet.
That output turned out to be pretty useless...
post #12251 of 12255
Greetings,
I am new to this site.
I assume this post will be regarded as resurrecting a "zombie thread" because, by today's standards the Sharp Aquos LC 46D62 is yesterday's news.
I have one; I still like it - I've had a failure and I am wishing to repair it on the cheap.
I have already determined that one of the four inverter PCBs (RUNTKA255WJZZ) popped because there is HV leakage associated with one or more of the CFL backlight lamp assemblies in the upper portion of the display. I also have a dim band in the suspect area (that is/was before I popped the second inverter board.)
I am looking for a source of the CFL Backlight lamps. Actually, there are generic sources out there, but I have been unable to cross-reference the Sharp dual lamp assembly part number to the dimensions and specs for the individual lamps that would make up an assembly.
Any info on this subject will be much appreciated.
Joe_A
post #12252 of 12255
Reply to my own post:
Found CCFL Warehouse and was able to purchase 4mm generic backlight tubes in the proper length for my 46 " Aquos
Purchased a new inverter board from ShopJimmy.com
In about 2 1/2 hours was able to tear down the TV and discover one of the CCFL tubes was burned nearly black half-way along the length. Replaced it and the one next to it in the pair. Two (2) of 22 lamps replaced and I have couple of spares if I need them in future.
Everything worked out fine.
It is not too daunting for someone who is a bit handy - and can solder - to repair the backlighting of an LCD TV.
Cheers,
Joe
post #12253 of 12255
Good work!
I still have of these and they look really good.
Arno
post #12254 of 12255
Good job! My 46" unit still has great pictures after 4 years. As long as it works I don't see any reason to replace it any time soon.
post #12255 of 12255
Does anyone know what the latest firmware for the D62U series is? My current firmware is U0610191. I have searched numerous posts online and even the Sharp website and cannot find anything. Also, if someone has the latest firmware for this series could you please PM me or email me at warren.marshall@ryerson.ca. It would be much appreciated!
