Vexeus - don't know if this will help or not. It is an email I sent to my speaker company and the response received tthe other day.
Your Information:
Technical Help Description:
Model Number: T70 Speaker System
Serial Number: T70RB 80466
Please explain the technical issue.: What ohm speakers are these? Would
there be damage to play when the A/V receiver is set for 8 ohm speakers?
What is the advantage of 6 ohm versus 8 ohm speakers. Thank you.
Hi D,
The T70 series speakers are rated as 6 ohms. As a general rule, lower
impedance speakers play louder than higher impedance ones. However, some
less expensive receivers can have difficulty with 4 ohm speakers, especially
at high volumes. A 6 ohm design is intended to be easier for the receiver
to drive, while still having somewhat higher output.
Some receivers have a switch to select either 8 or 4 ohms. There should
be no difficulty for most receivers to play 6 ohm speakers at the 8 ohm
switch setting; but if you have any difficulty with this, or just want to be
cautious, use the 4 ohm setting.
Best regards,
Paul C/ATI
-----Original Message-----
From: Customer Service [mailto:customerservice@atlantictechnology.com]
Sent: Tuesday, October 10, 2006 1:04 PM
To: Paul Ceurvels (E-mail)
Subject: FW: Customer Service & Technical Help has been completed at the
Atlantic Technology website
Sent: Tuesday, October 10, 2006 10:04 AM
To: customerservice@atlantictechnology.com
Subject: Customer Service & Technical Help has been completed at the
On 10/10/2006 9:03:54 AM, the form Customer Service & Technical Help was
completed at the Atlantic Technology website.
