Hey Bryan, good to hear from you! Thanks for the kind words.
I can't wait to get my speakers in there so I can appreciate the results of your brilliant acoustic design!
Btw, I jumped on the Galaxy CM-140 SPL meter buy on the "other" forum. So when I get it everything done I can send you some results and we can see how it performs.
I also have a few "minor" questions for you (you should have known that would happen if you posted in my thread, right
1. Unfortunately I can't do the 4' high 1" FSK on the back left hand side (as you face the screen). The reason is the cabinets at the back of the room on that side are 1" wider than they were supposed be. So if I do the FSK, it will run into the cabinet door. I have about 1/4" to work with. would peg-board or something like that help out in that area? or should I just leave it? On the flip side, the good news is that I can get 2" unfaced on the "alcove" wall above the cabinet
2. I'm trying to figure out where to put my rear channels. I can put them in the soffits along the side walls at the back corner, or in the rear walls (about 6" from the corners, same height as the sides). Does it make any difference?
3. Subs - I have access to a 2nd identical sub (B&W ASW1000). I was going to put the first one in the front right corner and the 2nd one in the left right corner. Any reason I should, or should not do this? any other guidelines on initial sub placement?
Thanks Bryan!!
