AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sharp XV-Z20000 initial impressions and numbers
post #1 of 392
I just updated my review of the Sharp 1080p projector, and I thought I’d post some numbers and impressions based on about one year of use.
Throw and lens shift
The Z20000 is a relatively long throw projector 1.85-2.5/1 screen width. It has a very flexible vertical lens shift of 1 screen height, which means that it is equally well-suited for a ceiling or a shelf installation. By default, the lens aligns with the bottom of the screen for a shelf mount and at the top of the screen for a ceiling mount. Use lens shift to adjust from there. Lens shift works like a charm, but it does reduce light output a little, so use it sparingly.
Brightness and contrast
Measuring brightness is not simple with the projector because it has so many different modes. Like the Z12000, the lamp has a Bright and a Eco + Quiet mode and it has an Iris with 3 settings, High Brightness, High Contrast, and Medium. It also has 5 Gamma presets and several Picture Modes. The default Picture Mode is Standard. With Standard gamma and Standard Dynamic Range selected in the Options menu, the gamma measured a nearly perfect 2.2 across the entire range. This offered exceptionally good shadow detail.
Initially, I did all my watching in the Eco + Quiet lamp mode, and subsequently changed to the Bright mode (with somewhat higher fan noise) as the lamp aged.
All measurements are post-calibration in the Standard Picture mode. The lumens figures were obtained with the projector set to minimum throw. For maximum throw, multiply by 88.6%. Throw range has a minimal effect on contrast.
I measured the ANSI contrast at 560:1 in the High Contrast mode and 489:1 in the Medium mode. Greg Rogers' review published in Widescreen Review reported 845:1.
The Medium Iris setting was my preferred setup. It offers a good compromise between brightness and contrast. Others with smaller or higher gain screens will no doubt prefer the High Contrast mode, as it certainly offers better contrast performance.
Color performance
The Sharp XV-Z20000 displayed the best gray scale performance out of the box that I have ever measured. By default, the color temperature is set at 7500k. I changed this to 6500k and then measured the gray scale.
As you can see, the default gray scale is very good. I entered the custom Gamma mode and tightened this up somewhat and achieved virtually perfect performance. I did run across one problem. The gray scale controls for the low end of the scale did not seem to work. The controls are there and they respond to input, but they have no effect on measured performance. Fortunately, the performance was so good to begin with, I wasn’t too concerned with this. (See more on this below)
The XV-Z20000 includes a Color Management System that allows calibrators to adjust the primary and secondary colors to industry standards. By default, the Sharp showed a familiar color profile: oversaturated red and very oversaturated and somewhat yellowish green.
After making adjustments in the CMS, I was able to get a nearly perfect color gamut.
This is a must-have feature for obsessive tweakers. In fact, this projector is a calibrator's dream. It was particularly gratifying to get accurate green for a change. I don’t think I’ve ever worked on a digital display that didn’t exaggerate green. Sharp’s color management system works exactly as advertised, and I was much more impressed with it than I was with a similar system provided by Optoma’s HD-3000 external processor (the HD81 uses this) and by the one offered on the Epson TW1000.
The Value parameter in the CMS works as a color decoding adjustment, but the color decoding was nearly perfect out of the box (no red push here), so minimal adjustment was required.
Here are some before/after screenshots that show what the CMS can accomplish. The original is on top. The CMS processed image is on the bottom.
Optics
This projector also has the best optics I have ever encountered. The images show great clarity and precision with no evidence of chromatic aberration. There is ZERO color fringing even at the extreme corners of the screen, as shown in this image of the upper right hand corner of my screen.
In addition to vertical shift, the lens has manual zoom and focus. For convenience I would have preferred a motorized system, but on the other hand the lens assembly has a very solid and well-engineered feel. Sharp obviously devoted a lot of resources to the optics. This is an aspect of projector performance that gets far too little attention. Really good optics are expensive, unsexy, and thus difficult to market. Nonetheless, a really good lens can make a profound difference to the quality of the image with respect to sharpness and clarity.
White field uniformity was also very good, a hallmark of the DLP technology. The brightness varies by no more than 10% across the entire screen. I measured color temperature at about 150k lower on the right side of the screen. This is a measurable difference but not one that’s visible to the naked eye (at least not to mine), even when looking at a uniformly white 80IRE field.
Processing
Using the Silicon Optics Benchmark DVD and HD DVD, I was able to test the XV-Z20000's standard definition and high definition processing. It is excellent. It passes full resolution for 1080i film and video sources. It also correctly deinterlaces 1080i for film-based sources, applying 3:2 pulldown. For 480i sources the 20K passed all of the tests the DVD threw at it. It took about a half a second to lock on to the racetrack scene contained in the film detail test, which evaluates whether the display's processor can correctly apply inverse telecine for standard definition film-based material.
One test the XV-Z20000 did NOT pass is the deinterlacing torture scene at the beginning of Chapter 8 of the MI:3 Blu-ray or HD DVD. The staircase scene reveals some moire and considerable line twitter. Interestingly, this scene looks better using 1080i output from the Sony BDP-S1 Blu-ray player than it did with the Toshiba XA2 HD DVD player, indicating either some difference in the way the 2 players output 1080i material or in the respective masters. Even the 1080p output of the XA2 showed problems. However, the 1080p output of the Sony was artifact free.
After its initial release, Sharp made a firmware update available that allowed the projector to accept 1080p/24 input, which it would output at 1080p/48. I am not particularly sensitive to the judder artifact that 1080p/60 supposedly induces so I cannot evaluate its success at eliminating it. However, the update did resolve some bugs, and the 480i processing seems improved insofar as prior to the update the XV-Z20000 did not pass the film detail test on the Silicon Optics Benchmark DVD. This firmware update is thus a valuable addition for this reason alone.
In the Dot by Dot mode, the projector maps the incoming signal directly to each pixel without any scaling. It is in this mode that 1080i and 1080p material look the sharpest. Using a 1080i multiburst signal from the Accupel test signal generator, I was able to verify that the HDMI input resolved the full limit of detail offered by HD sources. The component inputs, however, did not. This was apparent even with regular HD program material, which looked visibly softer over component than when fed the same material via HDMI.
Perhaps the best praise I can offer for the XV-Z20000's processing is that I no longer felt the need to use the Vantage-HD Realta external processor that had proven itself so valuable at improving the performance of the Optoma H79.
Problems
I ran across a few problems.
  • As I mentioned above, the RGB Bias adjustments for tweaking the low end of the gray scale seemed not to function. As it turns out, they do work, it is just that they work on only 10 IRE or below signals. This is a very strange--in my experience unique--implementation of a gray scale control that I fear will confuse a lot of owners and calibrators. Fortunately, you can use the RGB All Colors adjustment instead to adjust the gray scale in the 20-40 IRE range.
  • Page 40 of the User Manual, the page in which these controls are discussed, is reproduced in French! This is obviously a printing error.
  • The fan noise was a little higher than I would have liked and the light output was a little lower than I would have liked.
  • Some have reported seeing more rainbows on the Z20000 than they see on other high-end single-chip DLPs, but since I am insensitive to RBE, I cannot evaluate this.
Subjective impressions
My first thought upon seeing the image from the projector was: “I need a bigger screen!” The high pixel count really would shine more on something bigger than my 92-inch DaLite matte white screen.
I subsequently upgraded to a 100-inch Stewart StudioTek. I was surprised by the degree of improvement in image quality. First, I was able to get a larger image that did not, because of the true 1.3 gain, sacrifice any brightness. Second, this screen is able to resolve greater detail than the DaLite, so now the Z20000 seemed even sharper and more revealing than before. The DaLite imparted a subtle amount of screen grain to the image that disappeared with the StudioTek. This screen is a great match for this projector. If you wanted to go up to a larger 110" screen I would recommend the Stewart Ultramatte 150. For larger screens still, many users have reported very positive experiences with the DaLite High Power.
I spent a couple of hours looking at DVD, HD DVD, and broadcast (HD and SD). My only recent frame of reference was the SIM2 HT3000. They looked very similar, except that the Sharp seemed a little, well, sharper, a perception that I attribute to its superior optics. After tweaking, the Sharp certainly offered better measured performance. It provides better color performance and higher contrast. In fact, the only area of measurable performance where I thought that the Sharp needed improvement is light output. The High Brightness mode is quite bright, but the black level is unacceptably elevated. The High Contrast mode offers great black level, but it is too dim for my taste. The Medium mode is just about right, but by 670 hours I was getting only 9.5 fL so I had to get a new bulb. I was surprised how little visible change I saw after installing the new bulb, so I think I could have gone until at least 800 hrs. before the lack of brightness really began to impact viewing pleasure.
The biggest improvement of the 1080p pixel count is smoothness, depth, and a difficult-to-describe improvement in realism. The illusion that you are looking through a window viewing actual events is better conveyed with 2,073,600 pixels than it is with 921,600 of the little buggers. There’s clearly more picture information on the screen, which is evident even with standard DVD. However, I think that I was even more impressed by the Sharp’s optics, color, and gamma performance. The CMS system works wonderfully and it really shows on the screen.
There is actually one downside to 1080p projection, at least when combined with a unit with optics as good as the Z20000. As audiophiles have long known, one of the unintended consequences of using a very high-end sound system is that it is ruthlessly revealing of the source material. That is also true with video. The Z20000 did a much better job of revealing differences in quality between a variety of HD broadcast sources, differences that were not as obvious with my Optoma H79. I saw all sorts of flaws in these images that I hadn’t noticed before. However, with clean sources, such as HD DVD, the results are startling.
Despite the advantages of 1080p, resolution is only one measurement of performance and arguably not even the most important one. If the Z20000 had not also provided exemplary colorimetry, optics, and contrast, then the 2 million pixels wouldn’t matter much. Furthermore, to the extent that it does matter you need a large screen to appreciate it. I wonder how much obvious benefit users can expect from 1920x1080 50 and 60” rear projection displays.
Conclusion
In response to market pressures, Sharp has recently reduced the price on the XV-Z20000 to $6999, which is a truly great deal for a projector of this quality. Jason has these units in stock and can quote you a very attractive price, so if you are in the mood to upgrade you should give him a call.
To sum up, the XV-Z20000's strengths are:
  • World-class color available with the built-in full-featured CMS.
  • Excellent optics with zero convergence and chromatic aberration problems.
  • About the highest ANSI contrast available.
  • Very good native on/off contrast in the Medium or High Contrast modes.
  • Nearly perfect gamma provides excellent shadow detail.
  • Very good processing, especially for high definition sources.
Its weaknesses are:
  • Relatively low light output in High Contrast and Medium modes limits screen size.
  • Potential problems with RBE for those sensitive to this artifact.
  • Not appropriate for short-throw installations.
  • Lower on/off contrast than what's available from some similarly priced alternatives.
  • More fan noise than many competitors in this price range.
post #2 of 392
Thank you so much Tom. WOW, what a GREAT report!
post #3 of 392
Tom;
Thanks for your great report!
How is noise level (fan, color wheel, etc.) of this model compared to let's say its 720p brother?
_____
Axel
post #4 of 392
Thanks for the report. I loved the Sharp 12000, but I am disappointed with the contrast numbers and lumens. I would have expected much more from this unit in these areas.
post #5 of 392
Thanks for the marvellous review Tom and for getting all the measurements out so soon. Its great to read a review that includes comparisons to other projectors, subjective though it may be. You didn't mention whether you were using a scaler. If not, how does the onboard scaling measure up to the competitors?
post #6 of 392
Thanks millions, Tom! Yet another great report on a new breed 1080p DLP...
I find it curious that while the lower priced LCD projectors seem to be heading towards more lumens, the considerably higher priced 1080p DLPs you (and others) have reported on so far seem to have such low lumens output. Though I don't know for sure, I have a feeling that the new 1080p DMDs are still faced with the brightness/contrast tradeoffs that have plagued the lower resolution DMDs of the past. That is, they can deliver brightness OR contrast, but can't deliver both, and when manufacturers design projectors they have to make a conscious decision as to how much of each they will provide. So far, the HD-81 is the only unit with enough light output to make it watchable on what I consider a reasonably sized screen (100" to 120" diagonal) over the lifetime of the lamp. Your measurements of both the Sim2 and now the Sharp, as well as Greg's measurements of the Marantz, point towards a scary trend in brightness and contrast of 1080p DLPs. Although the brightness might be marginally fine on a new lamp, as you and I both know, this won't last long once the lamp begins to dim.
Thanks again for all of your efforts!
post #7 of 392
Thanks for the great review Tom. The one thing I have been confused about with this projector and trying to find out is what the "Auto Contrast" mode is and what it does. Did you see that in there? With a claim of 12k:1 on/off CR and your 4k:1 or so measurements, I'm hoping they actually have a dynamic iris mode.
Darin
post #8 of 392
This is beginning to sound like another near miss or "close but no cigar". I know it's good but when is digital going to challenge those CRT inky blacks? The only way to come close is to dim the lamp?
Perhaps I'm just expecting too much. Knowing Sharp it is an outstanding unit in every other way. I'm with Bob on this one.
post #9 of 392
I don't think it is so much a scary trend as evidence of what having a dynamic iris vs not having a dynamic iris means as far as then having to tradeoff lumens with CR, instead of getting both.
--Darin
post #10 of 392
I know people in Sweden have reported a very low black level for this machine. Shadow puppets were hard to see on the screen. With 250 ANSI lumen in the high contrast setting I doubt 4000:1 would lead to such comments. There must be more black level to squeeze out of the projector.
post #11 of 392
That depends on the size and gain of the screen... 250 lumens isn't a heck of a lot of light to start with.
post #12 of 392
Could be in auto iris mode?
post #13 of 392
Thanks for the excellent review Tom!
I have to agree with others and say that I am disappointed in the lumens from this pj. I was certainly hoping for more.
I had originally wanted to go with the Optoma, but their bone-headed decision to market a projector with a 37% vertical offset with no lens shift dashed those plans.
The 37% offset would work for me with 10 foot ceilings. The more bone-headed move to me was having such a long throw. The Sharp's throw is just as long as the Optoma's. It would be about 16.5 feet from my 9 foot wide screen, in a 19 foot long room, with a soffit that extends 14 inches. This would make for a very, very tight fit, if it would work at all.
What's up with this long throw on the Sharp and Optoma?
post #14 of 392
How much can a high gain screen like the Dalite HighPower compensate for the low lumens of these 1080p dlp's? What downside (other than restricted pj placement and viewing angle) is there to the 'highpower solution' to the low lumen problem?
post #15 of 392
It doesn't have an auto iris.
post #16 of 392
Thanks Tom. I am just finishing my review as well. I found similar levels to you. Question, did you take your contrast/light output settings in High Lamp or Low Lamp? I ask because I did mine in High Lamp and found the following:
Light Output:
(High Lamp/High Brightness): 670 lumens
(High Lamp/Medium Mode): 325 lumens
(High Lamp/High Contrast): 268 lumens
(Low Lamp/High Brightness): 506 lumens
(Low Lamp/Medium Mode): 246 lumens
(Low Lamp/High Contrast): 202 lumens
On/Off Contrast:
(HL/HB): 1696:1
(HL/MM): 2722:1
(HL/HC): 3767:1
Note: I did not take measurements for contrast in low lamp mode.
ANSI Contrast:
(HL/HB): 497:1
(HL/MM): 537:1
(HL/HC): 596:1
I do also agree with you completely, the grayscale tracking was extremely good out of the box. I also found the bias wasn't working on mine. I need to adjust it for the low end IRE's a tad, but I could not get it to do anything.
I'll have my report online tomorrow evening with screen shots and such.
post #17 of 392
Darin, I played with the AutoContrast feature...I didn't find that it did a heck of a lot. I could notice a bit of change on the image, but, my measurements did not change at all on any of the settings.
post #18 of 392
disapointing,
Jason's measurements for max lumens is less than the Sharp 12000. It measured like 850 in high briteness and high lamp.
post #19 of 392
Yes indeed. I should also mention I was at the shortest end of the throw with my measurements. I don't know why it is, but the single chip DLP 1080p units are simply not that bright. Granted, that is only part of the equation and they really look phenominal picture-wise.
post #20 of 392
Jason
How's the optics compare to the Marantz 11s1? from Tom's review, the optics of the Sharp is extremely good even better than the sim2 3000.
Mike
post #21 of 392
Optics are excellent. I should comment they they are smooth adjusting as well (no slop in the movement). I saw little CA and was able to focus down to the finest pixel gaps.
post #22 of 392
It appears that the contrast is only slightly better than the HD81, but quite a bit dimmer (comparing Jasons measurements with Guitarmans).
post #23 of 392
I have some good news to report. It turns out that the lens shift affects brightness and contrast more than I thought. When I took my initial measurements it was with the Z20000 on a top shelf. I put it there only because that's where the H79 had been and I was lazy. Tonight I moved the projector down 15" to a lower shelf. This required much less lens shift. I then took my lumens and contrast measurements again, and this time I included measurements from the economy mode as well. I have updated the table in the original review. Both lumens output and CR improved significantly. With zero lens shift they would improve even more. Too bad that this convenience feature has such a performance penalty.
To answer some questions:
The fan noise is worse than the H79, but better than the Sony HS20. I haven't heard the Z12000. I would rate the noise level low, but noticable. The H79 was virtually silent. I hear no color wheel sound at all.
I am using the Vantage HD scaler. It ALWAYS makes HD look better. I haven't checked out the Z20000 without it, but I'm sure it wouldn't look as good.
The Auto Contrast is a mystery to me. It certainly isn't an auto iris and, like Jason, I couldn't see that it had any measurable effect on CR.
post #24 of 392
Tom, I don't know if it is just my computer monitor, but I can't read the updated table at all. Would you be so kind as to repeat the info in regular print?
post #25 of 392
Bob, open the image or save it to disk and view it in Paint/Photo Editor or a similar program. Worked for me with both IE and Opera.
Tom, thanks for a nice write-up.
post #26 of 392
It's not your monitor. I can't read it either.
post #27 of 392
Nor I...
post #28 of 392
If you select the table with your mouse it will let you read it by changing the background color of the table
post #29 of 392
Good news Tom! I only wish my room would allow me to move the unit and redo the shift. I too was a bit disappointed with the light output in high contrast mode. Usually the differences are pretty subtle, but in the case of the Sharp the light output dropped considerable when going into high contrast mode. As Tom stated, and I agree, the Medium Mode was a nice, well, medium.
post #30 of 392
OK, take a look at the table now. My attempts to use fancy formatting was a flop.
