AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sharp XV-Z20000 initial impressions and numbers
Sharp XV-Z20000 initial impressions and numbers - Page 6
post #151 of 392
It was fairly significant, maybe 20%. I didn't experience much interactivity. The saturation seemed affected a little. For example, after raising red Value 20% I had to lower the saturation 1 tick.
BTW, I wonder if you even need a colorimeter for this parameter? Couldn't you just measure the light output of a post-calibration white, use that value as a baseline, and then measure the light output of each of the colors?
post #152 of 392
Interesting it needed that much adjustment. Did you happen measure the Y values for all colors after grayscale tracking but before any CMS adjustments were made? It would be interesting to hear if those were off to, or only off after CMS adjustment.
My hunch is that you could probably adjust the Lightness (Y) of the colors with your AEMC 813 just the same. In fact I'm thinking it may actually even be a tad more accurate that way since as I understand it that meter is better at reading light levels than colorimeters.
As a quick experiment you could measure with your AEMC the values you have now and see if it agrees with the values you get for Y from the colorimeter. Of course your units will likely be different (CF will give you cd/m2, AEMC will give you fc/lux) but you can convert the measurements. If you try this please post back what you find.
post #153 of 392
Thanks for posting on this, Tom.
I'm looking at getting a Da-Lite High Power screen to go with the Sharp 20k. The sample they sent me looks pretty spectacular, at least as much as you can tell from a 6"x6" square. I used a very high tech way of positioning the sample at different points on the screen - a bag clip, twine and a heavy stapler on top of the Firehawk. Gain is about 2.8 optimal (although the sweet spot is small).
post #154 of 392
How much does a bulb cost for the 20K? I've also looked at the Ruby and the $1000 bulb cost has really put me off.
post #155 of 392
$599. Not Ruby shock, but still a harsh slap.
post #156 of 392
BTW, I have backed off my changes to the Value parameter. I initially thought it gave the image more punch and vividness. After I lived with it for a few days it started to seem cartoonish and unnatural, so I decided to remeasure. Although the substantial increases to the Value of the primaries had little effect on their saturation, I discovered that it had a profound effect on the color control in the main menu. So I put all Values back to 0.
Why I can't seem to adjust this parameter correctly is a mystery to me, but the image looks (and measures) the best when they are all set to neutral.
post #157 of 392
I used some of your comments some posts back to adjust the Value parameters, also, and I had pretty much the same reaction. At first, everything had more pop and vibrancy, but it wasn't as natural or pleasing after a while. I put those values back to their default positions. Most things on my Sharp 20k are at default. The color temp I set to 6500 and the iris I set to High Contrast, with Brite lamp mode. The DVI input, I found, works well with RGB Video levels, instead of RGB PC levels. When I first tried switching from PC to Video level, I got a strange scaling shift, where the image overscanned dramatically and other image parameters seemed to be thrown way off. After I shifted to Dot to Dot mode, changing to RGB Video level worked as I had expected it would originally.
I'm awaiting a new Da-Lite High Power screen, which should arrive tomorrow. I found after prolonged viewing that the medium iris, eco lamp mode was robbing the image of some pop. The Brite lamp/High Contrast iris mode combo was more pleasing. I plan to shift back to eco lamp mode once the High Power arrives. There should be plenty of brightness to spare then (it's a 2.8 screen gain, and I should be able to get close to that), and I'll be able to keep the iris closed all the way down.
post #158 of 392
Joe - How's the noise level on Bright vs Eco?
I had a great demo of the Sharp, but could hot determine the noise level with the projector sealed in the back.
If you can compare the to Pearl on low/high that would be familar to me.
I have High Power too, which works best with a mid shelf mount, but noise becomes an issue. The Pearl was fine on low, high was pushing the comfort zone.
post #159 of 392
A friend of mine has the 20K and he said that the unit is much louder in the high lamp mode, disruptively so for his tastes. He did say that the lamp in the normal mode is not very quiet but is acceptable. This of course is very subjective as everyone has different tolerances for pj noise level, and it also depends on how close you sit to the pj.
post #160 of 392
It's definitely louder in Brite mode, but it doesn't bother me where it is now - high shelf mount, at about 7', about 2' behind me and 3' above my head. When I put it down lower for the new screen, it'll go back into low lamp mode, so it shouldn't be a problem. I have never seen/heard the Pearl, so I can't compare. I can say, though, that the noise has never bothered me, in either lamp mode where it is now.
post #161 of 392
That's about right. I find the fan in High mode annoying. In Normal mode it's there but I don't really notice it unless I try.
post #162 of 392
Tom - your comments about the internal processor seems to differ from Greg's WSR review.
Greg's review left me with the impression that the internal processor was less than ideal.
"Scaling quality was unexceptional and could be improved..."
Under HDTV Broadcasting... "Images very slightly softer..."
Any comments?
post #163 of 392
Yes, I know. I stand by what I said. A few points:
1. One of his criticisms dealt with the artifact he noticed on 1080p inputs. I'm using 1080i inputs, so I didn't see this.
2. Much of his criticism of the Z20000's processing (especially with HD material) seemed to be in comparison to the VXP processing he saw in the $20,000 Marantz 1080p projector, which he thought was a little better. I haven't seen the Marantz, so I can't comment.
3. The Z20000 is the first PJ I've seen that didn't obviously benefit from a Realta-based processor (Vantage-HD) that I have been using for several months. That's fairly high praise. I did quite a bit of A/B comparisons and I've yet to find a single case where I clearly preferred the image I obtained with the Vantage-HD in the loop.
4. I ran the Z20000 through the series of tests provided by the Silicon Optics Benchmark DVD. It passed every test, except one: the race track Film Detail test. To give some much-needed perspective, this is MUCH better performance than what you get with the Lumagen HDQ external processor, which Greg reviewed positively in WSR just a few months ago.
5. Some of these judgments are somewhat subjective. For example, I looked at the bobbing frozen branch scene he mentioned in the Montage of Images and I didn't see the jaggies he referred to. That doesn't mean they aren't there. I just didn't see them.
So, yes, all in all, he and I see this differently. I also think that the Sharp's implementation of gray scale controls is unintuitive and very difficult to use, and he barely mentioned this. People see different things. I guess that's human.
post #164 of 392
I think Greg has a (deserved) rock star status here on AVS, but the ultimate judge of these issues has to be our own eyes. I have a Lumagen Vision HDP and I'm really hard pressed to tell the difference between material I watch via 1080i or 1080p from it to the Sharp. I don't have Tom's level of expertise when it comes to measuring these things formally, and I haven't run the battery of tests he has, but I'm very, very happy with the de-interlacing job the Sharp does with both film and video 1080i material. I hope, as someone reports in another thread, that the Sharp will be upgraded to accept and display 24p sometime in March. The judder issue is of course completely separate, but it's one I'd like to see the Sharp be able to handle.
After being with the Sharp for the last few weeks, and seeing more and more shows that I know well from my previous H79 projector, I'm consistently impressed with how much better the image looks on the Sharp. It's the contrast that I'm even more impressed with than the bump in resolution. I paired the Sharp with a Da-Lite High Power screen, so I'm able to take advantage of the High Contrast iris mode. It's amazing how much I was missing before. (And that's not a brightness issue, either. I was running the H79 in High Brightness mode and it has a brighter lamp.)
post #165 of 392
I have some good news to report. It turns out that the lens shift affects brightness and contrast more than I thought. When I took my initial measurements it was with the Z20000 on a top shelf. I put it there only because that's where the H79 had been and I was lazy. Tonight I moved the projector down 15" to a lower shelf. This required much less lens shift. I then took my lumens and contrast measurements again, and this time I included measurements from the economy mode as well. I have updated the table in the original review. Both lumens output and CR improved significantly. With zero lens shift they would improve even more. Too bad that this convenience feature has such a performance penalty.
I just purchased the new Sharp 1080p projector, and I thought I'd post some preliminary numbers and impressions.
Throw and lens shift
The Z20000 is a relatively long throw projector 1.85-2.5/1 screen width. It has a very flexible vertical lens shift of 1 screen height, which means that it is equally well-suited for a ceiling or a shelf installation. By default, the lens aligns with the bottom of the screen for a shelf mount and at the top of the screen for a ceiling mount. Use lens shift to adjust from there. Lens shift works like a charm, but it does reduce light output and contrast, so I'd use as little of it as is practical for your installation.
Tom,
I have done alot of thinking about your lens shift assessment. Sadly I don't have a lightmeter at hand anymore to verify this myself.
Basically you are saying that the "default lensshift position" of the Sharp Z20k is aligned with the top of the screen for ceiling mount - that's how I use it right now (mainly following your suggestion, I never measured it myself (stupid me)). I can confirm that this is the setting my factory sealed Z20k came in - but somehow I doubt that this is the "zero lens shift" position and therefor provides the best optical performance. If you look at the projector lens you can see that this lensshift setting shifts the image as much downwards (relative to the optical path/lens) as possible. IMHO, without knowing the specifics of the optical path, I see this as one of two extreme lensshift settings (it uses the outer parts of the lens). In general the 20k has exactly one full picture height lensshift range.
Isn't it quite logical that aligning the Z20k lens with exactly "half-picture-height" is in fact ZERO lensshift as this exactly centers the picture relative to the lens/optical path? This is true as long as Sharp didn't design and optimize the optical path for one of the "extreme" lensshift settings.
Therefor this "center setting" should provide optimal optical performance, light output and contrast. As mentioned I sadly cannot confirm this by making any objective measurements myself atm. If this turns out to be true (verified by some measurements) I would be happy to lower my ceiling mounted Z20k in order to take advantage of increased performance.
What do you think about it, Tom?
post #166 of 392
Originally Posted by Bulldogger View Post
The projector central review gives some insight. How much lens shift are the guys getting low reading using? According to Projector Central, "One final note on lumen outputthe projector loses about 12% of its light output when the lens shift is set to the extreme ends of the lens shift range as compared to having the lens in the neutral position. That brought the lowest reading we could get from the RS1 down to 340 lumens (low lamp power, max telephoto, max lens shift). So all in all, there is absolutely nothing to worry about as far as the 700 ANSI lumen rating on the spec sheet is concerned."
A post about the JVC RS-1 that had me thinking...
post #167 of 392
I wanted to post some updated lumens numbers and correct a mistake I made in my original review regarding lens shift.
First, after 422 hours of use, here is my updated lumens chart
As you can see I have lost 20% of the lamp's brightness in the High Brightness iris mode and 35% in all other modes. I can't explain the discrepancy. In my case, the result of this loss of light output has forced me to start using the Bright lamp mode. The Economy lamp mode/Medium Iris mode now returns less than 10 FtL on my 100" 1.3 gain StudioTek screen, but in the Bright lamp mode it is still over 12 FtL.
I made a mistake when discussing the effect of lens shift in my original review. I made 2 assumptions, both of which turned out to be incorrect. I assumed that the 20K would ship with the lens shift at its neutral position as the default AND I assumed that zero lens shift would yield the highest light output.
The result of the first incorrect assumption was that, in my original install with the lens about vertically aligned with the center of the screen, I had to use lens shift to move the image down significantly to fill the screen. This led me to believe that zero lens shift was the lens aligned with the bottom of the screen (shelf mount) or top of the screen (ceiling mount). In fact, zero lens shift is the lens aligned with the center of the screen, exactly the way I had it originally. I was confused about this because the 20K does NOT ship with its lens in the neutral state. Its default is with lens shift invoked for either an inverted ceiling mount (lens aligned with the top of the screen) or a right-side-up shelf mount (lens aligned with the bottom of the screen). Sharp must just assume that these will be the most common installs.
Now, when I moved my shelf mount install down about 15" and noticed measurably higher light output, I attributed this to the fact that I had gotten the PJ closer to the zero lens shift position. I think I even wrote that more improvement was possible if I could only move the PJ lower. As it turns out, this was correct, but for the wrong reason. This leads us to my second mistake.
The best light output for the 20K is NOT zero lens shift. Sharp apparently engineered the optics so that the best light output is just where I originally said it would be: an inverted ceiling mount (lens aligned with the top of the screen) or a right-side-up shelf mount (lens aligned with the bottom of the screen). It's just that the lens shift required to accommodate these installs, though it is the default shift and offers the best performance, it is NOT the zero lens shift position. Zero lens shift (my original install) actually gets you LESS light output. Weird, uh?
I hope that this clears up any confusion my original post may have caused.
post #168 of 392
Any update on how to calibrate the XV-Z20000? Mine seem to have way to much blue in the low IRE but I can't do a proper calibration using the Sharp controls. Anyone have access to the Sharp service menu or info about a firmware update that would correct this problem?
Greg Rogers didn't seem to have any problems calibrating his Sharp. Is the problem present on only a few Sharp and not others? Can we find out what firmware version we have..so we can compare?
post #169 of 392
The service menu doesn't help, largely because when entering the unit defaults to the high brightness, high lamp mode, which doesn't translate in any obvious way to the mode in which you are likely to use it.
I was able to get a very flat grayscale by using the RGB adjustments under All Colors to adjust the low end and then the RGB controls under White Detail to adjust the high end of the brightness scale. That's really the only way to do it.
post #170 of 392
Thanks Tom, I was able to calibrate yesterday using the RGB adjustements under all Colors, The black adjustement actually work for IRE below 20 IRE (basically 10 IRE)
Now can you help me with adjusting the primaries? I try yesterday with red and wasn't able to go closer to magenta but not toward yellow. How is Hue, saturation and Tint supposed to affect the primaries. Sorry for the dumb question.
Bruno
post #171 of 392
Bruno:
First, set the user Color and Tint control using a blue filter and blue color bar provided on Avia or the equivalent. The CMS adjustments in the Advanced menu should allow you to move Red hue either towards magenta or towards yellow. On my unit I had to move red towards yellow. What equipment do you have to measure the color points with?
post #172 of 392
I'm using Progressive labs software with the CA6X probe (also know as Opticone).
It's actually quite efficient. You see real time what the control do to the primaries. I will give it another try tomorrow. Maybe I didn't do it correctly.
I have a question. What should I use for primaries measurements. I have access to AVIA (regular DVD version) DVE Essential and Getgray calibration disk.
I've read somewhere that the AVIA magenta is slightly off. Is that the truth? I guess getgray is probably more acurate. Just need to find the disk (move in my new home not that long ago). I'm waiting for my copy of DVE in HDDVD but that won't be until may last time I checked Amazon.
post #173 of 392
Have been able to calibrated my primaries and secondaries with AVIA. I will probably burn another Getgray disk in the next few days to compare. I found the picture better in a lot of scenes and going back to my previous setting show clearly how oversaturated it was. But I found the skin tone a bit to green. My grayscale is flat from 10 to 100IRE between 6350 kelvins and 6500 kelvins. Maybe one of the secondaries is not right on AVIA and cause some bad coloration on skin tone. Maybe it's my test disk as well (CRANK in Blue Ray). I will need to check more movies before I'm sure what I want.
More question. Should I use the enhanced mode in the Dynamic range section? or enhanced should be use only for computers? Watch movie with a PS3, Toshiba HD A1 and TV with SA8000HD. What about brillant colors? What is it supposed to change? What should be the benefits of it? Any info on that subject would be appreciated.
Thanks! Again and again!
post #174 of 392
You can not adjust grayscale by degrees Kelvin. You MUST use dE or equivalent. Degrees Kelvin is worthless.
post #175 of 392
To pick up on what Greg said, the reason color temperature is not a reliable guide to getting good gray scale tracking is that it ignores green.
Before I did anything, I check more than just one film. Sometimes films have specialized color palette.
post #176 of 392
What is the equivalent?
I check in the Progressive labs manual and dE is never mention. I see Delta C? Is that equivalent?
When I do my calibration I use a feature with a blue, green and red bar that display a %. You can decide the colors you want to serve as reference. And you need to move the ajustement of the two others colors to get the proper level. Doing that I get that none of the colors is more than 0.5% above the reference. That should Indicate that I'm ok....right?
Bruno
post #177 of 392
Yes, that's fine. Delta-E is a mathematical expression of deviation from a color standard, in this case D65. The lower the Delta-E the better.
post #178 of 392
For your purpose yes. Just adjust for the minimum delta-C over the grayscale range that you can. The problem with using degrees Kelvin is that it is a correlated color temperature, which means your gray color lies on a line that passes through that same color temperature on the black body curve. But your color may be anywhere on that line, i.e. it may be close to D65 (the grayscale target color) or it may be far away from D65 (too green or too magenta). delta-C is a particular measure of the distance from D65, so that is why you want to minimize it over the entire grayscale range.
post #179 of 392
I tried to recalibrate my primaries with Getgray yesterday. The result were different than the AVIA disk. I now beleive that the colors space may be not well convert by my scaler. I will try today directly from my sony PS3 and my Toshiba HD A1 to see if there is a difference. I thing that Greg was saying that the conversion matrix in the Sharp are almost perfect. If I see no difference, maybe my calibration probe need calibration. Red turn orange when I make it fit the the point on the 709 reference. Any trick to make sure I do the correct thing? My scaler is an Anthem D2. How can I know for sure that the colors space is correct. A expert calibrator would know right away because he have seen many. It's not my case. I never calibrated primaries before.
One more question. If I feed 480p directly to the sharp the colors space from avia and Getgray will be 601? If It goes via the scaler and output 1080p it's now 709 right?
Bruno
ps: I guess I should move that discussion in the calibration forum. I posted there as well. You can answer me there Calibration of primaries for Sharp XV-Z20000
post #180 of 392
OK, I have finally resolved the problem I was having getting the Value parameter right in the CMS.
First, the numbers for the Y of the secondaries I provided in the previous post on this subject were wrong. It really wasn't my fault. I got the numbers directly from ColorFacts, and they had it wrong. Argghh! The intensity of the secondaries is a sum of the intensity of the primaries, not an average. Thanks to Krasmuzik for pointing this out.
Second, you've got to be careful to compare the light output of the color field with an equal intensity white field. So, a 75% color field should be measured against a 75% white field. In Avia, that's the Gray field, not the white field, which is 100 IRE.
Third, if you use a white window, compare that against a color window. Don't compare a white field with a color window or vice-versa.
Here are the updated Rec. 709 (HD) specs.
So you can use a light meter and a white window and color windows to measure the appropriate Value for RGBCYM, which will be a percentage of the measured light output of white.
You'll probably find, as I did, that this parameter (unlike saturation and hue) requires very little adjustment.
