I've been playing around with the Polaroid 2001G. I discovered that is was possible to do an easy plug and play HDD upgrade after reading the Polaroid thread on this forum. So I thought I'd give it a try. The Polaroid comes with an 80gb Western Digital drive. I was able to install a 200gb Seagate, a 250gb Western Digital, and a 500gb Maxtor.
My next step was to move the drives to the outside of the case. I thought making the storage removable would be pretty cool. So I ordered a two foot rounded IDE cable. With it still not delivered yet my impatience took over so I rigged the following today:
- a one foot ide ribbon cable fished through the case
- direct external power cable to power the HD drives
- 500gb Maxtor HDD
- 250gb WD HDD
- 80 gb WD HDD
Not pretty but it proves it does work. When the new ide cable arrives I will clean up the current installation. I also will add a removable drive enclosure to protect the drives.
Here are the pics:
1- the drives
2- the "rigged" IDE cable fished through the case (ugly I know)
3- one of the HDD's sitting on top of the SA8300HD cable box (it's running with the Polaroid).
4- The 80gb drive running the Polaroid
5- The 250 drive running
6- The 500gb running
The recording times shown are at SP (2 hour mode). The 250gb drive is almost full with 51 titles recorded to the drive.
I can pretty much add storage at will.
- 500gb Maxtor HDD
- 250gb WD HDD
- 80 gb WD HDD
Here are the pics:
1- the drives
