AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Is an External HDD possible w/ a DVDR?
Is an External HDD possible w/ a DVDR? - Page 5
post #121 of 313
Originally Posted by nextoo View Post
Here's the case. Cheapest I could find. Most are double the price. It is a SCSI enclosure but this one is cheaper because it does not include the SCSI cables.
http://www.censuspc.com/product.php?productid=637
The IDE male connectors are here:
http://www.pccables.com/cgi-bin/orde...les.com&rcode=
You have to be careful with IDE. There should not be too many connections or excessive cable lengths. Right now I still have the rounded IDE cables coming out from the side of the Polaroid case. I have the HDD removable drive enclosure and the DVD burner installed in the external SCSI case as pictured. Two IDE cables exit the SCSI case out the back panel with male connectors. The rounded IDE cables from the Polaroid are then connected to the male IDE connectors.
Here's a much more expensive alternative for the IDE cables:
http://www.mycableshop.com/itemdesc~...~ic~GC40MM.htm
Hi Nextoo,
Simple question: I am considering externalizing the HDD with the IDE IDE cable that you are using. Where did you get that? The link you provided above was for a male IDE connector; is that only for the SSCI box that you are using? Would any IDE IDE cable do the job?
I was checking out the removable tray IDE drive enclosure box at Geeks.com; one has led and fan, the other none. I have read that you disabled the fan because it wasn't necessary. Is that because the enclosure is now external? IF that is the case, maybe I can get the one without the fan???
Many thanks.
post #122 of 313
Originally Posted by ccgw View Post
Hi Nextoo,
Many thanks.
Everything you say is correct. The short male/male IDE cable was used to create a disconnection point between the external enclosure and the Polaroid. When I was using just the external IDE removable drive rack I didn't need it because the drive rack is light and easy to handle and has the IDE connector right on the back. I disconnected the fan because when using the drive rack externally there is little thermal build up. It was unnecessary. Also, any IDE cable will work as long as it is long enough for your application. You just need to grind down the "nub" and reverse the cable when using it for a HDD.
post #123 of 313
Originally Posted by 6volt View Post
Just an off the wall thought about not being able to see the stored files on a PC:
The Netgear NAS "toaster" SC101 is like that:
SC101 uses SAN File System (SFS) and is not compatible with NTFS, so knowing the differences in file system will help prevent problems on SC101. Others say it uses the Zetera-Filesystem. Maybe these are the same.
What is interesting is that the Netgear is really not a NAS because it only talks to Windows PC's w/installed drivers. Well... that wasn't really what was interesting... What IS interesting is that they DID NOT use a popular file system even when it is clear that the utility of the unit would benefit if they did.
They may have done this because of patents/royalties (guessing), but probably driven by costs. So maybe they shot for the lowest cost solution.
Maybe Polaroid did the same thing.
Maybe the Polaroid HD's would be recognized by the SC101.
Now, wouldn't THAT be amazing.
Tom
________________________________________________
PS. Still reading up on 2001G and is the following is still true?: 1) can't see HD content on PC, and 2) no way to move content directly from one HD to another HD.
PPS. Has anyone tried contacting HD recovery outfits to see if they know anything (of course, they may be very tight lipped.) Of maybe they would offer to convert the HD content for a small fee.
Tom,
I just happen to have an SC101 sitting on my desk(unused at the moment). Your idea got me to thinking.... Actually, I prefer the NDAS system(NetDisk) used by Ximeta. While it may not be a 'true' network drive, it's close enough for what I use my home gigabit LAN for and my main puter doesn't have to stay on when I'm away. All the puters in my home are WinXP based anyway, and I've installed the NDAS client software on the machines that need to access the drive. I recently bought 2 more Ximeta enclosures (RadioShack was having a sale on them before Christmas) for future use. You can now install your own drive. My first NetDisk included a 160Gb drive. BTW, these enclosure could be easily modded and used with the Polaroid I would think - sans the included interfaces. I like nextoo's external black enclosure though way better.
I picked up one of the last Polaroid 2001Gs left in my area(WalMart) Christmas Eve. A present to myself. I had been sitting on the fence for a long time, and just decided to do it. Wasn't sure exactly how I was going to use it, but this thread of nextoo's has given me much inspiration!
Back to your thought on the SC101.... The only thing Polaroid left off the 2001g was an Ethernet port. The inclusion of that would have sealed the deal for me a long time ago. My problem is the lack of time to tinker. I travel for a living and am gone 4 days a week, so all my family and hobby time gets compressed into 3 days! Anyway, the SC101 case could easily be modded with a cable coming out the back and used with the Polaroid. The form factor is perfect too since it is small and includes it's own power brick. Two 500gb drives would give you a tera-byte of external storage. I can already see the possibilities. Now if we could get the Polaroid to recognize the Ethernet port - that would be sweet indeed, but I don't see that happening... We can dream can't we? Looks like I've got a project for the weekend.
post #124 of 313
Originally Posted by redjr View Post
Tom,
Please report your findings!
post #125 of 313
Really great stuff - thanks!
I looked at one HDD I use with the Polaroid using PartitionMagic and the drive shows as unallocated. Works great with the Polaroid. It does not show up as a drive under Windows XP.
I looked at another HDD I use (with the Polaroid) and this one shows as an NTSF drive. I had set up an NTSF partiton on the drive a while back when testing and continued to use it as such. This drive shows up under My Computer. Under properties it shows the proper size and also shows 71GB used - which is correct, there are recordings on the drive. But it shows no files on the drive. I've set up folder options to show everything down to the system file level. Still nothing.
Both the unallocated drive and the NTSF formatted drive work fine with the Polaroid.
Not sure what this means but I thought I'd report it.
post #126 of 313
You guys are really leaving me in the dust with all this computer tech talk.
Ultimately though my take is that we can't get the HDD recognized anywhere other than the polaroid..true?
Keep workin' on it please as this would be an unbelievable asset!!!!!!!!
post #127 of 313
I just wanted to say thanks for all this.
I have been working around the clock, and missed this whole thing.
Thanks Mike
post #128 of 313
Do any of the compatible aftermarket dvd burners (listed in this thread) fit inside the polaroid case? If they wouldn't fit straight away, maybe if the aftermarket burner was dismantled somewhat? I want to repair a polaroid unit but I really don't want the dvd burner to be external.
post #129 of 313
The OEM burner is a standard size DVD burner. So a replacement should fit right in there. I have not done this on the Polaroid but on other DVD recorders the procedure is something like this:
1. Eject the DVD tray. Remove the front face plate. This allows you to remove the drive from the case.
2. Pull the power plug and the IDE cable from the drive. Remove the drive.
3. Remove the face plate on the replacement drive.
4. Install the new replacement drive into the recorder. Hopefully the bracket screws line up. And hopefully the drive tray lines up properly with the front of the machine. They usually do. Plug in the power cable and connect the IDE cable.
5. Eject the tray on the new drive. If you can do this manually fine. If not power up the recorder to do this.
6. Install the face plate on the front of the ejected drive tray. This could be the toughest part and might require a bit of customization to fit right.
The good news is I don't think you'll have to dismantle the replacement burner at all. It should fit right in.
post #130 of 313
Just out of curiosity, will the WD2500 fit in the same place as the WD800 inside the Polaroid 2001G? Could it be an exact replacement inside the unit???
Will the Caviar SE version of the WD2500 work as well?
post #131 of 313
As long as it is a standard IDE HDD it should fit inside in place of the stock HDD.
Be careful as to the capacity of the HDD as described by Nextoo earlier in this thread. I think he was successful up to and including 320gb but had troubles with 500gb. Please search for the specifics.
I use WD250gb HDDs. They can be picked up for a reasonable price at Newegg.
post #132 of 313
Has anyone tried swapping burners in anything other than the mentioned Polaroid? I have a couple problematic Panny machines that don't like most discs put in them, maybe a burner swap might fix the problem.
post #133 of 313
Hello 2001g Fans ,there Is Usb. On The Main Board Inside Of The Unit, Does Anyone Have A Wiring Diagram For Usb Config. ??
post #134 of 313
Yes there is. But it is not enabled in the firmware. The main board that the Polaroid uses is also used by other DVD recorders released in other countries under other brand names. Some of those recorders have USB capabilities as part of their feature set. But not so with the Polaroid.
Packard Bell, Eltax, Denver being just a few.
post #135 of 313
I wanted to rearrange some movies on my HDDs. I have 2 Polaroids. I transferred from one to the other by component connections flawlessly.
Way to much fun!
My wish list includes..
-Burn to DL
-View the HDDs on a PC
-High speed dub from one Polaroid to another
Back to reality....great little unit nevertheless!
post #136 of 313
I'm new to this so please bear with me.
Best I can tell the following is what I need to set an external HDD to my Polaroid.
http://www.geeks.com/details.asp?inv...NCH-DT&cat=HDD
http://www.geeks.com/details.asp?Inv...DE-N&cpc=RECOM
http://www.geeks.com/details.asp?inv...10-BLK&cpc=SCH
http://3btech.net/wediwd25at72.html
If I have something wrong please help me out.
post #137 of 313
Yes. What you list will do it. Maybe order extra drive trays for extra hard drives if you want to add them. I think you can order just the trays without the rack. You'll need two right out of the box. One for your new 250GB and one for the original 80GB that you'll be pulling out of the Polaroid. So you'll be up to 330GB - and counting.....
post #138 of 313
Thanks Nextoo for the quick reply. I appreciate your help very much. Now to get things ordered.
post #139 of 313
Only thing to add is remember you will need reverse the IDE cable which means you'll have to grind off the positioning "nub" of the new cable. Pay attention to pin one - the red line side of the cable. This is posted earlier in the thread.
post #140 of 313
Does anyone know if the HDD from the Polaroid can be swapped with another brand of DVDR and viewed??
My reasons for asking
- I would like to take the Polaroid HDD and plug it into another DVDR that has more advanced editing capabilities. I want it to be simply plug and play. I think this may be feasible.
- I would like the other DVDR to have DL recording capabilities in addition. This is not likely.
post #141 of 313
If the drive has DL capability and it gets its instruction from the drive, not the DVDR, it might work. I haven't read anything that explains whether onboard DVD burners need the DVDR to do its job once you instruct the machine to make a DVD copy. If the drive takes over, and just reads data from the HDD or incoming stream, why not? Sounds like a good thing to test?
If the DL writing instructions have to come from the DVDRs firmware, prob. not a chance since DL writing is more complex...the original firmware would have to be built to write outward from the hub on the 1st (top) layer, then reverse direction and write from outer edge to hub while focusing the laser slightly farther onto the 2nd (bottom) layer. Most likely the DVDR and burner designers prob. didn't add that more complex writing scheme into the orig. firmware for either.
post #142 of 313
Originally Posted by wabjxo View Post
The DL capability is not likely since the firmware would have to be able to write in the normal manner, hub out to outer edge, then reverse that to write from outer edge back to the hub while pointing the laser slightly ahead to reach the 2nd layer. Doubt they included that more complex routine in the original firmware.
Makes sense.
I suppose my only option for DL recording based on my setup is burning to standard disc and loading it onto the computer.
If I can achieve the first part of my question above I would be pleased and I think its possible. I think Polaroid records in "VR" so a similar unit that has a swappable HDD might be compatible.
post #143 of 313
We were posting at the same time. I think Nextoo has tried a DL external burner on the Polaroid without success. But if I could get the HDD recognized in another DVDR with this capability then it might work.
The problem is finding a DVDR that has a swappable HDD, that can recognize the Polaroids HDD and that has DL burning capabilities.
Any ideas?
post #144 of 313
I changed my mind...please read my edited post...it just might be possible, depending on which firmware contains the writing instructions.
I got ya. See my edit above also.
post #145 of 313
That's a tough order to fill. The Polaroid is not DL capable. I did see a post where the HDD can be swapped with the Philips 3455 but you won't gain anything on the editing side.
You can high speed dub Polaroid discs to the Accurian and this does offer better editing (file merge for example) but the Accurian does not have DL capabilities and cannot do a rate conversion dubbing from the HDD to disc.
You can dub Polaroid recordings to the HDD of the Toshiba XS series. And then edit and merge files. You can then do a rate conversion dubbing back to disc in order to fit to one disc. But this is time consuming.
Biggest problem is once you split a recording on the Polaroid you can't merge it back together on the Polaroid.
I think your strategy of an analog copy from one Polaroid to another is a good strategy. Yes there is a generational loss. But your original recording is in HQ from a HD source. And your analog copy is via component. I bet the quality looks pretty good. You might try recording the copy in SP mode that will fit on a disc. Test the quality. This my be easier for a movie for example.
Another thing you might want to consider is making your original recording at a quality that will fit on a disc. SP for example instead of HQ. I use both HQ and SP depending on what I am recording. If I know I want to have portability I'll use SP or SP+. The quality is still very good. I use HQ for things I know I want to archive to the HDD. For example I did an HQ recording of the extended versions of LOTR. I edited out the disc changes ( 6 discs total) and ending credits and now have something like a 11 hour continuous recording at HQ backed up to a HDD. Sounds crazy I know but it was one of those because I could things.
post #146 of 313
[quote=nextoo]
Will the Accurian recognize the Polaroids HDD if swapped?
High speed or real time? What is a rate conversion dub?
Agreed
Yes. It was hard to tell the original from the copy. The picture was a little softer but close. The copy is real time, obviously, so a bit time consuming.
I was worried I might lose alot of quality but I bet this approach looks as good if not better than the Polaroid <--> Polaroid dub and is faster. The problem is that you have to know ahead of time what you going to do with the movie.
post #147 of 313
I have not even opened the case on the Accurian yet. But my thinking is that the HDD swap is more involved. Similiar to a LiteOn 5045 swap. Dubbing a polaroid disc to the Toshiba HDD is in real time. Rate conversion dubbing allows you to burn a file that is too large for one disc onto one disc. The Toshiba transcodes the file down to the right size - rate converts.
post #148 of 313
Alright. Thanks for the Toshiba link BTW.
-With rate conversion is there a quality loss? I assume the answer is yes but is it discernable? This also helps solve the lack of DL issue.
-Your audio out from the Polaroid is R+W to the Toshiba? Optical out also from the Polaroid to your AVR (or TV)?
post #149 of 313
- Yes there is a PQ loss when using rate conversion dubbing. It depends on how much the bit rate reduction is.
- I run one analog audio out of the SA8300HD to the Polaroid and a second analog audio out of the SA8300HD to the TV - the SA8300HD has two analog audio outputs. I then run analog audio out of the Polaroid to the Toshiba. I also run digital audio out of the Polaroid to the TV. My TV allows me to assign the digital audio to a specific input - I assigned it to component input #1 that also has the analog audio from the SA8300HD running to it along with the component video from the Polaroid.
When the Polaroid is powered off the TV gets the audio directly from the SA8300HD analog feed and the component video passes through the Polaroid to the TV.
When the Polaroid is powered on the digital audio from the Polaroid to the TV becomes dominant and over rides the analog audio feed (from the SA8300HD to input #1 of the TV). As mentioned above I have the TV component input #1 set up with two audio feeds - the analog from the SA8300HD and the digital audio from the Polaroid. Being able to assign a digital audio input to different video inputs is a feature of the TV.
With the Polaroid powered off the Toshiba gets a passthrough of both audio and video because I have s-video running from the SA8300HD to the Polaroid (in addition to the component mentioned above). The s-video and analog audio pass through to the Toshiba with the Polaroid powered off - a normal feature of the Polaroid. HD channels are letterboxed but SD channels operate as they should because the video is passing through the Polaroid as s-video (in and out).
When I power the Polaroid on and choose the Polaroid's component input the component to s-video conversion kicks in to the Toshiba and I get a full wide screen 16x9 image to the Toshiba. Also any CP issues that might effect the Toshiba go away. For example I can't record ON Demand without CP kicking in with the Toshiba. With the Polaroid powered on I am able to. The Toshiba is hooked up the the TV via HDMI.
I have seven input choices with my TV so I have a lot of options. For example I have COAX out of the wall to the TV so I can get high def to the TV via its QAM tuner. And a couple other components hooked up to it. I decided on this setup because it requires no A/V switch box, matrix switch, etc. Most components as well as viewing choices are controlled with a universal learning remote - the inexpensive Sony VL600. My concesion right now is I'm not taking advantage of digital audio out of the SA8300HD to the TV.
post #150 of 313
Quite a setup Nextoo. Thanks for the post.
I have read of the controversy about DVD fade or whatever they call it....Is it bad media or just an unpredictable DVD life. This is in part why I like the external HDD setup. Should there be any worries for HDD storage life?
  Back to Forum: DVD Recorders (Standard Def)
