Originally Posted by
John F. Palacio
6 feet. They are standard OSHA cords so you can change it to fit.
Thanks for the power cord info John? Do you know what guage it is (12awg, 14awg??). With 2500 watts it could suck some pretty huge power. Wouldn't each f113 require it's own 20A dedicated circuit? Even with 20A it peaks at 120x20 =2400Watts. I have 2 dedicated 20A circuit outlets but they will be 12 ft away from the subs. I would need 2 power cords that are 12 ft long. Good thick well shielded ones can get expensive.
I have a PS-Audio juice bar with a 10AWG 6ft teflon shielded power cord from b-p-t. Using this I can split the single 20A outlet into several (using the juice bar). The juice bar will be close enough for the stock power cords to reach. But this method would give only 20A x 120v = 2400 watts. Wouldn't this limit the performance of the dual f113s during the most intense bass scenes?
Any thoughts would help.
-Jai
