AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Owners/Support Thread.
Official SVS Owners/Support Thread. - Page 378
post #11311 of 15588
Originally Posted by neutro View Post
That's weird... I would have thought inverting the driver polarity would just invert the phase. Maybe the connection was not good in the first place?
So you fixed one sub and the other got fixed too ??? That's even weirder. Now I'm confused. But I'm really glad you got this fixed.
Apparently yes. No more flapping sounds on both subs now. That is kind of strange though. Maybe I will send Ed Mullen from SVS an email.
post #11312 of 15588
Hmmm. Good point. But...
EDIT: you could test again at a much lower level, where you're absolutely sure not to hear any distortion, to see if the flapping sound is still present on the phone. Or, you could record from the side of the sub to see if it changes anything. It does sound like a flag flapping in the wind; maybe it's just the crest of the high-SPL wave hitting the mic.
Lecter, did you actually hear the flapping on your sub or was the flapping only on your recording?
Done, never heard any flapping w/ my own ears, only vids captured on my phone.
Originally Posted by TheFactor View Post
ROFLMAO, sorry Mantarays but that was funny
Lol. What I'm saying is that I'm pretty sure Mantaray implied he was actually hearing the flapping sound live, not just on his recordings smile.gif
In the hyghwayman's case, either the flapping sound are there but drowned by other sounds, or the flapping sounds are just an artifact of phone recording.
It's all my phones fault.
Originally Posted by mantaraydesign View Post
Gentlemen, alright and maybe some Ladies.
My problem with the flapping sounds are fixed or completely gone!!!
Ed Mullen from SVS helped me to solved the flapping sounds. I no longer need to turn down the Trim Level on the receiver anymore. These Pluses sounds so good now that I wanted to turn UP the Trim Level. LOL!
What a difference the Pluses sounds now!!
Do you want to know what was the issue that made the flapping sounds?
That is so cool to read your issue has been resolved, Hip Hip Hooray!!! cool.gifcool.gifbiggrin.gifcool.gifcool.gifcool.gif
I will get back to you NEXT YEAR. LOL!
Very funny, you got me eek.gif I can no wait that long.
post #11313 of 15588
Originally Posted by JimWilson View Post
Neither am I.
The DSP tuning SVS employs should handle that circumstance, irrespective of what any gain is set for. When the driver reaches its limit - no matter how it arrived there - its reached the limit, at which point the DSP steps in and says 'no more for you'. That should always occur before the driver starts making unpleasant sounds. As I said before, SVS is famous for their approach to limiters. While I suppose anything is possible, I still have a hard time believing it's being breached.
Then SVS should review this problem and offer a solution to all those affected by this problem ...
It is strange that this is happening, I had a PC13 dsp (sold it because I liked more the PB12 + box format) and not toward the noise. Then on the PB12 + dsp something wrong But which?
post #11314 of 15588
  • I think Mantaray could clearly hear the flapping noises.
  • It could be that the sound from the rest of the setup is masking the flapping sound. I know I for one was straining to try to listen to any flapping sounds, but my ears were already ringing from the sheer output from all other speakers.
  • It could indeed be the shockwave from the drive at close range, hitting the phone mic, that causes that sound. In my case the phone was not directly in front of the driver.
Actually one is the effect of the shock wave with the microphone of the phone and another very different than I to 2 m away listening. It really sounds as if the driver hit with something in the area of the coil ...
When I step back and sledge amp volume, I can get a lot more tour and not hear any of those noises torn on the driver.
post #11315 of 15588
The problem was one of the Plus wiring was not connected correctly within the amp. The black wire and the red wire was not connected correctly. I just had to switched them around and all is good!
What I do not understand is why would it effect to other Plus? Because the other Plus wiring was fine or correct. For some reasons, the flapping sounds was produced on both subs. Is it because I am using the Y adapter?
So if you have the flapping sounds like mine, you may want to open up the amp and see if the wiring is connect correctly. The red and black wire.
You mean the cable connecting the amplifier sledge, or the cable that connects to the subwoofer driver? If the option I would have seguna difficult to reach with arm up inside.
post #11316 of 15588
The cable that connects to the Sledge amp. Here is the picture of the Sledge Amp. Look at the 2 RED circles.
Please click on the image to enlarge so you can see it better.
Edited by mantaraydesign - 8/8/13 at 2:46pm
post #11317 of 15588
Now that these Pluses working properly, they don't even break a sweat at extremely high reference volume.
Thanks to Ed Mullen at SVS!!
post #11318 of 15588
all that did was reverse the polarity...you basically had one sub out of phase with the other and they were cancelling eachother out. I have herd subs make wierd noises before when they were out of phase, so that makes sense if your pluses are co located.
post #11319 of 15588
You are most welcome - I'm glad the subs are performing great and are now exceeding your expectations. cool.gif
post #11320 of 15588
My first pb-12 plus was sent to me with the wires backwards also. My avr was telling me it was out of phase and i called svs and they said that can happen and not to worry. Then had an amp issue and when i got the new amp i noticed the wires were put in backwards. I switched them and boom my avr now said it was in phase. It seems svs might have an issue with making sure the speakers are put together right. eek.gif
post #11321 of 15588
So it that picture showing correctly wired or incorrectly?
post #11322 of 15588
Maybe it was someone new on the assembly line . I know my PB12 plus and PB13 Ultra with the bash amps going on 4 years old have been flawless knock on wood !! They get a work out at least every other day and are on or on stand by everyday .
post #11323 of 15588
It is showing correctly wired.
post #11324 of 15588
No idea. The next two i bought (a 2nd pb-12 plus and a pb-13 ultra) both came set up right and work perfect. I love the subs biggrin.gif
post #11325 of 15588
post #11326 of 15588
Yes!!! That's it. I figured it out in my car so you beat me to it biggrin.gif
Those poor PB12s were battling each other and just working very hard to cancel each other out.
I guess the shockwave can create similar-sounding flapping sounds if your camera is in front and close to the woofer, so beware when taking movies of your sub.
post #11327 of 15588
I'll check the connection cables.
But I have the impression that my problem is different from a simple wire positions inside out.
Please, I beg you read one of my appointments with the problem I exposed. rolleyes.gif
A hug
post #11328 of 15588
post #11329 of 15588
Well, I just opened my PB12 + and effectively were poorly connected cables.
Usually SVS makes a review of their products and is signed on the serial number label on the subwoofer. My subwoofer is not inspected.
Thanks to this, my PB12 + has built-in functions PB13/PC13 models only and SB13.
And finally, put some pictures of the construction quality of the subwoofer and to make sure that the driver is properly connected to the wires.
You can see that the center bass reflex port is a bit longer than the rest, what makes me think that if I connect a port (16Hz) Is it better to plug into one of the other two ports, left or right?
I think my subwoofer was finished last minute Friday.
The technician was thinking about the cold beer and the weekend party and therefore led to a bad connection, one more dsp loaded with features and lack of final inspection.
Edited by Lecter83 - 8/9/13 at 3:12am
post #11330 of 15588
Can you be quiet, actually my PB12 + was not connected inside the amp. This later proves to gain maximum sledge 0 and see if the problem is fixed. smile.gif
post #11331 of 15588
Hi Lecter, can you tell us exactly what was wrong with the cable connection? Was it simply that the black and red wires were inverted? Or was the connector loose? If it's only a polarity inversion, it seems a common issue, and I would have thought that would lead to problems only when trying to integrate dual subs (which you will have to do shortly though).
SVS subs are made in China. I guess making them transit to the US to be inspected before shipping them to Europe would add even more to the cost.
That one is funny, a second PEQ for free. The bizarre thing is that the amp correctly tells you this is a PB12-Plus though.
That is a very interesting observation and a valid question! Is the port volume really larger for the center port? Is the situation the same on PC12-Pluses and Ultra models? Which port should be plugged when using 16 Hz tune? I guess in a PB12-Plus it's easy to simply plug the center port -- it will look symmetrical and it's easy to locate. On the PC12-Plus, the ports are arranged in a circle. Which one is the longest?
Apart from reversed polarity and the bonus PEQ, it looks alright to me. Reversed polarities are relatively frequent it seems. CR had the same problem when trying to integrate his two PB13-Ultras. Because of that, I made sure playing both my Pluses together actually raised the SPL level before going further in the setup.
That was lost in translation I think biggrin.gif I'm pretty sure you'd have noticed before if your amp were not connected biggrin.gif
post #11332 of 15588
Thanks for sharing those great pictures and video. You asked a good question regarding which port to plug at 16Hz Mode. I see most people plug the middle port but does it really matter which port to plug to get the best performance?
post #11333 of 15588
It may be a language issue; he's admitted to using a translator program, so perhaps his original message wasn't converted properly. Hopefully that's the case anyway...
post #11334 of 15588
eek.gif This is what is not being able to speak English like god and use google translator to communicate in this forum.
Thousand apologies and many times more than I will have to ask.
Actually I meant that the wires were placed with reversed polarity. rolleyes.gif
I believe that if one has to close a port to work on 16Hz, it will have to shut down or left or right. The longer is the port, the lower the tuning frequency (at least that's what I think).
Now I will respond to Neutro post, I will take a while and something long, but I'll clear some doubts. Well in my hands and were all models of SVS (NSD, Plus, Ultra) and teach as the Plus is the only one that has a large port. biggrin.gif
post #11335 of 15588
Originally Posted by Mongo171 View Post
LOL!
In a way it is not really funny because for the price ($1400) people pay for these, these should have the highest quality check (QC) before shipping them out. I am surprise because the incorrect wiring did not damage the driver or the Sledge amp.
Another thing is that SVS told me that they had to open the sealed box for ANOTHER inspection before they ship these subs out. And the wiring is STILL not correct. So why did they open the sealed box for a final inspection again???
Both of my Pluses came to me with boxes opened. They only taped the center of the box. They told me they had to open them for final inspection. So I don't know what to tell you about their quality check at SVS.
post #11336 of 15588
I think what Lecter wanted to say to Ed was simply "nevermind", as in "no need to answer that", which I see could be distorted into "you can remain silent", then further into "you can be quiet", or as a request, "can you be quiet".
post #11337 of 15588
....That one is funny, a second PEQ for free. The bizarre thing is that the amp correctly tells you this is a PB12-Plus though.......
So is it as simple as getting a free extra PEQ, or is it a more serious issue of the wrong DSP programing being used for driver (PB12+ vs 13U)?
post #11338 of 15588
Good question indeed. The wrong DSP programming could certainly push the Plus driver closer to its limits. I just don't see how that can happen though with the amp identifying itself as a "PB12-Plus".
post #11339 of 15588
Hi.
The cables were connected reversely. Where you need to go +, was connected - and where I had to go on - I was connected +.
But even so, I'm afraid not to solved nothing. The continuous noise in some scenes of some movies, if the gain is at 0 sledge. mad.gif
In all I had of SVS subwoofers, both NSD (Bash and Sledge) and PC13-Ultra Sledge in etiqueda with the serial number, the signature of the person who reviewed and in all cases has been one "DM ".
PEQ and a few more functions that possess ultra models. All in my PB12 +. It was Friday and the technician was about to taste the first beer of the weekend. Hahaha is an ironic way of speaking, is a joke. biggrin.gif
No, not the same. My previous PC13-Ultra sledge had the same size for all ports (inserting a jack then no matter where the foam). My previous PC13 is spoiling the amp and I had to replace it, leave a picture to verify that all ports have the same length ...
Now a photo taken from Audioholics and another from another forum. Is inside the PB13-Ultra and 3 shows that the ports have the same length...
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 75
In my case, just a subwoofer. Over time will be two, but you have to wait for the gift (hopefully soon). biggrin.gif
You can not imagine what it costs me to communicate with you all. muhahahahaha biggrin.gif
Edited by Lecter83 - 8/9/13 at 8:18am
post #11340 of 15588
"you can be quiet"
thanks
