AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Owners/Support Thread.
Official SVS Owners/Support Thread. - Page 437
post #13081 of 15588
What happened to the sb12's? The SB 1000 and 2000 look cheaper.. So the only way to get a nice gloss sub is PB12 plus or PB 13 ultra?
post #13082 of 15588
Read my recent posts for info on this
post #13083 of 15588
Some of us like cheaper.
But the "nicer" finish as an option is a great business move.
post #13084 of 15588
I read it but am not sure what you mean. Could you clarify?
post #13085 of 15588
It means "The president of SVS has informed me that they will be selling a piano black SB-2000 shortly."
Not sure what's difficult about that. Perhaps you could clarify what points you would like more detail on.
Edited by Sdiver2489 - 1/16/14 at 4:14pm
post #13086 of 15588
WTH - so the rest of us who want a P(iano) B(lack) PB are screwed? That sucks.
post #13087 of 15588
When has the PB12 non plus/Ultra ever been available in piano black?
post #13088 of 15588
I did not see this quote even though I had scrolled back. I appreciate the info but honestly I don't know what was so difficult about just repeating it without the attitude.
post #13089 of 15588
never - but since they will be making a SB in PB, why cant the PB get in on the PB love too?
post #13090 of 15588
No offense meant...was legitimately confused with what I might have misstated of been misunderstood on. My apologies if I came off harshly!
post #13091 of 15588
I think its cost due to the larger cabinet
post #13092 of 15588
Even if it did cost more, I'd think SVS would offer it and pass the price on to the consumer.
post #13093 of 15588
Perhaps it has to do with a combination of cost and quantity. If they offer a gloss version then they would lose quantity on the black oak and might have to increase both prices.
post #13094 of 15588
So whats the difference between the 2000 and pb12 nds?
post #13095 of 15588
Is the black oak veneer wood or vinyl? The ultra is wood is it the same on the .000
post #13096 of 15588
vinyl
post #13097 of 15588
SB-2000
post #13098 of 15588
I'm in the market for a new sub and it's now narrowed down to the new SB or PB2000. Despite my research thus far however, I'm having a little trouble coming to a decision between the two. Getting 2 of each is not an option for me.
My room is a rather difficult one perhaps. It is 15x15 with 18 foot ceilings and it opens up into the kitchen and also the large hall/foyer.
It will be used 60/40 for home theater/music.
Now I'm not the type of guy that needs or wants sheer output or objects rattling off shelves. I would rarely set volume at reference levels and certainly not when my wife is home smile.gif
Good performance at lower volumes would be something I can use.
I do enjoy defined low extension and am particularly bothered by 'boomy' subs. So a tight, 'musical' sub, whatever that really means, is a must.
Would you think the SB2000 is sufficient for my requirements? Or should I go for the PB?
As far as WAF is concerned, the SB can be tucked away in a corner, essentially out of sight given my present setup, whereas the PB would have to be visible at the other corner of the room. Not a primary consideration but still a factor.
Insights would be welcomed and appreciated.
post #13099 of 15588
15 x 15 x 18 AND opening up to the rest of the house? I would do the PB2000 unless you want to do all your listening in the near-field.
post #13100 of 15588
Agree with sdiver. 4,050+ cubic feet is too much volume for a small sealed sub or two to fill. Even at below reference volumes you will be looking at much less output in the lower octaves with the sealed.
post #13101 of 15588
The amp is new and beefier at 500W RMS (vs 400 for the NSD). Not sure if the driver is new. Anyway you can probably count on +3 dB max output in the 20-80 Hz range. The finish is also changed evidently. Matte charcoal vinyl has been replaced by black oak-patterned vinyl. Not sure but I think the grille has undergone some tweaks too.
post #13102 of 15588
I think they're saying the driver is newly designed as well.
post #13103 of 15588
Ad said new driver.
post #13104 of 15588
Well thanks to you guys, I have officially blown my subwoofer budget. I bought my house with intention of getting a simple sound bar, than a deal on Polk M60s came on newegg and decided to do that, before they even arrived I cancelled the order and bought Polk RTiA5s, CSiA6, and FXiA6 which will all be powered by a Pioneer Elite SC-63. Completely blowing my old budget out of the water I wanted to get a sub under $200 to at least easy the pain but instead I read that two subs are better so bought two Polk PSW505s. Well after reading up a little more now those are going back and I am now ordering two PB1000s. Before I was no way in hell spending money on one PB1000, now I am buying two....this is worse than my modification of cars! But cheaper as modifications for a Dodge Viper make the PB1000s look like an oil change, so that is kind of nice! haha
The TV purchase was not any better, was looking for a cheap $1000 60 inch, ended up with a 65 inch Panasonic VT60... now I just need to finish the floors and move all this stuff in.
post #13105 of 15588
post #13106 of 15588
Originally Posted by Sean Spamilton View Post
Good to be here, who needs money!
post #13107 of 15588
BTW, before I do make this purchase...what has more output
Dual PB1000 or a single PB12-NSD? are the Dual PB1000 worth an extra $250? Aesthetically I like the dual setup more but if I get more for less, than I won't mind.
post #13108 of 15588
I think in terms of output dual PB1000's are about the same as a single PB12-NSD. I think the NSD has about 3 dB on the 1000, and adding a second bridges that 3 dB gap. I'm not sure what the equivalence is in terms of impact--ability to pressurize the room and hit you in the chest. Maybe that's a question I have as well--will two 1000's have the same "hit you in the chest" factor as a single NSD?
All else being equal, duals have the advantage of evening out the bass, too. That might be worth the cost right there. I know I have some room modes. Of course, that comes at the expense of space and the WAF.
post #13109 of 15588
Svs says the dual 1000 will yield more output
post #13110 of 15588
Ah, really? By how much, do you know? I'm guessing it must be in the 1-2 dB range. As I stated in my post, I was thinking it came out fairly close.
