AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official SVS Owners/Support Thread.
Official SVS Owners/Support Thread. - Page 254
post #7591 of 10579
I have seen your post that "a single SB12-NSD can hit ~92 dB @ 20 Hz @ 2M GP per CEA-2010" and also a post comparing 2 SBs to a single PB, where it wasn't clear to me whether the 2 SBs were assumed to be co-located or not.
Could you please provide further detail concerning the output differences between a single SB12-NSD and a single PB12-NSD? If you have them, graphs would be great. Or if not, output (or output differences) at various points, 25Hz, 30, 40, 50, 70 perhaps.
Would also be very interested in any data/description concerning differences in the distortion realm, between the two subs.
I am assuming that group delay looks much better with the SB12-NSD.
Thanks in advance for any help.
post #7592 of 10579
Why is having that info so important to you?
post #7593 of 10579
I'm sure Ed has all that info. I know he's gone over info like that with different subs for me over the phone.
post #7594 of 10579
Originally Posted by mantaraydesign View Post
For the PB12 Plus, are you leaving everything in the default settings?
• Volume (dB)
• High pass filter adjustment (disable/enable, frequency, and slope)
• Low pass filter adjustment (disable/enable, frequency, and slope)
• Phase setting (degrees)
• High pass delay (milliseconds)
• Room compensation (disable/enable, frequency, and slope)
• Subwoofer tune (sealed, 16Hz, 20Hz)
• Parametric EQ (PEQ) 1 and PEQ 2 (frequency, level and Q for each)
The Volume adjustment is the ONLY thing I understand. The rest of the adjustments....WOW!!!! lol
I have the receiver Onkyo TX-NR905. It does have the Auto Test feature. Should I just use the 905 Auto Test feature and leave all the settings on the PB12 Plus alone?
Basically, yes, most of the time, people should just leave everything else alone, everything should be disabled on the sub. Start off with 20 (default) as the sub's gain/volume. For the subwoofer tune, the default 20Hz setting is good for most people unless there's a specific goal that the customer wants to achieve (the tuning mode gives you a tradeoff of bass extension over high output)
You should take care to run the Audyssey correctly, there's some good guidelines how to do it right in the Audyssey setup guide in the receiver forum.
Lastly, you might need to make one adjustment AFTER you finish Audyssey setup. That means going in and adjusting the receiver to pick "Small" for the speaker type. The Audyssey guide gives advice about why to do that as well.
post #7595 of 10579
warpdrive-
Thanks for your advice!
post #7596 of 10579
Originally Posted by neutro View Post
I never saw a PC in person, only in pictures. They look good. So they have this black velvet sock right... So... what's underneath?
A monster of epic proportions
post #7597 of 10579
Because when considering ID subs, it isn't feasible to do side-by-side listening tests in my own room, since I don't care to pay for roundtrip shipping on the 3 subs I've narrowed things down to. That reduces me to buying based on (hopefully) reliable measurements (such as audioholics').
post #7598 of 10579
While I have Ed on the line... just a quick comment about SVS's website and the process of shopping there. It's really well done and all but there's one thing missing in my opinion: pictures that give a sense of the size of SVS's various offering. They're all shot alone on a uniform or nondescript background. It would be very interesting to 1) have a few pictures of the subs next to familiar objects to give a sense of size and 2) maybe a familiy picture to see the relative sizes of all the subs.
For example, fantasizing about a PC, I see myself upgrading from my SB12 in the future. But with which should I go... judging by price alone, the process is like, the PC12-NSD would be an upgrade but the smallest upgrade possible, and reselling the SB12 most of the cost of the new sub would be recovered. The PC12-Plus is quite a bit more expensive and would probably provide a much more contrasted upgrade. Then again, in this price range, differences of a few hundred bucks are hard to grasp, so why not go for the PC13-Ultra and be done with it.
Then the sheer size and weight of the thing makes me wonder if it's really a good idea (vs. dual NSDs for example, which would be more manageable and almost the same price). My point is that a pictures are worth a thousand words, and even though your pictures are great, they don't help much when trying to decide which sub to choose. Just my $0.02...
We're working on it! We'll have some perspective lifestyle renderings coming for each product page which show the SVS size relative to a room with normal furnishings, etc.
post #7599 of 10579
Correct - dual colocated subs will add 6 dB. If they are separated, the amount of gain depends on the modal response of the room, but is typically 3-5 dB (depending on the frequency).
Audioholics tested the PB12-NSD and has the CEA-2010 data posted in table form. They are also testing the SB12-NSD - but it's not posted yet. But Josh's data is very close to ours for the SB12-NSD.
Below is our 2M GP CEA-2010 (distortion-limited) output data for ONE (1) SB12-NSD. For dual colocated SB12-NSD, add 6 dB to these values. Values rounded to nearest 0.5 dB.
Freq/SPL
16/88
20/92
25/96
31.5/101
40/105
50/106.5
63/108
80/108
Comparing to a single PB12-NSD, you can see dual SB12-NSD outgun it down to about 32 Hz, and then fall a few dB short at 25 Hz and about 5-6 dB down at 20 Hz.
Can't cheat the laws of physics, but a pair of SB12-NSD rips really well in smaller rooms, and has lots of mid-bass punch, with really good articulation.
post #7600 of 10579
Freq/SPL
16/88
20/92
25/96
31.5/101
40/105
50/106.5
63/108
80/108
Thank you VERY much, Ed! Are there any distortion data you can share for the SB12-NSD vs PB12-NSD?
post #7601 of 10579
PB12-NSD data is posted in the Josh Ricci AH review. Below is our %THD data at the CEA-2010 passing SPL - rounded to nearest 0.5%. No surprises here - typical sealed behavior and this woofer stays in really good shape at the CEA-2010 limits.
Freq/SPL/%THD
16/88/16
20/92/18
25/96/21
31.5/101/12
40/105/8
50/106.5/5
63/108/3
80/108/3
post #7602 of 10579
Thanks Ed. I am soon to join the SVS club as my SB12 should be here tomorrow. Like you said ' can't cheat the laws of physics' but with your DSP, the FR, db and distortion numbers seem to be as good as it gets for a 14" cube seal sub. Do you know when AH review will be posted?
post #7603 of 10579
very nice performance output and distortion numbers for the SB12. If you want a 14" cube sub, it's a no brainer to choose the SB12
post #7604 of 10579
One question Ed: is the SB12-NSD an upgrade version of the SB12 plus? What are the differences? Thanks.
post #7605 of 10579
Probably won't be too long - I would ask Gene though to be sure. I know Josh is super busy and in high demand (he sets the bar IMO).
Yes, we're very happy with the overall performance envelope of the SB12-NSD - look at FR, deep extension, max output, and THD levels and it's a really solid package for a 14" sealed cube. One thing not shown by the above numbers is behavior at the limits. The dual band DSP limiter/compressor is extremely sophisticated and exceedingly transparent - this sub is very graceful at the limits.
post #7606 of 10579
The two subs are virtually the same size and the woofers are comparable in overall capability (the new woofer is a bit better in overall linearity). The main improvement with the SB12-NSD is the Sledge STA-400D DSP amp. It has a bit more power than the SB12-NSD amp, but the major upgrade is the DSP chipset and tuning software suite.
post #7607 of 10579
Freq/SPL/%THD
16/88/16
20/92/18
25/96/21
31.5/101/12
40/105/8
50/106.5/5
63/108/3
80/108/3
Thank you so much, Ed!
post #7608 of 10579
Please report back once you get it. Yes, it really does seem to set the bar for what can be done for $700 and in a small package.
post #7609 of 10579
Yup. As an owner of the SB12nsd. I have never heard it make a bad sound during intense program material. The transparency of the DSP/limiters is remarkable.
post #7610 of 10579
The smarts of the amp was probably the deciding factor for me choosing my sb13-plus over the competition. It seems to be un breakable. Never gets distorted.
post #7611 of 10579
Just ordered the sb12-nsd. This will be an upgrade from my onkyo 10" htib subwoofer so I expect quite an improvement. I almost got the emotiva x-ref 12 but I was able to get a great deal from svsound by buying b-stock and they let me choose slow/cheap shipping to hawaii. I was also swayed by svsounds great reputation for customer service and the 5 year all inclusive warranty. Originally I was going to get something like a hsu vtf-2 mk4 but I really wanted the sub to fit in my cabinet where the onkyo htib sub is currently residing and the sb12 fits perfectly.. plus it's going in a bedroom so I'm not sure I really needed a dual ported 12" with such a large enclosure. Anyway I'm looking forward to receiving it
fyi fun fact: shipping from hsuresearch was $260 for fedex, $40 usps from svsound(to hawaii)
post #7612 of 10579
Your gonna love it! It amazes me more and more each day!
post #7613 of 10579
Originally Posted by brian6751 View Post
The smarts of the amp was probably the deciding factor for me choosing my sb13-plus over the competition. It seems to be in breakable. Never gets distorted.
so true. It NEVER makes a bad sound. Just really tight bass. I drove mine pretty hard to test it and it was almost moving itself off the platform it was sitting on.
post #7614 of 10579
Ditto with my previous PB10-NSD and PB12-NSD subs - they never made a bad sound.
post #7615 of 10579
Is it bad for the amp or sub if the limiter always goes off? My sub is pb12nsd. Volume in the sub is 10 o'clock and -6.5 in the avr (denon 1910). Thanks
post #7616 of 10579
I would try setting at 9 o'clock and re-running Audyssey.
post #7617 of 10579
you might be pushing the sub past it's limit. I would call svs.
post #7618 of 10579
I was reading the manual for my sb12-nsd which is still shipping.. it recommends using a single connector rca cable and then using an rca y-splitter adapter to connect it to the subwoofer. I read elsewhere this makes the subwoofer louder.. is that true or a myth? Also, my receiver has two subwoofer preouts.. would it be even better for me to run a normal rca cable from these two preouts, one male plug in each subwoofer preout to the subwoofer? I know those two outs are mirrored on the receiver
edit: it's so cheap that I just ordered the cable and adapter already from monoprice
post #7619 of 10579
... using an rca y-splitter adapter to connect it to the subwoofer. I read elsewhere this makes the subwoofer louder.. is that true or a myth?
It's true.
I ordered the exact same Y splitter from Monoprice about a week ago and tested output switching from a single connector to the two connectors from the Y splitter and it was substantially louder.
Following re-calibration, I thought my PC12-NSD sounded better, though I did not spoil the potential placebo effect by rigorously testing this.
Actually, I bought two Y splitters and connected the other to my cheap KLH KSUB10 with comparable results.
My new home made sub riser certainly improved the sound of the PC12-NSD.
post #7620 of 10579
Are you talking about using a splitter even if you have only a single subwoofer? I don't see any reference in the sb12-nsd manual to doing this. They mention a splitter when using two subs, not one.
http://www.svsound.com/images/svs/do...nsd_manual.pdf
