I'm currently running a PC12 and PB12 in my setup. My room is 25' by 35' with 8' high ceilings. The PB is located between my center and right front. The PC is located by my main seating area to the left about two feet from the side wall. I have level matched both subs and am running them 3 db hot from the center channel level. I am getting good bass performance. But I have noticed that on some intense LFE scenes the red light is coming on on both. Both sub's gain is set around 10 o'clock.
Here's my question. I'm thinking of adding a third sub, another PB12 to place between the left and center. Then move the PC12 directly behind the main listening position. It will be about 8 ft from the back wall, but when I do a sub crawl I'm getting good a response from that spot. I know 3 subs in a setup can sometimes be a negative, but I'm thinking it could help lessen the burden on my other two subs. Any thoughts?
But one of my ex-neighbors complained whenever something played on my crappy Creative 5.1 computer system. The sub was the size of a cantaloup and I guess it was 40W RMS -ish. Lighter than the SB12 driver alone. So whether you can use the SB12 freely or not will depend much more on your neighbors and apartment structure than the sub itself, in my opinion.
) half; and
