Thanks for the compliment! You know, I didn't really give it much thought when I placed them there... it was more for aesthetics I suppose. Maybe i'll move them...
The situation is superbly inextricable here. The tip of the 1/4" phono plug, along with the plastic ring that comes just before it -- are in the bottom of the input socket, past the flexible metal retainer, in awkward positions. Removing the cover of the BFD I could insert a thin mini-screwdriver in the back of the input socket and make them move but I can't get enough leverage to push them out past the flexible metal bit. Well I can use the second input/output for now...
It's all over the place lol. I tried taking 3 measurements across the couch. The one in dead center is the worst, with two gigantic nulls. The good news is that it's not really a seating position (it's a 2-seat couch and the measurement was right in the middle). This happens to be the exact center of the room in the two axes so no wonder there are nulls there. The situation is slightly better on the right and left positions but there's still peaks and valleys (and, surprisingly, huge nulls above my crossover frequency
). The peaks and valleys are not exactly the same on each side and it appears REW cannot average measurements, so I tried EQing for the "most likely" seating position. REW did relatively well I think, except that one PEQ used to tame a peak on one side created a big dip on the other side.
No joking -- it should really help with that kind of problems. I can't wait now.
I reckoned about 3 feet for the TV stand and another foot for the center speaker, plus the TV would hang down a bit from the midpoint of the mounting bracket, so 5 feet seemed OK at the time.
On Monday I ordered a bunch of blu-rays for about $10 each, including a few 5-stars and otherwise bassy movies (Hot Fuzz, Clash + Wrath of the Titans, The Raid: Redemption). I'm curious to test sealed mode mostly to see if 1) I can have real output much below what I was getting with the SB12 and 2) if I can actually notice it or tell if the Plus sounds different when sealed.
We'll walk you through a solution, I'm 100% sure. First thing first; you say your receiver has no sub EQ and the LFE level goes from -12 to 0 dB. Can you give us the model? I'm trying to see what kind of bass management it is capable of. If your LFE level is restricted to that range it's mainly to attenuate it in case it's too boomy; set it to 0 dB and make your adjustments through the sub itself.
) -- please don't be offended Lecter, English is not my first language either, so I know how it is, I just think SVS should rename the boring-sounding "20 Hz mode" to MEVM.
