You could also add another Plus... That would provide a bit more output than replacing the Plus with an Ultra. Of course you could also go all the way to dual Ultras right now too
I often listen to that level or a bit lower when my daughter is sleeping and I'm listening with my girlfriend. Alone my target volume is more -15 to -10 dB. Note that chest thump will only happen at higher volume anyway.
rather they're high-sensitivity 4-ohm center / mains (LCR) using 3x 12" woofers. The Catalyst are powered (1000 W each) while the JTR are passive (up to 1600 W RMS each). I bet *those* produce chest thump
Well of course a couple of Submersive would probably do an amazing job
