Originally Posted by neutro
They're not in the same league. They do have the same amp but as said previously, the SB13 is sealed, meaning it needs much more power to move. The benefits of a sealed design is mainly size, and a gentle roll-off at the low end that can be amplified by room gain. But the PB13 or PC13 will wipe the SB13 in terms of sheer output at 20 Hz, and as a bonus, they indeed can be sealed if needed. Your current PB12-Plus will in fact have more output at 20 Hz than the SB13-Ultra. Not that the SB13 is not a good sub: in fact I was quite tempted to go with dual SB13 instead of dual Pluses for a smaller size and more appealing aesthetics. Also because the SB13's gentle roll-off would be amplified quite a bit in my small room (whereas the response below tuning on ported sub drop much faster; then again I settled on the Plus because it can be variably tuned, like the ported Ultras). I personally don't see anything different with music between ported and sealed. Thus if you want to go Ultra, the PB or PC is probably the best choice for you as you need as much output as you can.
Then again, another interesting choice would be to run duals. Dual Pluses would get you a bit more output than a single Ultra, and smooth out both the frequency response and bass uniformity in your room. Ed Mullen from SVS pointed out that buying duals is generally recommended over buying a sub twice as much expensive. However dual Pluses are indeed quite a bit more expensive than a single Ultra though.
Why is it every time this guy jump into my discussion, that I always feel BROKE!!! In my mind, all I can see is BROKE!!! LOL!!!!
Can someone please take this guy out of this forum please!!! LOL!!!
I am just kidding with you. Thanks for your great advice as always my friend.
The Onkyo 818 (MultEQ XT32 capable but without SubEQ HT) is $400 off right now at canadian BestBuys, and I might have a buyer for my Pio 1020. One thing that makes me hesitate getting a new receiver is that I'd still need a BFD/MiniDSP if I want to introduce a house curve. Maybe I won't feel like it after seeing what XT32 can do.
