Maybe.
The most valuable truism in audio is that the most important quality of reproduction is that it sounds good to you, not that you have accurately reproduced the mixing engineer's studio.
I doubt any of us bought an SVS sub so we could turn the nasty bass down, hence the frequency with which you see people talk about running their subs "hot", i.e. turned up above some balanced volume (even if they then turn it back down to avoid getting divorced or evicted).
Originally Posted by jrnewquist
I did not do a sub crawl or anything, because I have little choice about where it's located. And I have no idea if I'm dealing with voids (and if so, dialing the sound up would simply make up for it, to some sloppy estimated degree) or not.
That's the tricky part: tuning for the room. On the one end of the scale you are building the room with wall and corner treatments, furniture, etc. and are running around with an expensive SPL meter while running test tones and frequency sweeps. On the other you tune by ear (assisted by your receiver) in the area in which you sit because that's the only place it matters.
As the discussion in thread indicates, you may start at one end of the scale, but in time you have at least dual subs on home made risers and are posting plots of your FRs. Along the way don't forget to enjoy your sound even though you know it could be ever so slightly better.
Honestly the rythmik would be a no brainer for me but the shipping cost really is pretty insane imo ($355). I'm basically in 'pick a subwoofer paralysis' mode between the SVS PB13U (cheapest, best looking, but least output), Rythmik FV15HP (shipping rape + warranty hassles), and the Funk 18.0C (beautiful box, ugly driver, zero reviews anywhere).
...But the more potent LFE is just so seductive. Dammit.
