Originally Posted by laychooba
MOTHER. OF. GOD.
mine finally got here yesterday after waiting for 3 weeks. i got them from homeboy mason at sonicboom
(aka SVS canada). they arrived on a skid and i almost died bringing them home/moving them around. these
are some serious puppies. finally got them both unboxed and re-arranged the room a little bit to set them
up.
they got plugged in, i adjusted the the main volume on them to -10, but by that time it was kinda late
and i didn't want to blow my neighbours head off (i live in an attached unit). i had a blu-ray playing and even
at -40db on my reciever, it was DIRTYYYYYYY. hahahah
i'm going to run ARC on my anthem tommororw since i have the day off so i'll be killing ithem all day. also the
adjustments on these things are out of control! is there anywhere out there that has a setup tutorial specifically
for the SVS's with sledge amps?
MOTHER. OF. GOD.
up.
Really cool.........running dual subs from day one.............most impressive!
Congrats on your purchase and thanks for sharing the pics. About setting things up in your subs (sledge amps), look at the link attached and jump to page #26 - important thing here is the port configuration. Other new owners were reporting issues with the sub and it was basically due to incorrect configuration between the ports blocked and selecting the correct subsonic filter in the amp. I hope this helps:
http://www.svsound.com/images/svs/doclibrary/pb13-ultra_manual.pdf
How big is your room? You have duals, so I'll recommend going with one port blocked and tune setting at 16Hz.
Congrats again and don't forget to report back as soon you have your system calibrated.
Still bite my lips about going PC instead of PB, but they simply wouldn't have fit.
