Hey, I was checking this out, but am not sure which options to try, to use this with the meter I bought/got with my SMART III calibration kit.
I have one of the Extech "403125" meters, and some R / G / B filters.
I assume I should choose the generator HCFR to get the test patterns off my HTP, but manual DVD to get the patters off my HD-DVD player?
And then for meter I choose Capture Simule? And then choose "Start Calibration" rather than using an existing file.
And then for "reference" ("Display"?) I choose sRGB.
But I'm not sure what next?
), there is no use for these parameters for you. Just select "Cancel" and paste xyY measurement from your meter in the table (if you get them).
