I've got a geometry problem with my 960 and I could use some help.
The picture is skewed as follows: the top left corner is lower than top right corner, and lower left corner is lower than the lower right corner.
BUT the left and right sides are parallel to each other, and straight up and down.
So if I correct the skew by tilting the image clockwise, the left and right sides are no longer vertical. They are tilted.
If you imagine the image is a section of fence, and the posts are perfectly vertical, then the problem is that the left fencepost is lower than the right one. I want to lift that left post so it's the same height as the right post.
Any idea how to do this? I've checked the geometry pages of the service manual. Maybe it's some combination of service menu adjustments?
