Our probe is still under evolution/tunning, we plan to use the second sensor at a later stage, I can't yet comment how but one usage will be to use one filterered and not other, also to do band filtering...
At present you can use one or other to measure or both (to cross ref).
Beside the calibration thing, the only annoyance at the moment is some disturbance in measure due to IR. But that is only a problem on some projectors where buld tend to emit a bit too much IR. It can easily be filtered by an IR filter.
On the good news side, I can state we have made huge progress in multilanguage support
and also in supporting the Spyder II... There may be a version available quite soon...
--Patrice
