After reading through most of the threads for 40 inch LCDs or larger owners are experiencing uneven backlighting in the form of vertical or horizontal lines (bands) of various widths. The intensity of these lines varies from unit to unit. Usually noticable on a grey background or turf during a sporting event when the camera pans. What I am doing is starting a poll to see how many users are experiencing this. If you could vote and then post the make and model of your screen that would help as well. I’d like to see how wide spread this problem is across the brands. Any screenshots you have would help as well. Hopefully the information collected can be used to help manufactures correct the issue with their product.
Thanks in advance!
Westinghouse LVM47-w1
Vertical uneven backlighting
Thanks in advance!
