I'm not sure if this is normal or a problem. My 42 inch LCD TV (model 42LBDR1) seems to get fairly hot. The performance doesn't change, it just gets warm at the top of the TV.
I measured 111 degrees F at the top vent. Other than that spot, the temperatures are not of concern.
Interestingly, the manual states that the operating temps should not exceed 104 degrees F. I'm not sure whether this means in a 104 degree room or where this max temp is to be measured from.
In any case, is this unusual or problematic? Does anyone know what this operating temperature is meant to refer to (the TV, the room,...)?
Thank you.
Bob
Thank you.
Bob
